Commit e3b16af8 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Remove some obsolete conversions between machine integers and unbounded integers.
parent fc99841c
...@@ -90,25 +90,25 @@ module BinarySearchInt32 ...@@ -90,25 +90,25 @@ module BinarySearchInt32
exception Not_found (* raised to signal a search failure *) exception Not_found (* raised to signal a search failure *)
let binary_search (a : array int32) (v : int32) : int32 let binary_search (a : array int32) (v : int32) : int32
requires { forall i1 i2 : int. 0 <= i1 <= i2 < to_int a.length -> requires { forall i1 i2 : int. 0 <= i1 <= i2 < a.length ->
to_int a[i1] <= to_int a[i2] } a[i1] <= a[i2] }
ensures { 0 <= to_int result < to_int a.length /\ a[to_int result] = v } ensures { 0 <= result < a.length /\ a[result] = v }
raises { Not_found -> raises { Not_found ->
forall i:int. 0 <= i < to_int a.length -> a[i] <> v } forall i:int. 0 <= i < a.length -> a[i] <> v }
let l = ref (of_int 0) in let l = ref 0 in
let u = ref (length a - of_int 1) in let u = ref (length a - 1) in
while !l <= !u do while !l <= !u do
invariant { 0 <= to_int !l /\ to_int !u < to_int a.length } invariant { 0 <= !l /\ !u < a.length }
invariant { forall i : int. 0 <= i < to_int a.length -> invariant { forall i : int. 0 <= i < a.length ->
a[i] = v -> to_int !l <= i <= to_int !u } a[i] = v -> !l <= i <= !u }
variant { to_int !u - to_int !l } variant { !u - !l }
let m = !l + (!u - !l) / of_int 2 in let m = !l + (!u - !l) / 2 in
assert { to_int !l <= to_int m <= to_int !u }; assert { !l <= m <= !u };
if a[m] < v then if a[m] < v then
l := m + of_int 1 l := m + 1
else if a[m] > v then else if a[m] > v then
u := m - of_int 1 u := m - 1
else else
return m return m
done; done;
...@@ -14,9 +14,9 @@ ...@@ -14,9 +14,9 @@
<proof prover="3"><result status="valid" time="0.01" steps="63"/></proof> <proof prover="3"><result status="valid" time="0.01" steps="63"/></proof>
</goal> </goal>
</theory> </theory>
<theory name="BinarySearchInt32" proved="true" sum="909f26be7787adc1464e7f847a908692"> <theory name="BinarySearchInt32" proved="true" sum="189de117608870d3dac4a21f7234eef5">
<goal name="VC binary_search" expl="VC for binary_search" proved="true"> <goal name="VC binary_search" expl="VC for binary_search" proved="true">
<proof prover="3"><result status="valid" time="2.53" steps="3682"/></proof> <proof prover="3"><result status="valid" time="8.18" steps="11481"/></proof>
</goal> </goal>
</theory> </theory>
<theory name="BinarySearchBoolean" proved="true" sum="0022604a394766cd083f25712d0f873a"> <theory name="BinarySearchBoolean" proved="true" sum="0022604a394766cd083f25712d0f873a">
