Commit e62996dd authored by Raphael Rieu-Helft's avatar Raphael Rieu-Helft
Clean up
parent 3acf2fef
...@@ -608,7 +608,9 @@ module MLToC = struct ...@@ -608,7 +608,9 @@ module MLToC = struct
begin match query_syntax info.syntax ts.ts_name begin match query_syntax info.syntax ts.ts_name
with with
| Some s -> C.Tsyntax (s, List.map (ty_of_ty info) tl) | Some s -> C.Tsyntax (s, List.map (ty_of_ty info) tl)
| None -> C.Tnosyntax | None -> if is_ts_tuple ts && tl = []
then C.Tvoid
else C.Tnosyntax
end end
let ity_of_expr e = match e.e_ity with let ity_of_expr e = match e.e_ity with
...@@ -1045,10 +1047,7 @@ module MLToC = struct ...@@ -1045,10 +1047,7 @@ module MLToC = struct
acc && arity_zero ity.ity_node) true ity) acc && arity_zero ity.ity_node) true ity)
in in
(* FIXME is it necessary to have arity 0 in regions ?*) (* FIXME is it necessary to have arity 0 in regions ?*)
let rtype = let rtype = ty_of_ty info (ty_of_ity rity) in
if ity_equal rity Ity.ity_unit
then C.Tvoid
else ty_of_ty info (ty_of_ity rity) in
let rtype,sdecls = let rtype,sdecls =
if rtype=C.Tnosyntax && is_simple_tuple rity if rtype=C.Tnosyntax && is_simple_tuple rity
then then
