Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit e132791e authored by Andrei Paskevich's avatar Andrei Paskevich
Dterm, Dexpr: allow destructible types for casts and constants
parent dbe55174
...@@ -103,6 +103,8 @@ let rec dty_unify dty1 dty2 = match dty1,dty2 with ...@@ -103,6 +103,8 @@ let rec dty_unify dty1 dty2 = match dty1,dty2 with
List.iter2 dty_unify dl1 dl2 List.iter2 dty_unify dl1 dl2
| _ -> raise Exit | _ -> raise Exit
let dty_int = Duty ty_int
let dty_real = Duty ty_real
let dty_bool = Duty ty_bool let dty_bool = Duty ty_bool
let protect_on x s = if x then "(" ^^ s ^^ ")" else s let protect_on x s = if x then "(" ^^ s ^^ ")" else s
...@@ -184,7 +186,7 @@ and dpattern_node = ...@@ -184,7 +186,7 @@ and dpattern_node =
| DPapp of lsymbol * dpattern list | DPapp of lsymbol * dpattern list
| DPor of dpattern * dpattern | DPor of dpattern * dpattern
| DPas of dpattern * preid | DPas of dpattern * preid
| DPcast of dpattern * ty | DPcast of dpattern * dty
type dbinop = type dbinop =
| DTand | DTand_asym | DTor | DTor_asym | DTimplies | DTiff | DTby | DTso | DTand | DTand_asym | DTor | DTor_asym | DTimplies | DTiff | DTby | DTso
...@@ -203,7 +205,7 @@ type dterm = { ...@@ -203,7 +205,7 @@ type dterm = {
and dterm_node = and dterm_node =
| DTvar of string * dty | DTvar of string * dty
| DTgvar of vsymbol | DTgvar of vsymbol
| DTconst of Number.constant * ty | DTconst of Number.constant * dty
| DTapp of lsymbol * dterm list | DTapp of lsymbol * dterm list
| DTfapp of dterm * dterm | DTfapp of dterm * dterm
| DTif of dterm * dterm * dterm | DTif of dterm * dterm * dterm
...@@ -215,7 +217,7 @@ and dterm_node = ...@@ -215,7 +217,7 @@ and dterm_node =
| DTnot of dterm | DTnot of dterm
| DTtrue | DTtrue
| DTfalse | DTfalse
| DTcast of dterm * ty | DTcast of dterm * dty
| DTuloc of dterm * Loc.position | DTuloc of dterm * Loc.position
| DTlabel of dterm * Slab.t | DTlabel of dterm * Slab.t
...@@ -317,8 +319,7 @@ let dpattern ?loc node = ...@@ -317,8 +319,7 @@ let dpattern ?loc node =
dp1.dp_dty, Mstr.union join dp1.dp_vars dp2.dp_vars dp1.dp_dty, Mstr.union join dp1.dp_vars dp2.dp_vars
| DPas (dp,{pre_name = n}) -> | DPas (dp,{pre_name = n}) ->
dp.dp_dty, Mstr.add_new (DuplicateVar n) n dp.dp_dty dp.dp_vars dp.dp_dty, Mstr.add_new (DuplicateVar n) n dp.dp_dty dp.dp_vars
| DPcast (dp,ty) -> | DPcast (dp,dty) ->
let dty = dty_of_ty ty in
dpat_expected_type dp dty; dpat_expected_type dp dty;
dty, dp.dp_vars in dty, dp.dp_vars in
let dty, vars = Loc.try1 ?loc get_dty node in let dty, vars = Loc.try1 ?loc get_dty node in
...@@ -395,8 +396,8 @@ let dterm tuc ?loc node = ...@@ -395,8 +396,8 @@ let dterm tuc ?loc node =
mk_dty (Some dty) mk_dty (Some dty)
| DTgvar vs -> | DTgvar vs ->
mk_dty (Some (dty_of_ty vs.vs_ty)) mk_dty (Some (dty_of_ty vs.vs_ty))
| DTconst (_,ty) -> | DTconst (_,dty) ->
mk_dty (Some (dty_of_ty ty)) mk_dty (Some dty)
| DTapp (ls, dtl) when ls_equal ls ps_equ -> | DTapp (ls, dtl) when ls_equal ls ps_equ ->
let swap, dtl = let swap, dtl =
match dtl with match dtl with
...@@ -490,8 +491,7 @@ let dterm tuc ?loc node = ...@@ -490,8 +491,7 @@ let dterm tuc ?loc node =
there is no need to count these constructs as "formulas" which there is no need to count these constructs as "formulas" which
require explicit if-then-else conversion to bool *) require explicit if-then-else conversion to bool *)
mk_dty (Some dty_bool) mk_dty (Some dty_bool)
| DTcast (dt,ty) -> | DTcast (dt,dty) ->
dterm_expected_dterm tuc dt dty dterm_expected_dterm tuc dt dty
| DTuloc (dt,_) | DTuloc (dt,_)
| DTlabel (dt,_) -> | DTlabel (dt,_) ->
...@@ -606,8 +606,8 @@ and try_term strict keep_loc uloc env prop dty node = ...@@ -606,8 +606,8 @@ and try_term strict keep_loc uloc env prop dty node =
t_var (Mstr.find_exn (UnboundVar n) n env) t_var (Mstr.find_exn (UnboundVar n) n env)
t_var vs t_var vs
| DTconst (c,ty) -> | DTconst (c,dty) ->
t_const c ty t_const c (term_ty_of_dty ~strict dty)
| DTapp (ls,[]) when ls_equal ls fs_bool_true -> | DTapp (ls,[]) when ls_equal ls fs_bool_true ->
if prop then t_true else t_bool_true if prop then t_true else t_bool_true
| DTapp (ls,[]) when ls_equal ls fs_bool_false -> | DTapp (ls,[]) when ls_equal ls fs_bool_false ->
...@@ -28,6 +28,8 @@ val dty_app : tysymbol -> dty list -> dty ...@@ -28,6 +28,8 @@ val dty_app : tysymbol -> dty list -> dty
val dty_match : dty -> ty -> unit (* raises Exit on failure *) val dty_match : dty -> ty -> unit (* raises Exit on failure *)
val dty_unify : dty -> dty -> unit (* raises Exit on failure *) val dty_unify : dty -> dty -> unit (* raises Exit on failure *)
val dty_int : dty
val dty_real : dty
val dty_bool : dty val dty_bool : dty
val dty_fold : (tysymbol -> 'a list -> 'a) -> val dty_fold : (tysymbol -> 'a list -> 'a) ->
...@@ -48,7 +50,7 @@ and dpattern_node = ...@@ -48,7 +50,7 @@ and dpattern_node =
...@@ -67,7 +69,7 @@ type dterm = private { ...@@ -67,7 +69,7 @@ type dterm = private {
...@@ -79,7 +81,7 @@ and dterm_node = ...@@ -79,7 +81,7 @@ and dterm_node =
| DTtrue | DTtrue
| DTfalse | DTfalse
...@@ -362,7 +362,7 @@ type dpattern_node = ...@@ -362,7 +362,7 @@ type dpattern_node =
| DPapp of rsymbol * dpattern list | DPapp of rsymbol * dpattern list
| DPas of dpattern * preid * bool | DPas of dpattern * preid * bool
| DPcast of dpattern * ity | DPcast of dpattern * dity
(** Specifications *) (** Specifications *)
...@@ -618,7 +618,7 @@ let drec_defn denv0 prel = ...@@ -618,7 +618,7 @@ let drec_defn denv0 prel =
denv_add_rec denv denv0.frozen id (argl,res) in denv_add_rec denv denv0.frozen id (argl,res) in
let denv1 = List.fold_left add denv0 prel in let denv1 = List.fold_left add denv0 prel in
let parse (id,gh,pk,bl,res,msk,pre) = let parse (id,gh,pk,bl,res,msk,pre) =
let dsp, dvl, de = pre (denv_add_args denv1 bl) in let dsp, dvl, de = pre denv1 in
dexpr_expected_type de res; dexpr_expected_type de res;
(id,gh,pk,bl,res,msk,dsp,dvl,de) in (id,gh,pk,bl,res,msk,dsp,dvl,de) in
let fdl = List.map parse prel in let fdl = List.map parse prel in
...@@ -668,8 +668,8 @@ let dpattern ?loc node = ...@@ -668,8 +668,8 @@ let dpattern ?loc node =
let { dp_pat = pat; dp_dity = dity; dp_vars = vars } = dp in let { dp_pat = pat; dp_dity = dity; dp_vars = vars } = dp in
let vars = Mstr.add_new (Dterm.DuplicateVar n) n dity vars in let vars = Mstr.add_new (Dterm.DuplicateVar n) n dity vars in
mk_dpat (PPas (pat, id, gh)) dity vars mk_dpat (PPas (pat, id, gh)) dity vars
| DPcast (dp, ity) -> | DPcast (dp, dity) ->
dpat_expected_type dp (dity_of_ity ity); dpat_expected_type dp dity;
dp dp
in in
Loc.try1 ?loc dpat node Loc.try1 ?loc dpat node
...@@ -46,7 +46,7 @@ type dpattern_node = ...@@ -46,7 +46,7 @@ type dpattern_node =
(** Binders *) (** Binders *)
...@@ -131,6 +131,13 @@ let ty_of_pty tuc pty = ...@@ -131,6 +131,13 @@ let ty_of_pty tuc pty =
in in
get_ty pty get_ty pty
let dty_of_pty tuc pty =
Dterm.dty_of_ty (ty_of_pty tuc pty)
let dty_of_opt tuc = function
| Some pty -> dty_of_pty tuc pty
| None -> Dterm.dty_fresh ()
let ity_of_pty muc pty = let ity_of_pty muc pty =
let rec get_ity = function let rec get_ity = function
| PTtyvar {id_str = x} -> | PTtyvar {id_str = x} ->
...@@ -150,6 +157,13 @@ let ity_of_pty muc pty = ...@@ -150,6 +157,13 @@ let ity_of_pty muc pty =
in in
get_ity pty get_ity pty
let dity_of_pty muc pty =
Dexpr.dity_of_ity (ity_of_pty muc pty)
let dity_of_opt muc = function
| Some pty -> dity_of_pty muc pty
| None -> Dexpr.dity_fresh ()
(** typing using destructive type variables (** typing using destructive type variables
parsed trees intermediate trees typed trees parsed trees intermediate trees typed trees
...@@ -191,16 +205,13 @@ let rec dpattern tuc { pat_desc = desc; pat_loc = loc } = ...@@ -191,16 +205,13 @@ let rec dpattern tuc { pat_desc = desc; pat_loc = loc } =
DPapp (cs,fl) DPapp (cs,fl)
| Ptree.Pas (p, x, false) -> DPas (dpattern tuc p, create_user_id x) | Ptree.Pas (p, x, false) -> DPas (dpattern tuc p, create_user_id x)
| Ptree.Por (p, q) -> DPor (dpattern tuc p, dpattern tuc q) | Ptree.Por (p, q) -> DPor (dpattern tuc p, dpattern tuc q)
| Ptree.Pcast (p, ty) -> DPcast (dpattern tuc p, ty_of_pty tuc ty) | Ptree.Pcast (p, ty) -> DPcast (dpattern tuc p, dty_of_pty tuc ty)
| Ptree.Pvar (_, true) | Ptree.Pas (_, _, true) -> Loc.errorm ~loc | Ptree.Pvar (_, true) | Ptree.Pas (_, _, true) -> Loc.errorm ~loc
"ghost variables are only allowed in programs") "ghost variables are only allowed in programs")
let quant_var tuc (loc, id, gh, ty) = let quant_var tuc (loc, id, gh, ty) =
if gh then Loc.errorm ~loc "ghost variables are only allowed in programs"; if gh then Loc.errorm ~loc "ghost variables are only allowed in programs";
let ty = match ty with Opt.map create_user_id id, dty_of_opt tuc ty, Some loc
| Some ty -> dty_of_ty (ty_of_pty tuc ty)
| None -> dty_fresh () in
Opt.map create_user_id id, ty, Some loc
let loc_cutoff loc13 loc23 loc2 = let loc_cutoff loc13 loc23 loc2 =
let f,l,b,e = Loc.get loc13 in let f,l,b,e = Loc.get loc13 in
...@@ -293,9 +304,9 @@ let rec dterm tuc gvars at denv {term_desc = desc; term_loc = loc} = ...@@ -293,9 +304,9 @@ let rec dterm tuc gvars at denv {term_desc = desc; term_loc = loc} =
apply loc de1 op1 (dterm tuc gvars at denv e23) in apply loc de1 op1 (dterm tuc gvars at denv e23) in
chain loc (dterm tuc gvars at denv e1) op1 e23 chain loc (dterm tuc gvars at denv e1) op1 e23
| Ptree.Tconst (Number.ConstInt _ as c) -> | Ptree.Tconst (Number.ConstInt _ as c) ->
DTconst (c, ty_int) DTconst (c, dty_int)
| Ptree.Tconst (Number.ConstReal _ as c) -> | Ptree.Tconst (Number.ConstReal _ as c) ->
DTconst (c, ty_real) DTconst (c, dty_real)
| Ptree.Tlet (x, e1, e2) -> | Ptree.Tlet (x, e1, e2) ->
let id = create_user_id x in let id = create_user_id x in
let e1 = dterm tuc gvars at denv e1 in let e1 = dterm tuc gvars at denv e1 in
...@@ -370,12 +381,10 @@ let rec dterm tuc gvars at denv {term_desc = desc; term_loc = loc} = ...@@ -370,12 +381,10 @@ let rec dterm tuc gvars at denv {term_desc = desc; term_loc = loc} =
| Ptree.Tnamed (Lstr lab, e1) -> | Ptree.Tnamed (Lstr lab, e1) ->
DTlabel (dterm tuc gvars at denv e1, Slab.singleton lab) DTlabel (dterm tuc gvars at denv e1, Slab.singleton lab)
| Ptree.Tcast ({term_desc = Ptree.Tconst c}, pty) -> | Ptree.Tcast ({term_desc = Ptree.Tconst c}, pty) ->
let ty = ty_of_pty tuc pty in DTconst (c, dty_of_pty tuc pty)
DTconst (c, ty)
| Ptree.Tcast (e1, pty) -> | Ptree.Tcast (e1, pty) ->
let d1 = dterm tuc gvars at denv e1 in let d1 = dterm tuc gvars at denv e1 in
let ty = ty_of_pty tuc pty in DTcast (d1, dty_of_pty tuc pty))
DTcast (d1, ty))
(** typing program expressions *) (** typing program expressions *)
...@@ -435,7 +444,7 @@ let rec dpattern muc { pat_desc = desc; pat_loc = loc } = ...@@ -435,7 +444,7 @@ let rec dpattern muc { pat_desc = desc; pat_loc = loc } =
| Ptree.Ptuple pl -> | Ptree.Ptuple pl ->
DPapp (rs_tuple (List.length pl), List.map (dpattern muc) pl) DPapp (rs_tuple (List.length pl), List.map (dpattern muc) pl)
| Ptree.Pcast (p, pty) -> DPcast (dpattern muc p, ity_of_pty muc pty) | Ptree.Pcast (p, pty) -> DPcast (dpattern muc p, dity_of_pty muc pty)
| Ptree.Pas (p, x, gh) -> DPas (dpattern muc p, create_user_id x, gh) | Ptree.Pas (p, x, gh) -> DPas (dpattern muc p, create_user_id x, gh)
| Ptree.Por (p, q) -> DPor (dpattern muc p, dpattern muc q)) | Ptree.Por (p, q) -> DPor (dpattern muc p, dpattern muc q))
...@@ -543,16 +552,11 @@ let dinvariant muc f lvm _xsm old = dpre muc f lvm old ...@@ -543,16 +552,11 @@ let dinvariant muc f lvm _xsm old = dpre muc f lvm old
(* abstract values *) (* abstract values *)
let dbinder muc id gh pty = let dparam muc (_,id,gh,pty) =
let id = Opt.map create_user_id id in Opt.map create_user_id id, gh, dity_of_pty muc pty
let dity = match pty with
| Some pty -> dity_of_ity (ity_of_pty muc pty)
| None -> dity_fresh () in
id, gh, dity
let dparam muc (_,id,gh,pty) = dbinder muc id gh (Some pty) let dbinder muc (_,id,gh,opt) =
Opt.map create_user_id id, gh, dity_of_opt muc opt
let dbinder muc (_,id,gh,pty) = dbinder muc id gh pty
(* expressions *) (* expressions *)
...@@ -669,10 +673,8 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} = ...@@ -669,10 +673,8 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} =
| ({term_loc = loc},_)::_ -> | ({term_loc = loc},_)::_ ->
Loc.errorm ~loc "unexpected 'variant' clause" Loc.errorm ~loc "unexpected 'variant' clause"
| _ -> dspec muc sp in | _ -> dspec muc sp in
let dity = dity_of_opt muc pty in
let denv = denv_add_args denv bl in let denv = denv_add_args denv bl in
let denv = denv_add_exn denv old_mark_id dity in let denv = denv_add_exn denv old_mark_id dity in
DEfun (bl, dity, msk, ds, dexpr muc denv e) DEfun (bl, dity, msk, ds, dexpr muc denv e)
| Ptree.Eany (pl, kind, pty, msk, sp) -> | Ptree.Eany (pl, kind, pty, msk, sp) ->
...@@ -758,7 +760,7 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} = ...@@ -758,7 +760,7 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} =
DEghost (dexpr muc denv e1) DEghost (dexpr muc denv e1)
| Ptree.Eexn (id, pty, mask, e1) -> | Ptree.Eexn (id, pty, mask, e1) ->
let id = create_user_id id in let id = create_user_id id in
let dity = dity_of_ity (ity_of_pty muc pty) in let dity = dity_of_pty muc pty in
let denv = denv_add_exn denv id dity in let denv = denv_add_exn denv id dity in
DEexn (id, dity, mask, dexpr muc denv e1) DEexn (id, dity, mask, dexpr muc denv e1)
| Ptree.Eabsurd -> | Ptree.Eabsurd ->
...@@ -783,21 +785,18 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} = ...@@ -783,21 +785,18 @@ let rec dexpr muc denv {expr_desc = desc; expr_loc = loc} =
| Ptree.Enamed (Lstr lab, e1) -> | Ptree.Enamed (Lstr lab, e1) ->
DElabel (dexpr muc denv e1, Slab.singleton lab) DElabel (dexpr muc denv e1, Slab.singleton lab)
| Ptree.Ecast ({expr_desc = Ptree.Econst c}, pty) -> | Ptree.Ecast ({expr_desc = Ptree.Econst c}, pty) ->
let ity = ity_of_pty muc pty in DEconst (c, dity_of_pty muc pty)
DEconst (c, dity_of_ity ity)
| Ptree.Ecast (e1, pty) -> | Ptree.Ecast (e1, pty) ->
let d1 = dexpr muc denv e1 in let d1 = dexpr muc denv e1 in
let ity = ity_of_pty muc pty in DEcast (d1, dity_of_pty muc pty)
DEcast (d1, dity_of_ity ity)
end end
and drec_defn muc denv fdl = and drec_defn muc denv fdl =
let prep (id, gh, kind, bl, pty, msk, sp, e) = let prep (id, gh, kind, bl, pty, msk, sp, e) =
let bl = List.map (dbinder muc) bl in let bl = List.map (dbinder muc) bl in
let dity = match pty with let dity = dity_of_opt muc pty in
let pre denv = let pre denv =
let dv = dvariant muc sp.sp_variant in let dv = dvariant muc sp.sp_variant in
dspec muc sp, dv, dexpr muc denv e in dspec muc sp, dv, dexpr muc denv e in
