Commit e219bba9 authored by Asma Tafat-Bouzid's avatar Asma Tafat-Bouzid
Latex statistics
parent a28a0e84
This diff is collapsed.
...@@ -323,6 +323,11 @@ let rec provers_latex_stats provers g = ...@@ -323,6 +323,11 @@ let rec provers_latex_stats provers g =
let goals = tr.M.subgoals in let goals = tr.M.subgoals in
List.iter (provers_latex_stats provers) goals) tr List.iter (provers_latex_stats provers) goals) tr
let prover_name a =
match a with
M.Detected_prover d -> d.Session.prover_name ^ " " ^ d.Session.prover_version
| M.Undetected_prover s -> s
let rec goal_latex_stat n fmt prov depth depth_max first g = let rec goal_latex_stat n fmt prov depth depth_max first g =
if(n ==1) then begin if(n ==1) then begin
if not first then if not first then
...@@ -372,11 +377,6 @@ let rec goal_latex_stat n fmt prov depth depth_max first g = ...@@ -372,11 +377,6 @@ let rec goal_latex_stat n fmt prov depth depth_max first g =
() ) tr () ) tr
end end
let prover_name a =
match a with
let theory_latex_stat n dir t = let theory_latex_stat n dir t =
let provers = Hashtbl.create 9 in let provers = Hashtbl.create 9 in
List.iter (provers_latex_stats provers) (M.goals t); List.iter (provers_latex_stats provers) (M.goals t);
...@@ -391,7 +391,7 @@ let theory_latex_stat n dir t = ...@@ -391,7 +391,7 @@ let theory_latex_stat n dir t =
fprintf fmt "{| l |"; fprintf fmt "{| l |";
for i = 0 to (List.length provers) + depth do fprintf fmt "c |" done; for i = 0 to (List.length provers) + depth do fprintf fmt "c |" done;
fprintf fmt "} \n \\hline@."; fprintf fmt "} \n \\hline@.";
if (n == 1) then if (n == 1) then
fprintf fmt " \\multicolumn{%d}{|c|}{Proof obligations } " (depth + 1) fprintf fmt " \\multicolumn{%d}{|c|}{Proof obligations } " (depth + 1)
else else
fprintf fmt " Proof obligations "; fprintf fmt " Proof obligations ";
