Commit e859e9ed authored by François Bobot's avatar François Bobot
explicit forbidden with enumeration :
TPTP/simplify : explicit not anymore the default
parent a8f1e433
o TPTP : encoding is not anymore the default for tptp provers.
It is now forbidden to use explicit with enumeration.
o [IDE] source file names are stored in database as relative paths o [IDE] source file names are stored in database as relative paths
to the database, so that databases are now easier to move from a to the database, so that databases are now easier to move from a
machine to another (e.g when they are stored in source control machine to another (e.g when they are stored in source control
...@@ -67,12 +67,12 @@ theory int.Int ...@@ -67,12 +67,12 @@ theory int.Int
remove prop CompatOrderAdd remove prop CompatOrderAdd
(* use with explicit polymorphism *) (* use with explicit polymorphism *)
meta "enco_poly" "explicit" (* meta "enco_poly" "explicit" *)
meta "encoding : base" type int meta "encoding : base" type int
(* use with encoding_decorate *) (* use with encoding_decorate *)
(* meta "enco_poly" "decorate" *) meta "enco_poly" "decorate"
(* meta "encoding : kept" type int *) meta "encoding : kept" type int
end end
...@@ -194,6 +194,7 @@ let query_syntax sm id = Mid.find_option id sm ...@@ -194,6 +194,7 @@ let query_syntax sm id = Mid.find_option id sm
(** {2 exceptions to use in transformations and printers} *) (** {2 exceptions to use in transformations and printers} *)
exception UnsupportedTysymbol of tysymbol * string
exception UnsupportedType of ty * string exception UnsupportedType of ty * string
exception UnsupportedExpr of expr * string exception UnsupportedExpr of expr * string
exception UnsupportedDecl of decl * string exception UnsupportedDecl of decl * string
...@@ -202,6 +203,7 @@ exception Unsupported of string ...@@ -202,6 +203,7 @@ exception Unsupported of string
(** {3 functions that catch inner error} *) (** {3 functions that catch inner error} *)
let unsupportedTysymbol e s = raise (UnsupportedTysymbol (e,s))
let unsupportedType e s = raise (UnsupportedType (e,s)) let unsupportedType e s = raise (UnsupportedType (e,s))
let unsupportedTerm e s = raise (UnsupportedExpr (Term e,s)) let unsupportedTerm e s = raise (UnsupportedExpr (Term e,s))
let unsupportedFmla e s = raise (UnsupportedExpr (Fmla e,s)) let unsupportedFmla e s = raise (UnsupportedExpr (Fmla e,s))
...@@ -213,6 +215,9 @@ let unsupported s = raise (Unsupported s) ...@@ -213,6 +215,9 @@ let unsupported s = raise (Unsupported s)
let catch_unsupportedType f e = let catch_unsupportedType f e =
try f e with Unsupported s -> unsupportedType e s try f e with Unsupported s -> unsupportedType e s
let catch_unsupportedTysymbol f e =
try f e with Unsupported s -> unsupportedTysymbol e s
let catch_unsupportedTerm f e = let catch_unsupportedTerm f e =
try f e with Unsupported s -> unsupportedTerm e s try f e with Unsupported s -> unsupportedTerm e s
...@@ -245,6 +250,9 @@ let () = Exn_printer.register (fun fmt exn -> match exn with ...@@ -245,6 +250,9 @@ let () = Exn_printer.register (fun fmt exn -> match exn with
| UnsupportedType (e,s) -> | UnsupportedType (e,s) ->
fprintf fmt "@[<hov 3> This type isn't supported:@\n%a@\n%s@]" fprintf fmt "@[<hov 3> This type isn't supported:@\n%a@\n%s@]"
Pretty.print_ty e s Pretty.print_ty e s
| UnsupportedTysymbol (e,s) ->
Pretty.print_ts e s
| UnsupportedExpr (e,s) -> | UnsupportedExpr (e,s) ->
fprintf fmt "@[<hov 3> This expression isn't supported:@\n%a@\n%s@]" fprintf fmt "@[<hov 3> This expression isn't supported:@\n%a@\n%s@]"
Pretty.print_expr e s Pretty.print_expr e s
...@@ -66,11 +66,13 @@ val syntax_arguments : string -> 'a pp -> 'a list pp ...@@ -66,11 +66,13 @@ val syntax_arguments : string -> 'a pp -> 'a list pp
exception NotImplemented of string exception NotImplemented of string
val unsupportedTysymbol : tysymbol -> string -> 'a
val unsupportedType : ty -> string -> 'a val unsupportedType : ty -> string -> 'a
val unsupportedTerm : term -> string -> 'a val unsupportedTerm : term -> string -> 'a
val unsupportedFmla : fmla -> string -> 'a val unsupportedFmla : fmla -> string -> 'a
...@@ -91,6 +93,11 @@ val catch_unsupportedType : (ty -> 'a) -> (ty -> 'a) ...@@ -91,6 +93,11 @@ val catch_unsupportedType : (ty -> 'a) -> (ty -> 'a)
- return [f arg] if [f arg] does not raise {!Unsupported} exception - return [f arg] if [f arg] does not raise {!Unsupported} exception
- raise [UnsupportedType (arg,s)] if [f arg] raises [Unsupported s]*) - raise [UnsupportedType (arg,s)] if [f arg] raises [Unsupported s]*)
val catch_unsupportedTysymbol : (tysymbol -> 'a) -> (tysymbol -> 'a)
(** same as {! catch_unsupportedType} but use [UnsupportedTysymbol]
instead of [UnsupportedType]*)
val catch_unsupportedTerm : (term -> 'a) -> (term -> 'a) val catch_unsupportedTerm : (term -> 'a) -> (term -> 'a)
(** same as {! catch_unsupportedType} but use [UnsupportedExpr] (** same as {! catch_unsupportedType} but use [UnsupportedExpr]
instead of [UnsupportedType]*) instead of [UnsupportedType]*)
...@@ -45,7 +45,7 @@ let kept_opt,register_enco_kept = enco_opt "kept" "bridge" ...@@ -45,7 +45,7 @@ let kept_opt,register_enco_kept = enco_opt "kept" "bridge"
let poly_opt,register_enco_poly = enco_opt "poly" "decorate" let poly_opt,register_enco_poly = enco_opt "poly" "decorate"
let poly_smt_opt = poly_opt let poly_smt_opt = poly_opt
let poly_tptp_opt = { poly_opt with default = "explicit" } let poly_tptp_opt = poly_opt
let enco_gen opt env = let enco_gen opt env =
Trans.on_meta_excl opt.meta (fun alo -> Trans.on_meta_excl opt.meta (fun alo ->
...@@ -64,15 +64,29 @@ let enco_kept = enco_gen kept_opt ...@@ -64,15 +64,29 @@ let enco_kept = enco_gen kept_opt
let enco_poly_smt = enco_gen poly_smt_opt let enco_poly_smt = enco_gen poly_smt_opt
let enco_poly_tptp = enco_gen poly_tptp_opt let enco_poly_tptp = enco_gen poly_tptp_opt
let maybe_encoding_enumeration = let forbid_for_explicit =
Encoding_enumeration.forbid_enumeration
"explicit is unsound in presence of this finite type"
let maybe_forbid_enumeration =
Trans.on_meta_excl poly_smt_opt.meta (fun alo ->
let s = match alo with
| None -> poly_smt_opt.default
| Some [MAstr s] -> s
| _ -> assert false in
if s = "explicit"
then forbid_for_explicit
else Trans.identity)
let forbid_enumeration =
Trans.on_meta_excl poly_smt_opt.meta (fun alo -> Trans.on_meta_excl poly_smt_opt.meta (fun alo ->
let s = match alo with let s = match alo with
| None -> poly_smt_opt.default | None -> poly_smt_opt.default
| Some [MAstr s] -> s | Some [MAstr s] -> s
| _ -> assert false in | _ -> assert false in
if s = "explicit" if s = "explicit"
then Encoding_enumeration.encoding_enumeration then forbid_for_explicit
else identity) else Encoding_enumeration.encoding_enumeration)
open Ty open Ty
...@@ -99,13 +113,13 @@ let monomorphise_goal = ...@@ -99,13 +113,13 @@ let monomorphise_goal =
let encoding_smt env = let encoding_smt env =
compose monomorphise_goal compose monomorphise_goal
(compose maybe_encoding_enumeration (compose maybe_forbid_enumeration
(compose (enco_select env) (compose (enco_select env)
(compose (enco_kept env) (enco_poly_smt env)))) (compose (enco_kept env) (enco_poly_smt env))))
let encoding_tptp env = let encoding_tptp env =
(compose Encoding_enumeration.encoding_enumeration (compose forbid_enumeration
(compose (enco_kept env) (enco_poly_tptp env)))) (compose (enco_kept env) (enco_poly_tptp env))))
...@@ -32,7 +32,7 @@ val register_enco_poly : string -> (env -> task trans) -> unit ...@@ -32,7 +32,7 @@ val register_enco_poly : string -> (env -> task trans) -> unit
val monomorphise_goal : Task.task Trans.trans val monomorphise_goal : Task.task Trans.trans
val maybe_encoding_enumeration : Task.task Trans.trans val maybe_forbid_enumeration : Task.task Trans.trans
val enco_poly_smt : Env.env -> Task.task Trans.trans val enco_poly_smt : Env.env -> Task.task Trans.trans
val print_kept : Task.task Trans.trans val print_kept : Task.task Trans.trans
...@@ -576,7 +576,7 @@ let encoding_smt_array env = ...@@ -576,7 +576,7 @@ let encoding_smt_array env =
Trans.on_used_theory th_array (fun used -> Trans.on_used_theory th_array (fun used ->
if not used then Encoding.encoding_smt env else if not used then Encoding.encoding_smt env else
compose Encoding.monomorphise_goal compose Encoding.monomorphise_goal
(compose Encoding.maybe_encoding_enumeration (compose Encoding.maybe_forbid_enumeration
(compose (select_subterm_array th_array) (compose (select_subterm_array th_array)
(compose Encoding.print_kept (compose Encoding.print_kept
(compose (Encoding_instantiate.t (compose (Encoding_instantiate.t
...@@ -93,5 +93,10 @@ let encoding_enumeration = ...@@ -93,5 +93,10 @@ let encoding_enumeration =
let tenv = { enum = enum ; projs = projs } in let tenv = { enum = enum ; projs = projs } in
Trans.decl (decl tenv) None) Trans.decl (decl tenv) None)
let forbid_enumeration s =
Trans.on_tagged_ts meta_enum (fun enum ->
if Sts.is_empty enum then Trans.identity
else Printer.unsupportedTysymbol (Sts.choose enum) s)
let () = Trans.register_transform "encoding_enumeration" encoding_enumeration let () = Trans.register_transform "encoding_enumeration" encoding_enumeration
...@@ -18,3 +18,6 @@ ...@@ -18,3 +18,6 @@
val encoding_enumeration : Task.task Trans.trans val encoding_enumeration : Task.task Trans.trans
val forbid_enumeration : string ->Task.task Trans.trans
(* [forbid_enumeration s] if the task contains encoded enumeration
unsupportedTysymbol is raised with the message [s] *)
