Commit e12880ca authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
slightly more robust detection of PVS
parent 82b3fb69
...@@ -466,15 +466,15 @@ else ...@@ -466,15 +466,15 @@ else
PVSVERSION=`$PVS -version | sed -n -e 's|.*Version* *\([[^ ]]*\)$|\1|p' ` PVSVERSION=`$PVS -version | sed -n -e 's|.*Version* *\([[^ ]]*\)$|\1|p' `
case $PVSVERSION in case $PVSVERSION in
2.*|3.*|4.*|5.*) 6.*)
enable_pvs_support=yes
AC_MSG_RESULT($PVSVERSION) AC_MSG_RESULT($PVSVERSION)
enable_pvs_support=no
AC_MSG_WARN(You need PVS 6.0 or higher; PVS discarded)
reason_pvs_support=" (need version 6.0 or higher)"
esac esac
fi fi
