GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
e77fd95c
e77fd95c
Guillaume Melquiond
Fix compilation of Jessie 3.
6643d425
2
2 changed files
35 additions
30 deletions
+35
-30
src/jessie/ACSLtoWhy3.ml
+32
-27
src/jessie/literals.mll
+3
-3
e77fd95c
@@ -41,7 +41,7 @@ module Enabled =
open
Cil_types
open
Why3
open
Wstdlib
@@ -271,12 +271,12 @@ let rec ctype_and_default ty =
match
ty
TVoid
_attr
Mlw_ty
ity_unit
Mlw_expr
e_void
TInt
IInt
_attr
let
n
Mlw_expr
e_const
Number
ConstInt
Number
int_const_dec
"0"
in
let
n
Mlw_expr
e_const
Number
const_of_int
Mlw_ty
ity_int
in
mlw_uint32_type
Mlw_expr
e_app
Mlw_expr
e_arrow
uint32ofint_fun
mlw_int_type
mlw_uint32_type
n
TInt
ILong
_attr
let
n
Mlw_expr
e_const
Number
ConstInt
Number
int_const_dec
"0"
in
let
n
Mlw_expr
e_const
Number
const_of_int
Mlw_ty
ity_int
in
mlw_int64_type
Mlw_expr
e_app
Mlw_expr
e_arrow
int64ofint_fun
mlw_int_type
mlw_int64_type
n
@@ -365,11 +365,13 @@ let mk_set ref_ty ty =
let
logic_constant
c
match
c
Integer
_value
Some
s
let
c
Literals
integer
s
in
Number
ConstInt
c
let
c
Literals
integer
s
in
Term
t_const
Number
ConstInt
ic_negative
false
ic_abs
c
Ty
ty_int
Integer
_value
None
Self
not_yet_implemented
"logic_constant Integer None"
LReal
r_literal
s
let
c
Literals
floating_point
s
in
Number
ConstReal
c
let
c
Literals
floating_point
s
in
Term
t_const
Number
ConstReal
rc_negative
false
rc_abs
c
Ty
ty_real
LStr
_
LWStr
_
LChr
_
LEnum
_
Self
not_yet_implemented
"logic_constant"
@@ -421,9 +423,7 @@ let bound_vars = Hashtbl.create 257
let
create_lvar
v
let
id
Ident
id_fresh
v
lv_name
in
let
vs
Term
create_vsymbol
id
logic_type
v
lv_type
in
Self
result
"create logic variable %d"
v
lv_id
Hashtbl
add
bound_vars
v
lv_id
vs
vs
@@ -437,9 +437,7 @@ let get_lvar lv =
let
program_vars
Hashtbl
create
257
let
create_var_full
v
Self
result
"create program variable %s (%d)"
v
vname
v
vid
Self
result
v
vname
v
vid
let
id
Ident
id_fresh
v
vname
in
let
ty
def
ctype_and_default
v
vtype
in
let
def
Mlw_expr
e_app
mk_ref
ty
def
in
@@ -524,7 +522,7 @@ let coerce_to_int ty t =
let
rec
term_node
label
t
match
t
TConst
cst
Term
t_const
logic_constant
cst
TConst
cst
logic_constant
cst
TLval
lv
tlval
label
lv
TBinOp
op
t1
t2
bin
term
label
t1
op
term
label
t2
TUnOp
op
t
unary
op
term
label
t
@@ -549,11 +547,12 @@ let rec term_node ~label t =
Tat
t
lab
begin
match
lab
LogicLabel
None
"Here"
snd
term
label
Here
t
LogicLabel
None
"Old"
snd
term
label
Old
t
LogicLabel
None
lab
snd
term
label
At
lab
t
LogicLabel
Some
_
_lab
Self
not_yet_implemented
"term_node Tat/LogicLabel/Some"
BuiltinLabel
Cil_types
Here
snd
term
label
Here
t
BuiltinLabel
Cil_types
Old
snd
term
label
Old
t
BuiltinLabel
_
Self
not_yet_implemented
"term_node Tat/BuiltinLabel/other"
FormalLabel
_
Self
not_yet_implemented
"term_node Tat/FormalLabel"
StmtLabel
_
Self
not_yet_implemented
"term_node Tat/StmtLabel"
@@ -738,10 +737,11 @@ let rec predicate ~label p =
Pallocable
_
_
Pfreeable
_
_
Pfresh
_
_
_
_
Psubtype
_
_
Psubtype
_
_
Pvalid_function
_
Self
not_yet_implemented
"predicate"
predicate_named
label
p
predicate
label
p
content
predicate_named
label
p
predicate
label
p
pred_
content
@@ -784,7 +784,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
map
fun
s
Ty
create_tvsymbol
Ident
id_fresh
s
lt
lt_params
in
let
tdef
match
lt
lt_def
None
None
None
Ty
NoDef
Some
_
Self
not_yet_implemented
"logic_decl Dtype non abstract"
in
let
ts
@@ -818,7 +818,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
_
Self
not_yet_implemented
"Dfun_or_pred with labels"
Dlemma
name
is_axiom
labels
vars
p
loc
Dlemma
name
is_axiom
labels
vars
p
attrs
loc
begin
match
labels
vars
@@ -835,7 +835,7 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
_
Self
not_yet_implemented
"Dlemma with labels or vars"
Daxiomatic
name
decls'
loc
Daxiomatic
name
decls'
attrs
loc
let
theories
add_decls_as_theory
theories
Ident
id_fresh
global_logic_decls_theory_name
decls
@@ -851,15 +851,14 @@ let rec logic_decl ~in_axiomatic a _loc (theories,decls) =
add_decls_as_theory
theories
Ident
id_user
name
Loc
extract
loc
decls''
in
theories
Dvolatile
_
_
_
_
Dvolatile
_
_
_
_
_
Dinvariant
_
_
Dtype_annot
_
_
Dmodel_annot
_
_
Dcustom_annot
_
_
_
Dcustom_annot
_
_
_
_
Self
not_yet_implemented
"logic_decl"
let
identified_proposition
p
name
p
ip_name
loc
p
ip_loc
content
p
ip_content
let
p
p
ip_content
@@ -897,6 +896,8 @@ let annot a e =
Self
not_yet_implemented
"annot AAllocation"
APragma
_
Self
not_yet_implemented
"annot APragma"
AExtended
_
Self
not_yet_implemented
"annot AExtended"
let
loop_annot
a
fold_left
fun
inv
var
a
@@ -920,7 +921,9 @@ let loop_annot a =
AAllocation
_
Self
not_yet_implemented
"loop_annot AAllocation"
APragma
_
Self
not_yet_implemented
"loop_annot APragma"
Self
not_yet_implemented
AExtended
_
Self
not_yet_implemented
"loop_annot AExtended"
Term
t_true
a
let
binop
op
e1
e2
@@ -967,7 +970,7 @@ let constant c =
Some
s
s
None
Integer
to_string
t
in
let
n
Mlw_expr
e_const
Number
ConstInt
Literals
integer
s
in
let
n
Mlw_expr
e_const
Number
ConstInt
ic_negative
false
ic_abs
Literals
integer
s
Mlw_ty
ity_int
in
Mlw_expr
e_app
Mlw_expr
e_arrow
uint32ofint_fun
mlw_int_type
mlw_uint32_type
n
CInt64
_t
,_
ikind
_
@@ -1093,6 +1096,8 @@ let instr i =
Mlw_expr
e_void
Code_annot
_
_
Self
not_yet_implemented
"instr Code_annot"
Local_init
_
Self
not_yet_implemented
"instr Local_init"
let
exc_break
Mlw_ty
create_xsymbol
Ident
id_fresh
"Break"
Mlw_ty
ity_unit
e77fd95c
@@ -56,11 +56,11 @@ let oct_escape = '\\' rO rO? rO?
(* integer literals, both decimal, hexadecimal and octal *)
rule
integer_literal
parse
(* hexadecimal *)
x''X'
rH
as
d
rIS
eof
Number
int_
const
_hex
d
x''X'
rH
as
d
rIS
eof
Number
int_
literal
_hex
d
(* octal *)
rO
as
d
rIS
eof
Number
int_
const
_oct
d
rO
as
d
rIS
eof
Number
int_
literal
_oct
d
(* decimal *)
rD
as
d
rIS
eof
Number
int_
const
_dec
d
rD
as
d
rIS
eof
Number
int_
literal
_dec
d
(* TODO: character literals
| ('L'? "'" as prelude) (([^ '\\' '\'' '\n']|("\\"[^ '\n']))+ as content) "'"
