Commit e77fd95c authored by Guillaume Melquiond's avatar Guillaume Melquiond
Fix compilation of Jessie 3.
parent 6643d425
...@@ -41,7 +41,7 @@ module Enabled = ...@@ -41,7 +41,7 @@ module Enabled =
open Cil_types open Cil_types
open Why3 open Why3
open Wstdlib
...@@ -271,12 +271,12 @@ let rec ctype_and_default ty = ...@@ -271,12 +271,12 @@ let rec ctype_and_default ty =
match ty with match ty with
| TVoid _attr -> Mlw_ty.ity_unit, Mlw_expr.e_void | TVoid _attr -> Mlw_ty.ity_unit, Mlw_expr.e_void
| TInt (IInt, _attr) -> | TInt (IInt, _attr) ->
let n = Mlw_expr.e_const (Number.ConstInt (Number.int_const_dec "0")) in let n = Mlw_expr.e_const (Number.const_of_int 0) Mlw_ty.ity_int in
mlw_uint32_type, mlw_uint32_type,
Mlw_expr.e_app Mlw_expr.e_app
(Mlw_expr.e_arrow uint32ofint_fun [mlw_int_type] mlw_uint32_type) [n] (Mlw_expr.e_arrow uint32ofint_fun [mlw_int_type] mlw_uint32_type) [n]
| TInt (ILong, _attr) -> | TInt (ILong, _attr) ->
mlw_int64_type, mlw_int64_type,
(Mlw_expr.e_arrow int64ofint_fun [mlw_int_type] mlw_int64_type) [n] (Mlw_expr.e_arrow int64ofint_fun [mlw_int_type] mlw_int64_type) [n]
...@@ -365,11 +365,13 @@ let mk_set ref_ty ty = ...@@ -365,11 +365,13 @@ let mk_set ref_ty ty =
let logic_constant c = let logic_constant c =
match c with match c with
| Integer(_value,Some s) -> | Integer(_value,Some s) ->
let c = Literals.integer s in Number.ConstInt c let c = Literals.integer s in
Term.t_const (Number.(ConstInt {ic_negative = false; ic_abs = c})) Ty.ty_int
| Integer(_value,None) -> | Integer(_value,None) ->
Self.not_yet_implemented "logic_constant Integer None" Self.not_yet_implemented "logic_constant Integer None"
| LReal { r_literal = s } -> | LReal { r_literal = s } ->
let c = Literals.floating_point s in Number.ConstReal c let c = Literals.floating_point s in
Term.t_const (Number.(ConstReal {rc_negative = false; rc_abs = c})) Ty.ty_real
| (LStr _|LWStr _|LChr _|LEnum _) -> | (LStr _|LWStr _|LChr _|LEnum _) ->
Self.not_yet_implemented "logic_constant" Self.not_yet_implemented "logic_constant"
...@@ -421,9 +423,7 @@ let bound_vars = Hashtbl.create 257 ...@@ -421,9 +423,7 @@ let bound_vars = Hashtbl.create 257
let create_lvar v = let create_lvar v =
let id = Ident.id_fresh v.lv_name in let id = Ident.id_fresh v.lv_name in
let vs = Term.create_vsymbol id (logic_type v.lv_type) in let vs = Term.create_vsymbol id (logic_type v.lv_type) in
Self.result "create logic variable %d" v.lv_id; Self.result "create logic variable %d" v.lv_id;
Hashtbl.add bound_vars v.lv_id vs; Hashtbl.add bound_vars v.lv_id vs;
vs vs
...@@ -437,9 +437,7 @@ let get_lvar lv = ...@@ -437,9 +437,7 @@ let get_lvar lv =
let program_vars = Hashtbl.create 257 let program_vars = Hashtbl.create 257
let create_var_full v = let create_var_full v =
(**) Self.result "create program variable %s (%d)" v.vname v.vid;
let id = Ident.id_fresh v.vname in let id = Ident.id_fresh v.vname in
let ty,def = ctype_and_default v.vtype in let ty,def = ctype_and_default v.vtype in
let def = Mlw_expr.e_app (mk_ref ty) [def] in let def = Mlw_expr.e_app (mk_ref ty) [def] in
...@@ -524,7 +522,7 @@ let coerce_to_int ty t = ...@@ -524,7 +522,7 @@ let coerce_to_int ty t =
let rec term_node ~label t = let rec term_node ~label t =
match t with match t with
| TConst cst -> Term.t_const (logic_constant cst) | TConst cst -> logic_constant cst
| TLval lv -> tlval ~label lv | TLval lv -> tlval ~label lv
| TBinOp (op, t1, t2) -> bin (term ~label t1) op (term ~label t2) | TBinOp (op, t1, t2) -> bin (term ~label t1) op (term ~label t2)
| TUnOp (op, t) -> unary op (term ~label t) | TUnOp (op, t) -> unary op (term ~label t)
...@@ -549,11 +547,12 @@ let rec term_node ~label t = ...@@ -549,11 +547,12 @@ let rec term_node ~label t =
| Tat (t, lab) -> | Tat (t, lab) ->
begin begin
match lab with match lab with
| LogicLabel(None, "Here") -> snd (term ~label:Here t) | BuiltinLabel Cil_types.Here -> snd (term ~label:Here t)
| LogicLabel(None, "Old") -> snd (term ~label:Old t) | BuiltinLabel Cil_types.Old -> snd (term ~label:Old t)
| LogicLabel(None, lab) -> snd (term ~label:(At lab) t) | BuiltinLabel _ ->
| LogicLabel(Some _, _lab) -> Self.not_yet_implemented "term_node Tat/BuiltinLabel/other"
Self.not_yet_implemented "term_node Tat/LogicLabel/Some" | FormalLabel _ ->
Self.not_yet_implemented "term_node Tat/FormalLabel"
| StmtLabel _ -> | StmtLabel _ ->
Self.not_yet_implemented "term_node Tat/StmtLabel" Self.not_yet_implemented "term_node Tat/StmtLabel"
end end
...@@ -738,10 +737,11 @@ let rec predicate ~label p = ...@@ -738,10 +737,11 @@ let rec predicate ~label p =
| Pallocable (_, _) | Pallocable (_, _)
| Pfreeable (_, _) | Pfreeable (_, _)
| Pfresh (_, _, _, _) | Pfresh (_, _, _, _)
| Psubtype (_, _) -> | Psubtype (_, _)
| Pvalid_function _ ->
Self.not_yet_implemented "predicate" Self.not_yet_implemented "predicate"
and predicate_named ~label p = predicate ~label p.content and predicate_named ~label p = predicate ~label p.pred_content
...@@ -784,7 +784,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -784,7 +784,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
List.map (fun s -> Ty.create_tvsymbol (Ident.id_fresh s)) lt.lt_params List.map (fun s -> Ty.create_tvsymbol (Ident.id_fresh s)) lt.lt_params
in in
let tdef = match lt.lt_def with let tdef = match lt.lt_def with
| None -> None | None -> Ty.NoDef
| Some _ -> Self.not_yet_implemented "logic_decl Dtype non abstract" | Some _ -> Self.not_yet_implemented "logic_decl Dtype non abstract"
in in
let ts = let ts =
...@@ -818,7 +818,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -818,7 +818,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
| _ -> | _ ->
Self.not_yet_implemented "Dfun_or_pred with labels" Self.not_yet_implemented "Dfun_or_pred with labels"
end end
| Dlemma(name,is_axiom,labels,vars,p,loc) -> | Dlemma(name,is_axiom,labels,vars,p,attrs,loc) ->
begin begin
match labels,vars with match labels,vars with
...@@ -835,7 +835,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -835,7 +835,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
| _ -> | _ ->
Self.not_yet_implemented "Dlemma with labels or vars" Self.not_yet_implemented "Dlemma with labels or vars"
end end
| Daxiomatic (name, decls', loc) -> | Daxiomatic (name, decls', attrs, loc) ->
let theories = let theories =
add_decls_as_theory theories add_decls_as_theory theories
(Ident.id_fresh global_logic_decls_theory_name) decls (Ident.id_fresh global_logic_decls_theory_name) decls
...@@ -851,15 +851,14 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) = ...@@ -851,15 +851,14 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
add_decls_as_theory theories (Ident.id_user name (Loc.extract loc)) decls'' add_decls_as_theory theories (Ident.id_user name (Loc.extract loc)) decls''
in in
(theories,[]) (theories,[])
| Dvolatile (_, _, _, _) | Dvolatile (_, _, _, _, _)
| Dinvariant (_, _) | Dinvariant (_, _)
| Dtype_annot (_, _) | Dtype_annot (_, _)
| Dmodel_annot (_, _) | Dmodel_annot (_, _)
| Dcustom_annot (_, _, _) | Dcustom_annot (_, _, _, _)
-> Self.not_yet_implemented "logic_decl" -> Self.not_yet_implemented "logic_decl"
let identified_proposition p = let identified_proposition p = p.ip_content
{ name = p.ip_name; loc = p.ip_loc; content = p.ip_content }
...@@ -897,6 +896,8 @@ let annot a e = ...@@ -897,6 +896,8 @@ let annot a e =
Self.not_yet_implemented "annot AAllocation" Self.not_yet_implemented "annot AAllocation"
| APragma _ -> | APragma _ ->
Self.not_yet_implemented "annot APragma" Self.not_yet_implemented "annot APragma"
| AExtended _ ->
Self.not_yet_implemented "annot AExtended"
let loop_annot a = let loop_annot a =
List.fold_left (fun (inv,var) a -> List.fold_left (fun (inv,var) a ->
...@@ -920,7 +921,9 @@ let loop_annot a = ...@@ -920,7 +921,9 @@ let loop_annot a =
| AAllocation _ -> | AAllocation _ ->
Self.not_yet_implemented "loop_annot AAllocation" Self.not_yet_implemented "loop_annot AAllocation"
Self.not_yet_implemented "loop_annot APragma") Self.not_yet_implemented "loop_annot APragma"
| AExtended _ ->
Self.not_yet_implemented "loop_annot AExtended")
(Term.t_true, []) a (Term.t_true, []) a
let binop op e1 e2 = let binop op e1 e2 =
...@@ -967,7 +970,7 @@ let constant c = ...@@ -967,7 +970,7 @@ let constant c =
| Some s -> s | Some s -> s
| None -> Integer.to_string t | None -> Integer.to_string t
in in
let n = Mlw_expr.e_const (Number.ConstInt (Literals.integer s)) in let n = Mlw_expr.e_const (Number.(ConstInt {ic_negative = false; ic_abs = Literals.integer s})) Mlw_ty.ity_int in
| CInt64(_t,_ikind, _) -> | CInt64(_t,_ikind, _) ->
...@@ -1093,6 +1096,8 @@ let instr i = ...@@ -1093,6 +1096,8 @@ let instr i =
Mlw_expr.e_void Mlw_expr.e_void
| Code_annot (_, _) -> | Code_annot (_, _) ->
Self.not_yet_implemented "instr Code_annot" Self.not_yet_implemented "instr Code_annot"
| Local_init _ ->
Self.not_yet_implemented "instr Local_init"
let exc_break = let exc_break =
Mlw_ty.create_xsymbol (Ident.id_fresh "Break") Mlw_ty.ity_unit Mlw_ty.create_xsymbol (Ident.id_fresh "Break") Mlw_ty.ity_unit
...@@ -56,11 +56,11 @@ let oct_escape = '\\' rO rO? rO? ...@@ -56,11 +56,11 @@ let oct_escape = '\\' rO rO? rO?
(* integer literals, both decimal, hexadecimal and octal *) (* integer literals, both decimal, hexadecimal and octal *)
rule integer_literal = parse rule integer_literal = parse
(* hexadecimal *) (* hexadecimal *)
| '0'['x''X'] (rH+ as d) rIS eof { Number.int_const_hex d } | '0'['x''X'] (rH+ as d) rIS eof { Number.int_literal_hex d }
(* octal *) (* octal *)
| '0' (rO+ as d) rIS eof { Number.int_const_oct d } | '0' (rO+ as d) rIS eof { Number.int_literal_oct d }
(* decimal *) (* decimal *)
| (rD+ as d) rIS eof { Number.int_const_dec d } | (rD+ as d) rIS eof { Number.int_literal_dec d }
(* TODO: character literals (* TODO: character literals
| ('L'? "'" as prelude) (([^ '\\' '\'' '\n']|("\\"[^ '\n']))+ as content) "'" | ('L'? "'" as prelude) (([^ '\\' '\'' '\n']|("\\"[^ '\n']))+ as content) "'"
