Commit e5922592 authored by Sylvain Dailler's avatar Sylvain Dailler
merge_trans: Exception is raised when stack_trace is given
Also replace eprintf with Warning.emit in session_itp.
parent 1d8789b7
...@@ -755,7 +755,7 @@ let update_theory_node notification s th = ...@@ -755,7 +755,7 @@ let update_theory_node notification s th =
try let p = theory_parent s th in try let p = theory_parent s th in
update_file_node notification s p update_file_node notification s p
with Not_found when not (Debug.test_flag Debug.stack_trace) -> with Not_found when not (Debug.test_flag Debug.stack_trace) ->
Format.eprintf "[Fatal] Session_itp.update_theory_node: parent missing@."; Warning.emit "[Fatal] Session_itp.update_theory_node: parent missing@.";
assert false assert false
end end
...@@ -783,7 +783,7 @@ let rec update_goal_node notification s id = ...@@ -783,7 +783,7 @@ let rec update_goal_node notification s id =
| Trans trans_id -> update_trans_node notification s trans_id | Trans trans_id -> update_trans_node notification s trans_id
| Theory th -> update_theory_node notification s th | Theory th -> update_theory_node notification s th
| exception Not_found when not (Debug.test_flag Debug.stack_trace) -> | exception Not_found when not (Debug.test_flag Debug.stack_trace) ->
Format.eprintf "Session_itp.update_goal_node: parent missing@."; Warning.emit "Session_itp.update_goal_node: parent missing@.";
Printexc.print_backtrace stderr; Printexc.print_backtrace stderr;
end end
...@@ -927,7 +927,7 @@ let string_attribute field r = ...@@ -927,7 +927,7 @@ let string_attribute field r =
try try
List.assoc field r.Xml.attributes List.assoc field r.Xml.attributes
with Not_found -> with Not_found ->
eprintf "[Error] missing required attribute '%s' from element '%s'@." Warning.emit "[Error] missing required attribute '%s' from element '%s'@."
field r.Xml.name; field r.Xml.name;
...@@ -1239,7 +1239,7 @@ let read_sum_and_shape ch = ...@@ -1239,7 +1239,7 @@ let read_sum_and_shape ch =
let old_sum = List.assoc "sum" attrs in let old_sum = List.assoc "sum" attrs in
if sum <> old_sum then if sum <> old_sum then
begin begin
Format.eprintf "old sum = %s ; new sum = %s@." old_sum sum; Warning.emit "old sum = %s ; new sum = %s@." old_sum sum;
raise raise
(ShapesFileError (ShapesFileError
"shapes files corrupted (sums do not correspond)") "shapes files corrupted (sums do not correspond)")
...@@ -1441,7 +1441,7 @@ let add_registered_transformation s env old_tr goal_id = ...@@ -1441,7 +1441,7 @@ let add_registered_transformation s env old_tr goal_id =
old_tr.transf_args) old_tr.transf_args)
goal.proofn_transformations in goal.proofn_transformations in
Format.eprintf "[add_registered_transformation] FATAL transformation already present@."; Warning.emit "[add_registered_transformation] FATAL transformation already present@.";
exit 2 exit 2
let subgoals = let subgoals =
...@@ -1470,10 +1470,12 @@ and merge_trans ~shape_version env old_s new_s new_goal_id old_tr_id = ...@@ -1470,10 +1470,12 @@ and merge_trans ~shape_version env old_s new_s new_goal_id old_tr_id =
(* add_registered_transformation actually apply the transformation. It can fail *) (* add_registered_transformation actually apply the transformation. It can fail *)
try Some (add_registered_transformation new_s env old_tr new_goal_id) try Some (add_registered_transformation new_s env old_tr new_goal_id)
with with
| e when not (Debug.test_flag debug_stack_trace) ->
raise e
(* Non fatal exception are silently ignored *) (* Non fatal exception are silently ignored *)
| e when not (is_fatal e) -> None | e when not (is_fatal e) -> None
| e when is_fatal e -> | e when is_fatal e ->
Format.eprintf "FATAL unexpected exception during application of %s: %a@." Warning.emit "FATAL unexpected exception during application of %s: %a@."
old_tr.transf_name Exn_printer.exn_printer e; old_tr.transf_name Exn_printer.exn_printer e;
(* Notify the user but still allow her to load why3 *) (* Notify the user but still allow her to load why3 *)
None None
...@@ -1514,7 +1516,7 @@ and merge_trans ~shape_version env old_s new_s new_goal_id old_tr_id = ...@@ -1514,7 +1516,7 @@ and merge_trans ~shape_version env old_s new_s new_goal_id old_tr_id =
found_detached := true found_detached := true
with e when not (Debug.test_flag debug_stack_trace) -> with e when not (Debug.test_flag debug_stack_trace) ->
Format.eprintf "[Session_itp.merge_trans] FATAL unexpected exception: %a@." Exn_printer.exn_printer e; Warning.emit "[Session_itp.merge_trans] FATAL unexpected exception: %a@." Exn_printer.exn_printer e;
exit 2 exit 2
...@@ -1620,7 +1622,7 @@ let add_file_section (s:session) (fn:string) ~file_is_detached ...@@ -1620,7 +1622,7 @@ let add_file_section (s:session) (fn:string) ~file_is_detached
if Hfile.mem s.session_files fn then if Hfile.mem s.session_files fn then
begin begin
Format.eprintf "[session] FATAL: file %s already in database@." fn; Warning.emit "[session] FATAL: file %s already in database@." fn;
exit 2 exit 2
end end
else else
