Commit e3cfcd52 authored by Andrei Paskevich's avatar Andrei Paskevich
Introduction: "generalize_introduced" moves local premises back to the goal
See #151.
At the moment, this transformation is only integrated into TryWhy3,
in order to restore left-hand side splitting under vc:sp.
I suggest to integrate "generalize" into split_vc unconditionally.
I've tested that, the sessions were only broken for 4 examples:
  examples/tortoise_and_hare/
  examples/verifythis_2018_array_based_queuing_lock_2/
  examples/verifythis_2018_mind_the_gap_2/
  examples/multiprecision/toom/
parent d95b50c5
......@@ -74,9 +74,11 @@ let intro_var subst ({vs_name = id; vs_ty = ty} as vs) =
Mvs.add vs (fs_app ls [] ty) subst,
create_param_decl ls
let get_expls f =
Sattr.filter (fun a -> Strings.has_prefix "expl:" a.attr_string) f.t_attrs
let rec intros kn pr expl f =
let is_expl a = Strings.has_prefix "expl:" a.attr_string in
let fexpl = Sattr.filter is_expl f.t_attrs in
let fexpl = get_expls f in
let expl = if Sattr.is_empty fexpl then expl else fexpl in
let move_expl f = if Sattr.is_empty fexpl && not (Sattr.is_empty expl)
then t_attr_add (Sattr.min_elt expl) f else f in
......@@ -90,13 +92,13 @@ let rec intros kn pr expl f =
(* f is going to be removed, preserve its attributes and location in f2 *)
let f2 = t_attr_copy f f2 in
let fl = Split_goal.split_intro_right ?known_map:kn (dequant false f1) in
let idx = id_fresh "H" ~attrs:(Sattr.singleton intro_attr) in
let add (subst,dl) f =
let svs = Mvs.set_diff (t_freevars Mvs.empty f) subst in
let subst, dl = Mvs.fold (fun vs _ (subst,dl) ->
let subst, d = intro_var subst vs in
subst, d::dl) svs (subst, dl) in
let prx = create_prsymbol (id_fresh "H"
~attrs:(Sattr.singleton intro_attr)) in
let prx = create_prsymbol idx in
let d = create_prop_decl Paxiom prx (t_subst subst f) in
subst, d::dl in
let _, fl = List.fold_left add (Mvs.empty, []) fl in
......@@ -129,12 +131,57 @@ let introduce_premises = Trans.store (fun t ->
let known_map = Task.task_known t in
Trans.apply (Trans.goal (intros ~known_map)) t)
let () = Trans.register_transform "introduce_premises" introduce_premises
~desc:"Introduce@ universal@ quantification@ and@ hypothesis@ in@ the@ \
goal@ into@ constant@ symbol@ and@ axioms."
let generalize hd (pl, task) = match hd.Task.task_decl.Theory.td_node with
| Theory.Decl {d_node = Dprop (Pgoal,pr,f)} ->
if pl = [] then [], Some hd else
let expl = get_expls f in
let get_vs {ls_name = id; ls_value = oty} =
let attrs = Sattr.remove intro_attr id.id_attrs in
let id = id_fresh ~attrs ?loc:id.id_loc id.id_string in
create_vsymbol id (Opt.get oty) in
let set_vs vs ls f =
t_replace (t_app ls [] ls.ls_value) (t_var vs) f in
let rewind (vl,f) d = match d.d_node with
| Dparam ls ->
let v = get_vs ls in
v::vl, set_vs v ls f
| Dlogic [ls,ld] ->
let f = t_forall_close vl [] f in
let f = set_vs v ls f in
let _, h = Decl.open_ls_defn ld in
[], t_let_close v h f
| Dprop (Paxiom,_,h) ->
[], t_implies (t_attr_remove intro_attr h) f
| _ -> assert false (* never *) in
let vl, f = List.fold_left rewind ([],f) pl in
let f = if Sattr.is_empty expl then f else
t_attr_add (Sattr.min_elt expl) f in
[], Task.add_decl task (create_prop_decl Pgoal pr f)
| Theory.Decl ({d_node =
( Dparam {ls_name = id; ls_args = []; ls_value = Some _}
| Dlogic [{ls_name = id; ls_args = []; ls_value = Some _}, _]
| Dprop (Paxiom, {pr_name = id}, _))} as d)
when Sattr.mem intro_attr id.id_attrs -> d::pl, task
(* We only reattach the local premises right before the goal.
On the first non-local premise, we ignore the accumulator
and return the original task. We make an exception for
metas, as they are not checked against the known_map *)
| Theory.Meta _ -> pl, Task.add_tdecl task hd.Task.task_decl
| _ -> [], Some hd
let generalize_intro = Trans.fold_map generalize [] None
let () = Trans.register_transform "generalize_introduced" generalize_intro
~desc:"Move@ the@ premises@ introduced@ by@ \"introduce_premises\"@ back@ \
into@ the@ goal."
(** Destruction of existential quantifiers in axioms.
Contributed by Nicolas Jeannerod [niols@niols.fr] *)
......@@ -171,7 +218,9 @@ let simplify_intros =
introduce_premises
let split_vc =
Trans.compose_l Split_goal.split_goal_right (Trans.singleton simplify_intros)
Trans.compose_l (* TODO: decide whether we want generalize in split_vc *)
((* Trans.compose generalize_intro *) Split_goal.split_goal_right)
let () = Trans.register_transform_l
"split_vc" split_vc
......@@ -58,6 +58,9 @@ let () = log_time ("Initialising why3 worker: end ")
let split_trans = Trans.lookup_transform_l "split_vc" env
let split_trans = (* TODO: remove if generalize is integrated in split_vc *)
Trans.compose (Trans.lookup_transform "generalize_introduced" env) split_trans
(* CF gmain.ml ligne 568 et suivante *)
module W =
struct
