GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
Why3
why3
e4b1478b
e4b1478b
Sylvain Dailler
Add a save file notification and edit of source in gtk.
dd206906
4
4 changed files
44 additions
6 deletions
+44
-6
src/ide/why3ide.ml
src/ide/why3ide.ml
+17
-1
src/session/itp_communication.ml
+2
src/session/itp_communication.mli
+5
-1
src/session/itp_server.ml
+20
-4
src/ide/why3ide.ml
e4b1478b
@@ -408,6 +408,7 @@ let reload_menu_item : GMenu.menu_item =
clear_tree_and_table
goals_model
send_request
Reload_req
(* vpan222 contains:
2.2.2.1 a notebook containing view of the current task, source code etc
2.2.2.2 a vertiacal pan which contains
@@ -441,7 +442,8 @@ let task_view =
packing
scrolled_task_view
add
let
source_view_table
Hstr
create
14
let
source_view_table
int
GSourceView2
source_view
Hstr
t
Hstr
create
14
let
create_source_view
let
n
ref
in
@@ -886,6 +888,19 @@ let (_ : GMenu.menu_item) =
exp_factory
add_item
key
GdkKeysyms
_D
callback
detached_copy
"Detached copy"
let
save_sources
Hstr
iter
fun
k
_n
s
GSourceView2
source_view
let
text_to_save
s
source_buffer
get_text
in
send_request
Save_file_req
k
text_to_save
source_view_table
(* TODO replace this with menu items *)
let
_
GMenu
menu_item
exp_factory
add_item
key
GdkKeysyms
_X
"Save files"
callback
fun
save_sources
(* add a new file in the project *)
@@ -950,6 +965,7 @@ let treat_message_notification msg = match msg with
Task_Monitor
t
s
r
update_monitor
t
s
r
Open_File_Error
s
print_message
"%s"
s
Parse_Or_Type_Error
s
print_message
"%s"
s
File_Saved
s
print_message
"%s was saved"
s
Error
s
if
Debug
test_flag
debug
then
print_message
"%s"
s
e4b1478b
@@ -33,6 +33,7 @@ type message_notification =
Information
of
string
Task_Monitor
of
int
int
int
Parse_Or_Type_Error
of
string
File_Saved
of
string
Error
of
string
Open_File_Error
of
string
@@ -88,6 +89,7 @@ type ide_request =
Remove_subtree
of
node_ID
Copy_paste
of
node_ID
node_ID
Copy_detached
of
node_ID
Save_file_req
of
string
string
Get_first_unproven_node
of
node_ID
Get_Session_Tree_req
Save_req
e4b1478b
@@ -38,6 +38,8 @@ type message_notification =
(* A file was read or reloaded and now contains a parsing or typing error *)
Parse_Or_Type_Error
of
string
(* An error happened that could not be identified in server *)
File_Saved
of
string
(* [File_Saved f] f was saved *)
Error
of
string
Open_File_Error
of
string
@@ -78,7 +80,7 @@ type notification =
Task
of
node_ID
string
(* the node_ID's task *)
File_contents
of
string
string
(* File_contents (name, contents) *)
(* File_contents (
file
name, contents) *)
type
ide_request
Command_req
of
node_ID
string
@@ -93,6 +95,8 @@ type ide_request =
Remove_subtree
of
node_ID
Copy_paste
of
node_ID
node_ID
Copy_detached
of
node_ID
Save_file_req
of
string
string
(* Save_file_req (filename, content_of_file). Save the file *)
of
node_ID
Save_req
e4b1478b
@@ -289,6 +289,7 @@ let print_request fmt r =
Copy_paste
_
fprintf
fmt
"copy paste"
Copy_detached
_
fprintf
fmt
"copy detached"
fprintf
fmt
"get session tree"
Save_file_req
_
fprintf
fmt
"save file"
Save_req
fprintf
fmt
"save"
Reload_req
fprintf
fmt
"reload"
Replay_req
fprintf
fmt
"replay"
@@ -306,8 +307,9 @@ let print_msg fmt m =
Information
s
fprintf
fmt
"info %s"
s
Task_Monitor
_
fprintf
fmt
"task montor"
Parse_Or_Type_Error
s
fprintf
fmt
"parse_or_type_error:
\n
%s"
s
File_Saved
s
fprintf
fmt
"file saved %s"
s
Error
s
fprintf
fmt
"%s"
s
Open_File_Error
s
fprintf
fmt
"%s"
s
Open_File_Error
s
fprintf
fmt
"%s"
s
let
print_notify
fmt
n
match
n
@@ -413,9 +415,9 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
cont
c
Read and send file
File input/output
let
read_and_send
f
try
@@ -427,6 +429,18 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
Invalid_argument
s
P
notify
Message
Error
s
let
save_file
f
file_content
try
let
d
get_server_data
in
let
fn
Sysutil
absolutize_filename
Session_itp
get_dir
d
cont
controller_session
f
in
let
oc
open_out
fn
in
Printf
fprintf
oc
"%s
\n
file_content
(* TODO replace this *)
close_out
oc
P
notify
Message
File_Saved
f
Invalid_argument
s
P
notify
Message
Error
s
@@ -967,6 +981,8 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
C
copy_detached
copy
d
cont
from_any
Get_file_contents
f
read_and_send
f
Save_file_req
name
text
save_file
name
text
Get_task
nid
send_task
nid
Replay_req
replay_session
resend_the_tree
Command_req
nid
cmd
