Commit e63363c9 authored by Sylvain Dailler's avatar Sylvain Dailler
fix #220 : print for ind constr now only prints the constructor
Also, fix a problem of search on constructor
parent 57259417
...@@ -109,13 +109,31 @@ let load_strategies cont = ...@@ -109,13 +109,31 @@ let load_strategies cont =
let list_strategies cont = let list_strategies cont =
Hstr.fold (fun _ (name,short,_,_) acc -> (short,name)::acc) cont.Controller_itp.controller_strategies [] Hstr.fold (fun _ (name,short,_,_) acc -> (short,name)::acc) cont.Controller_itp.controller_strategies []
let symbol_name s = let symbol_name s =
match s with match s with
| Args_wrapper.Tstysymbol ts -> ts.Ty.ts_name | Args_wrapper.Tstysymbol ts -> ts.Ty.ts_name
| Args_wrapper.Tsprsymbol pr -> pr.Decl.pr_name | Args_wrapper.Tsprsymbol pr -> pr.Decl.pr_name
| Args_wrapper.Tslsymbol ls -> ls.Term.ls_name | Args_wrapper.Tslsymbol ls -> ls.Term.ls_name
(* Prints a constructor in a string using the inductive list definition
containing the constructor *)
let print_constr_string ~print_term ~print_pr il pr =
(* The inductive type is an lsymbol: we are sure to get a constructor *)
let constr_def =
List.fold_left (fun acc (_, ind_decl) ->
List.fold_left (fun acc x ->
if Decl.pr_equal (fst x) pr then
Some x
else
acc) acc ind_decl)
None il
in
match constr_def with
| None -> raise Not_found (* construct was not found: should not happen *)
| Some (_, t_def) ->
let s = Pp.string_of print_term t_def in
Pp.string_of print_pr pr ^ ": " ^ s
(* The id you are trying to use is undefined *) (* The id you are trying to use is undefined *)
exception Undefined_id of string exception Undefined_id of string
(* Bad number of arguments *) (* Bad number of arguments *)
...@@ -124,21 +142,23 @@ exception Number_of_arguments ...@@ -124,21 +142,23 @@ exception Number_of_arguments
let print_id s tables = let print_id s tables =
(* let tables = Args_wrapper.build_name_tables task in*) (* let tables = Args_wrapper.build_name_tables task in*)
let km = tables.Trans.known_map in let km = tables.Trans.known_map in
let id = try Args_wrapper.find_symbol s tables with let table_id =
| Args_wrapper.Arg_parse_type_error _ try Args_wrapper.find_symbol s tables with
| Args_wrapper.Arg_qid_not_found _ -> raise (Undefined_id s) in
let d =
try Ident.Mid.find (symbol_name id) km with
| Not_found -> raise Not_found (* Should not happen *)
| Args_wrapper.Arg_parse_type_error _ | Args_wrapper.Arg_parse_type_error _
| Args_wrapper.Arg_qid_not_found _ -> raise (Undefined_id s) | Args_wrapper.Arg_qid_not_found _ -> raise (Undefined_id s)
in in
(* Check that the symbol is defined *)
let d = (* Not_found should not happend *)
Ident.Mid.find (symbol_name table_id) km
in
let pr = tables.Trans.printer in let pr = tables.Trans.printer in
let apr = tables.Trans.aprinter in let apr = tables.Trans.aprinter in
let module P = (val Pretty.create pr apr pr pr false) in let module P = (val Pretty.create pr apr pr pr false) in
Pp.string_of P.print_decl d (* Different constructs are printed differently *)
match d.Decl.d_node, table_id with
| Decl.Dind (_, il), Args_wrapper.Tsprsymbol pr ->
print_constr_string ~print_term:P.print_term ~print_pr:P.print_pr il pr
| _ -> Pp.string_of P.print_decl d
(* searching ids in declarations *) (* searching ids in declarations *)
...@@ -156,7 +176,8 @@ let occurs_in_defn id (ls,def) = ...@@ -156,7 +176,8 @@ let occurs_in_defn id (ls,def) =
let (_vl,t) = Decl.open_ls_defn def in occurs_in_term id t let (_vl,t) = Decl.open_ls_defn def in occurs_in_term id t
let occurs_in_ind_decl id (_,clauses) = let occurs_in_ind_decl id (_,clauses) =
List.exists (fun (_,t) -> occurs_in_term id t) clauses List.exists (fun (pr,t) ->
Ident.id_equal id pr.Decl.pr_name || occurs_in_term id t) clauses
let occurs_in_decl d id = let occurs_in_decl d id =
Decl.(match d.d_node with Decl.(match d.d_node with
...@@ -178,7 +199,8 @@ let do_search ~search_both km idl = ...@@ -178,7 +199,8 @@ let do_search ~search_both km idl =
if search_both then if search_both then
(if List.exists (occurs_in_decl d) idl then Decl.Sdecl.add d acc else acc) (if List.exists (occurs_in_decl d) idl then Decl.Sdecl.add d acc else acc)
else else
(if List.for_all (occurs_in_decl d) idl then Decl.Sdecl.add d acc else acc)) km Decl.Sdecl.empty (if List.for_all (occurs_in_decl d) idl then Decl.Sdecl.add d acc else acc))
km Decl.Sdecl.empty
let search ~search_both s tables = let search ~search_both s tables =
let ids = List.rev_map let ids = List.rev_map
