GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
e35119d5
e35119d5
François Bobot
Ajout de petite fonction utile
2f93f077
4
src/util/sysutil.ml
e35119d5
@@ -39,6 +39,11 @@ let channel_contents_buf cin =
let
channel_contents
cin
Buffer
contents
cin
let
rec
fold_channel
f
acc
cin
try
fold_channel
f
f
acc
input_line
cin
cin
End_of_file
acc
let
file_contents_fmt
f
fmt
try
let
cin
open_in
f
in
src/util/sysutil.mli
e35119d5
@@ -26,6 +26,9 @@ val channel_contents_buf : in_channel -> Buffer.t
(* put the content of an in_channel in a formatter *)
val
channel_contents_fmt
in_channel
Format
formatter
unit
(* fold on the line of a file *)
val
fold_channel
a
string
a
a
in_channel
a
(* return the content of a file *)
val
file_contents
string
string
src/util/util.ml
e35119d5
@@ -59,6 +59,11 @@ let option_map_fold f acc x =
let
acc
x
f
acc
x
in
acc
Some
x
(* useful iterator on int *)
let
rec
foldi
f
acc
min
max
if
min
max
then
acc
else
foldi
f
f
acc
min
succ
min
max
let
rec
mapi
f
foldi
fun
acc
i
f
i
acc
(* useful list combinators *)
let
rev_map_fold_left
f
acc
l
src/util/util.mli
e35119d5
@@ -54,6 +54,10 @@ val option_eq : ('a -> 'b -> bool) -> 'a option -> 'b option -> bool
val
option_map_fold
a
b
a
b
a
b
option
a
b
option
(* useful int iterator *)
val
foldi
a
int
a
a
int
int
a
val
mapi
int
a
int
int
a
list
val
rev_map_fold_left
