Commit e27ff68e authored by Sylvain Dailler's avatar Sylvain Dailler
Update obsolete session
parent 8a19e02e
......@@ -300,7 +300,7 @@
<proof prover="5"><result status="valid" time="0.12"/></proof>
</goal>
<goal name="VC proof1.6.2" expl="VC for proof1" proved="true">
<proof prover="4"><result status="valid" time="1.32"/></proof>
<proof prover="4"><result status="valid" time="1.00"/></proof>
<proof prover="6"><result status="valid" time="0.04" steps="96"/></proof>
</goal>
</transf>
......@@ -269,7 +269,7 @@
<proof prover="12"><result status="valid" time="0.02"/></proof>
</goal>
<goal name="VC poke.5" expl="postcondition" proved="true">
<proof prover="12"><result status="valid" time="0.01"/></proof>
</goal>
<goal name="VC poke.6" expl="postcondition" proved="true">
......@@ -284,7 +284,7 @@
</goal>
<goal name="VC poke.10" expl="postcondition" proved="true">
</goal>
<goal name="VC poke.11" expl="precondition" proved="true">
<proof prover="12"><result status="valid" time="0.04"/></proof>
......@@ -293,13 +293,13 @@
</goal>
<goal name="VC poke.13" expl="loop invariant init" proved="true">
</goal>
<goal name="VC poke.14" expl="loop invariant init" proved="true">
</goal>
<goal name="VC poke.15" expl="loop invariant init" proved="true">
</goal>
<goal name="VC poke.16" expl="precondition" proved="true">
<proof prover="12"><result status="valid" time="0.03"/></proof>
......@@ -77,7 +77,7 @@
<proof prover="0"><result status="valid" time="0.04"/></proof>
</goal>
<goal name="VC counting_sort.21" expl="loop invariant preservation" proved="true">
<proof prover="0" timelimit="10" memlimit="4000"><result status="valid" time="0.86"/></proof>
<proof prover="0" timelimit="10" memlimit="4000"><result status="valid" time="1.12"/></proof>
</goal>
<goal name="VC counting_sort.22" expl="loop invariant preservation" proved="true">
<proof prover="1"><result status="valid" time="0.10" steps="204"/></proof>
......@@ -179,7 +179,7 @@
<proof prover="0"><result status="valid" time="0.03"/></proof>
</goal>
<goal name="VC in_place_counting_sort.22" expl="loop invariant preservation" proved="true">
<proof prover="0"><result status="valid" time="0.38"/></proof>
<proof prover="0"><result status="valid" time="0.53"/></proof>
</goal>
<goal name="VC in_place_counting_sort.23" expl="loop invariant preservation" proved="true">
<proof prover="1"><result status="valid" time="0.13" steps="234"/></proof>
......@@ -16,13 +16,13 @@
<proof prover="7"><result status="valid" time="0.02"/></proof>
</goal>
<goal name="VC relax.1" expl="postcondition" proved="true">
<proof prover="7"><result status="valid" time="0.04"/></proof>
<proof prover="7"><result status="valid" time="0.01"/></proof>
</goal>
<goal name="VC relax.2" expl="postcondition" proved="true">
</goal>
<goal name="VC relax.3" expl="postcondition" proved="true">
</goal>
</transf>
</goal>
......@@ -108,7 +108,7 @@
<proof prover="7"><result status="valid" time="0.03"/></proof>
</goal>
<goal name="VC shortest_path_code.6" expl="loop invariant init" proved="true">
<proof prover="2"><result status="valid" time="2.45"/></proof>
<proof prover="2"><result status="valid" time="3.78"/></proof>
<proof prover="5"><result status="valid" time="1.46"/></proof>
</goal>
<goal name="VC shortest_path_code.7" expl="loop invariant init" proved="true">
......@@ -157,7 +157,7 @@
</transf>
</goal>
<goal name="VC two_equal_elements.33" expl="loop invariant preservation" proved="true">
<proof prover="0"><result status="valid" time="0.70"/></proof>
<proof prover="0"><result status="valid" time="0.50"/></proof>
</goal>
<goal name="VC two_equal_elements.34" expl="postcondition" proved="true">
<proof prover="1"><result status="valid" time="0.04"/></proof>
......@@ -19,10 +19,10 @@
<goal name="size_left.0" proved="true">
<transf name="destruct_alg" proved="true" arg1="t">
<goal name="size_left.0.0" proved="true">
<proof prover="3"><result status="valid" time="0.01"/></proof>
<proof prover="3"><result status="valid" time="0.02"/></proof>
</goal>
<goal name="size_left.0.1" proved="true">
</goal>
</transf>
</goal>
