Commit e05064c1 authored by Simon Cruanes's avatar Simon Cruanes
small change for apidoc
gitignore updated (vim swap files and .svn dirs)
bug corrected in explicit_polymorphism for formulae translation
parent 84ab8931
*.o *.o
*.svn
.*.swp
/config.status /config.status
/config.log /config.log
...@@ -619,7 +619,7 @@ clean:: ...@@ -619,7 +619,7 @@ clean::
apidoc: apidoc:
mkdir -p apidoc mkdir -p apidoc
$(OCAMLDOC) -d apidoc -html -I src $(LIBINCLUDES) -I +sqlite3 \ $(OCAMLDOC) -d apidoc -html -keep-code -I src $(LIBINCLUDES) -I +sqlite3 \
$(LIBML) $(LIBMLI) $(MNGML) $(MNGMLI) $(LIBML) $(LIBMLI) $(MNGML) $(MNGMLI)
clean:: clean::
...@@ -141,14 +141,13 @@ module Utils = struct ...@@ -141,14 +141,13 @@ module Utils = struct
to types in [right]. [tv_to_ty] is a mapping given in argument. to types in [right]. [tv_to_ty] is a mapping given in argument.
It must be compliant with the unification between [left] and [right] *) It must be compliant with the unification between [left] and [right] *)
let rec find_matching_vars tv_to_ty left right = let rec find_matching_vars tv_to_ty left right =
assert (List.length left = List.length right); Format.eprintf "matching @[%a@] with @[%a@]@."
(* Format.eprintf "matching @[%a@] with @[%a@]@."
(Debug.print_list Pretty.print_ty) left (Debug.print_list Pretty.print_ty) left
(Debug.print_list Pretty.print_ty) right; *) (Debug.print_list Pretty.print_ty) right;
let tv_to_ty = List.fold_left2 ty_match tv_to_ty left right in let tv_to_ty = List.fold_left2 ty_match tv_to_ty left right in
(* Format.eprintf "gives @[%a@]@." (* Format.eprintf "gives @[%a@]@."
(Debug.print_mtv Pretty.print_ty) tv_to_ty; *) (Debug.print_mtv Pretty.print_ty) tv_to_ty; flush stderr; *)
flush stderr;
tv_to_ty tv_to_ty
module Mint = Map.Make(struct module Mint = Map.Make(struct
...@@ -249,11 +248,12 @@ module Transform = struct ...@@ -249,11 +248,12 @@ module Transform = struct
(* Debug.print_list Pretty.print_ty Format.std_formatter type_vars; *) (* Debug.print_list Pretty.print_ty Format.std_formatter type_vars; *)
let int_to_tyvars = bind_nums_to_type_vars new_f in let int_to_tyvars = bind_nums_to_type_vars new_f in
(* match types *) (* match types *)
let result_to_match = fromSome new_f.ls_value in
let args_to_match = drop (List.length type_vars) new_f.ls_args in let args_to_match = drop (List.length type_vars) new_f.ls_args in
let concrete_ty = List.map (fun x-> x.t_ty) terms in let concrete_ty = List.map (fun x-> x.t_ty) terms in
let result_ty = t.t_ty in
let tv_to_ty = find_matching_vars tv_to_ty let tv_to_ty = find_matching_vars tv_to_ty
(result_to_match :: args_to_match) (t.t_ty :: concrete_ty) in (result_to_match :: args_to_match) (result_ty :: concrete_ty) in
(* Debug.print_mtv Pretty.print_ty Format.err_formatter tv_to_ty; *) (* Debug.print_mtv Pretty.print_ty Format.err_formatter tv_to_ty; *)
(* fresh terms to be added at the beginning of the list of arguments *) (* fresh terms to be added at the beginning of the list of arguments *)
let new_ty_int = range (List.length type_vars) in let new_ty_int = range (List.length type_vars) in
...@@ -263,13 +263,34 @@ module Transform = struct ...@@ -263,13 +263,34 @@ module Transform = struct
(term_transform tblT tblL varM tv_to_ty) terms in (term_transform tblT tblL varM tv_to_ty) terms in
let transformed_result = ty_to_ty tv_to_ty (fromSome new_f.ls_value) in let transformed_result = ty_to_ty tv_to_ty (fromSome new_f.ls_value) in
t_app new_f (new_terms @ transformed_terms) transformed_result t_app new_f (new_terms @ transformed_terms) transformed_result
| _ -> (* default case : traverse *) | _ -> (* default case : traverse *)
t_map (term_transform tblT tblL varM tv_to_ty) t_map (term_transform tblT tblL varM tv_to_ty)
(fmla_transform tblT tblL varM tv_to_ty) t (fmla_transform tblT tblL varM tv_to_ty) t
(** (trivial) translation of formulae *) (** (trivial) translation of formulae *)
and fmla_transform tblT tblL varM tv_to_ty f = f_map and fmla_transform tblT tblL varM tv_to_ty f = match f.f_node with
(term_transform tblT tblL varM tv_to_ty) | Fapp(p,terms) when (not (ls_equal p ps_equ)) && not(ls_equal p ps_neq) ->
(fmla_transform tblT tblL varM tv_to_ty) f let new_p = findL tblL p in
(* first, remember an order for type vars of new_f *)
let type_vars = l_find_type_vars new_p in
let int_to_tyvars = bind_nums_to_type_vars new_p in
(* match types *)
let args_to_match = drop (List.length type_vars) new_p.ls_args in
args_to_match concrete_ty in
let new_ty = List.map (fun x -> Mint.find x int_to_tyvars) new_ty_int in
let new_terms = List.map (ty_to_term tblT varM tv_to_ty) new_ty in
let transformed_terms = List.map
f_app new_p (new_terms @ transformed_terms)
| _ ->
f_map (term_transform tblT tblL varM tv_to_ty)
(** transforms a list of logic declarations into another. (** transforms a list of logic declarations into another.
...@@ -325,14 +346,14 @@ end ...@@ -325,14 +346,14 @@ end
symbols) and a declaration, and returns the corresponding declaration in symbols) and a declaration, and returns the corresponding declaration in
explicit polymorphism logic. *) explicit polymorphism logic. *)
let decl_transform tblT tblL d = let decl_transform tblT tblL d =
(* Format.eprintf "%a@." Pretty.print_decl d; *) Format.eprintf "%a@." Pretty.print_decl d;
let result = match d.d_node with let result = match d.d_node with
| Dind _inds -> | Dind _inds ->
failwith "Dind : should not have inductives declarations at this point !" failwith "Dind : should not have inductives declarations at this point !"
| Dtype tys -> Transform.type_transform tblT tys | Dtype tys -> Transform.type_transform tblT tys
| Dlogic decls -> Transform.logic_transform tblL decls | Dlogic decls -> Transform.logic_transform tblL decls
| Dprop prop -> Transform.prop_transform tblT tblL prop in | Dprop prop -> Transform.prop_transform tblT tblL prop in
(* Format.eprintf "===@.%a@.@." (Debug.print_list Pretty.print_decl) result;*) Format.eprintf "===@.%a@.@." (Debug.print_list Pretty.print_decl) result;
result result
