No commit message
No commit message
parent 99cfd834
;; why.el - GNU Emacs mode for Why
;; Copyright (C) 2002 Jean-Christophe FILLIATRE
(defvar why-mode-hook nil)
(defvar why-mode-map nil
"Keymap for Why major mode")
(if why-mode-map nil
(setq why-mode-map (make-keymap))
(define-key why-mode-map "\C-c\C-c" 'why-generate-obligations)
(define-key why-mode-map "\C-c\C-a" 'why-find-alternate-file)
(define-key why-mode-map "\C-c\C-v" 'why-viewer)
(define-key why-mode-map [(control return)] 'font-lock-fontify-buffer))
(setq auto-mode-alist
(append
'(("\\.mlw" . why-mode))
auto-mode-alist))
;; font-lock
(defun why-regexp-opt (l)
(concat "\\<" (concat (regexp-opt l t) "\\>")))
(defconst why-font-lock-keywords-1
(list
'("(\\*\\([^*]\\|\\*[^)]\\)*\\*)" . font-lock-comment-face)
'("{\\([^}]*\\)}" . font-lock-type-face)
`(,(why-regexp-opt '("include" "inductive" "external" "logic" "parameter" "exception" "axiom" "predicate" "function" "goal" "type")) . font-lock-builtin-face)
`(,(why-regexp-opt '("let" "rec" "in" "if" "then" "else" "begin" "end" "while" "do" "done" "label" "assert" "try" "with" "theory")) . font-lock-keyword-face)
; `(,(why-regexp-opt '("unit" "bool" "int" "float" "prop" "array")) . font-lock-type-face)
"Minimal highlighting for Why mode")
(defvar why-font-lock-keywords why-font-lock-keywords-1
"Default highlighting for Why mode")
;; syntax
(defvar why-mode-syntax-table nil
"Syntax table for why-mode")
(defun why-create-syntax-table ()
(if why-mode-syntax-table
(setq why-mode-syntax-table (make-syntax-table))
(set-syntax-table why-mode-syntax-table)
(modify-syntax-entry ?' "w" why-mode-syntax-table)
(modify-syntax-entry ?_ "w" why-mode-syntax-table)))
;; utility functions
(defun why-go-and-get-next-proof ()
(let ((bp (search-forward "Proof." nil t)))
(if (null bp) (progn (message "Cannot find a proof below") nil)
(let ((bs (re-search-forward "Save\\|Qed\\." nil t)))
(if (null bs) (progn (message "Cannot find a proof below") nil)
(if (> bs (+ bp 6))
(let ((br (+ bp 1))
(er (progn (goto-char bs) (beginning-of-line) (point))))
(progn (kill-region br er) t))
(why-go-and-get-next-proof)))))))
(defun why-grab-next-proof ()
"grab the next non-empty proof below and insert it at current point"
(interactive)
(if (save-excursion (why-go-and-get-next-proof)) (yank)))
;; custom variables
(require 'custom)
(defcustom why-prover "coq"
"Why prover"
:group 'why :type '(choice (const :tag "Coq" "coq")
(const :tag "PVS" "pvs")))
(defcustom why-prog-name "why"
"Why executable name"
:group 'why :type 'string)
(defcustom why-options "--valid"
"Why options"
(defcustom why-viewer-prog-name "why_viewer"
"Why viewer executable name"
(defun why-command-line (file)
(concat why-prog-name " -" why-prover " " why-options " " file))
(defun why-find-alternate-file ()
"switch to the proof obligations buffer"
(interactive)
(let* ((f (buffer-file-name))
(fcoq (concat (file-name-sans-extension f) "_why.v")))
(find-file fcoq)))
(defun why-generate-obligations ()
"generate the proof obligations"
(interactive)
(let ((f (buffer-name)))
(compile (why-command-line f))))
(defun why-viewer-command-line (file)
(concat why-viewer-prog-name " " file))
(defun why-viewer ()
"launch the why viewer"
(interactive)
(compile (why-viewer-command-line f))))
(defun why-generate-ocaml ()
"generate the ocaml code"
(interactive)
(compile (concat why-prog-name " --ocaml " f))))
;; menu
(require 'easymenu)
(defun why-menu ()
(easy-menu-define
why-mode-menu (list why-mode-map)
"Why Mode Menu."
'("Why"
["Customize Why mode" (customize-group 'why) t]
["Type-check buffer" why-type-check t]
; ["Show WP" why-show-wp t]
["Why viewer" why-viewer t]
["Generate obligations" why-generate-obligations t]
["Switch to obligations buffer" why-find-alternate-file t]
["Generate Ocaml code" why-generate-ocaml t]
["Recolor buffer" font-lock-fontify-buffer t]
"Coq"
["Grab next proof" why-grab-next-proof t]
"PVS"
(easy-menu-add why-mode-menu))
;; setting the mode
(defun why-mode ()
"Major mode for editing Why programs.
\\{why-mode-map}"
(interactive)
(kill-all-local-variables)
(why-create-syntax-table)
; hilight
(make-local-variable 'font-lock-defaults)
(setq font-lock-defaults '(why-font-lock-keywords))
; indentation
; (make-local-variable 'indent-line-function)
; (setq indent-line-function 'why-indent-line)
; menu
; providing the mode
(setq major-mode 'why-mode)
(setq mode-name "WHY")
(use-local-map why-mode-map)
(font-lock-mode 1)
(why-menu)
(run-hooks 'why-mode-hook))
(provide 'why-mode)
...@@ -83,10 +83,12 @@ ...@@ -83,10 +83,12 @@
"ref", REF; "ref", REF;
"returns", RETURNS; "returns", RETURNS;
"then", THEN; "then", THEN;
"theory", THEORY;
"true", TRUE; "true", TRUE;
"try", TRY; "try", TRY;
"type", TYPE; "type", TYPE;
"unit", UNIT; "unit", UNIT;
"uses", USES;
"variant", VARIANT; "variant", VARIANT;
"void", VOID; "void", VOID;
"while", WHILE; "while", WHILE;
...@@ -37,7 +37,7 @@ let () = ...@@ -37,7 +37,7 @@ let () =
Loc.set_file file lb; Loc.set_file file lb;
let f = Lexer.parse_logic_file lb in let f = Lexer.parse_logic_file lb in
close_in c; close_in c;
ignore (List.fold_left Typing.add Typing.empty f) ignore (Typing.add_decls Typing.empty f)
with e -> with e ->
eprintf "%a@." report e; eprintf "%a@." report e;
exit 1 exit 1
...@@ -101,7 +101,7 @@ ...@@ -101,7 +101,7 @@
%token QUOTE RAISE RAISES READS REAL REC REF RETURNS RIGHTB RIGHTBRIGHTB %token QUOTE RAISE RAISES READS REAL REC REF RETURNS RIGHTB RIGHTBRIGHTB
%token RIGHTPAR RIGHTSQ %token RIGHTPAR RIGHTSQ
%token SEMICOLON SLASH %token SEMICOLON SLASH
%token THEN TIMES TRUE TRY TYPE UNIT VARIANT VOID WHILE WITH WRITES %token THEN THEORY TIMES TRUE TRY TYPE UNIT USES VARIANT VOID WHILE WITH WRITES
/* Precedences */ /* Precedences */
...@@ -147,6 +147,8 @@ ...@@ -147,6 +147,8 @@
logic_file: logic_file:
| list1_decl EOF | list1_decl EOF
{ $1 } { $1 }
| list1_theory EOF
{ $1 }
| EOF | EOF
...@@ -158,6 +160,13 @@ list1_decl: ...@@ -158,6 +160,13 @@ list1_decl:
{ $1 :: $2 } { $1 :: $2 }
list0_decl:
| /* epsilon */
| list1_decl
{ $1 }
decl: decl:
| external_ LOGIC list1_ident_sep_comma COLON logic_type | external_ LOGIC list1_ident_sep_comma COLON logic_type
{ Logic (loc_i 3, $1, $3, $5) } { Logic (loc_i 3, $1, $3, $5) }
...@@ -178,6 +187,24 @@ decl: ...@@ -178,6 +187,24 @@ decl:
{ let loc, vl, id = $2 in $3 loc vl id } { let loc, vl, id = $2 in $3 loc vl id }
list1_theory:
| theory
{ [$1] }
| theory list1_theory
{ $1 :: $2 }
theory:
| THEORY ident uses list0_decl END { Theory (loc (), $2, $3, $4) }
uses:
| /* epsilon */
| USES list1_ident_sep_comma
{ $2 }
typedecl: typedecl:
| ident | ident
{ (loc_i 1, [], $1) } { (loc_i 1, [], $1) }
...@@ -72,6 +72,8 @@ type plogic_type = ...@@ -72,6 +72,8 @@ type plogic_type =
| PPredicate of ppure_type list | PPredicate of ppure_type list
| PFunction of ppure_type list * ppure_type | PFunction of ppure_type list * ppure_type
type uses = string
type logic_decl = type logic_decl =
| Logic of loc * external_ * string list * plogic_type | Logic of loc * external_ * string list * plogic_type
| Predicate_def of loc * string * (loc * string * ppure_type) list * lexpr | Predicate_def of loc * string * (loc * string * ppure_type) list * lexpr
...@@ -83,5 +85,6 @@ type logic_decl = ...@@ -83,5 +85,6 @@ type logic_decl =
| TypeDecl of loc * external_ * string list * string | TypeDecl of loc * external_ * string list * string
| AlgType of (loc * string list * string | AlgType of (loc * string list * string
* (loc * string * ppure_type list) list) list * (loc * string * ppure_type list) list) list
| Theory of loc * string * uses list * logic_decl list
type logic_file = logic_decl list type logic_file = logic_decl list
(* test file *) (* test file *)
type 'a list theory test
logic nil : 'a list
logic cons : 'a, 'a list -> 'a list
type int
logic length : 'a list -> int
logic is_nil : 'a list -> prop
logic eq : 'a, 'a -> prop
axiom a : forall x : 'a. not eq(nil, cons(x, nil))
type 'a list
logic nil : 'a list
type int
axiom a : forall x : 'a. not eq(nil, cons(nil, nil))
theory test2
type elt
type t
logic add : elt, t -> t
...@@ -34,6 +34,7 @@ type error = ...@@ -34,6 +34,7 @@ type error =
| TermExpectedType of (formatter -> unit) * (formatter -> unit) | TermExpectedType of (formatter -> unit) * (formatter -> unit)
(* actual / expected *) (* actual / expected *)
| BadNumberOfArguments of Name.t * int * int | BadNumberOfArguments of Name.t * int * int
| ClashTheory of string
exception Error of error exception Error of error
...@@ -65,6 +66,8 @@ let report fmt = function ...@@ -65,6 +66,8 @@ let report fmt = function
| TermExpectedType (ty1, ty2) -> | TermExpectedType (ty1, ty2) ->
fprintf fmt "@[This term has type "; ty1 fmt; fprintf fmt "@[This term has type "; ty1 fmt;
fprintf fmt "@ but is expected to have type@ "; ty2 fmt; fprintf fmt "@]" fprintf fmt "@ but is expected to have type@ "; ty2 fmt; fprintf fmt "@]"
| ClashTheory s ->
fprintf fmt "clash with previous theory %s" s
(** typing environments *) (** typing environments *)
...@@ -74,14 +77,21 @@ type env = { ...@@ -74,14 +77,21 @@ type env = {
tysymbols : tysymbol M.t; (* type symbols *) tysymbols : tysymbol M.t; (* type symbols *)
fsymbols : fsymbol M.t; (* function symbols *) fsymbols : fsymbol M.t; (* function symbols *)
psymbols : psymbol M.t; (* predicate symbols *) psymbols : psymbol M.t; (* predicate symbols *)
theories : env M.t;
let empty = { let empty = {
tysymbols = M.empty; tysymbols = M.empty;
fsymbols = M.empty; fsymbols = M.empty;
psymbols = M.empty; psymbols = M.empty;
theories = M.empty;
let is_empty env =
M.is_empty env.tysymbols &&
M.is_empty env.fsymbols &&
M.is_empty env.psymbols
let find_tysymbol s env = M.find s env.tysymbols let find_tysymbol s env = M.find s env.tysymbols
let find_fsymbol s env = M.find s env.fsymbols let find_fsymbol s env = M.find s env.fsymbols
let find_psymbol s env = M.find s env.psymbols let find_psymbol s env = M.find s env.psymbols
...@@ -160,22 +170,18 @@ let rec unify t1 t2 = match t1, t2 with ...@@ -160,22 +170,18 @@ let rec unify t1 t2 = match t1, t2 with
t1 = t2 t1 = t2
(** Destructive typing environment, that is (** Destructive typing environment, that is
environment + type variables (user or destructive) + local variables. environment + local variables.
It is only local to this module and created with [create_denv] below. *) It is only local to this module and created with [create_denv] below. *)
module Htv = Hashtbl.Make(Name)
type denv = { type denv = {
env : env; env : env;
utyvars : (string, type_var) Hashtbl.t; (* user type variables *) utyvars : (string, type_var) Hashtbl.t; (* user type variables *)
dtyvars : type_var Htv.t; (* destructive type variables for unification *)
dvars : dty M.t; (* local variables, to be bound later *) dvars : dty M.t; (* local variables, to be bound later *)
let create_denv env = { let create_denv env = {
env = env; env = env;
utyvars = Hashtbl.create 17; utyvars = Hashtbl.create 17;
dtyvars = Htv.create 17;
dvars = M.empty; dvars = M.empty;
...@@ -187,14 +193,6 @@ let find_user_type_var x env = ...@@ -187,14 +193,6 @@ let find_user_type_var x env =
Hashtbl.add env.utyvars x v; Hashtbl.add env.utyvars x v;
v v
let find_type_var tv env =
try
Htv.find env.dtyvars tv
with Not_found ->
let v = create_type_var ~user:false tv in
Htv.add env.dtyvars tv v;
v
(** Typing types *) (** Typing types *)
(* parsed types -> intermediate types *) (* parsed types -> intermediate types *)
...@@ -218,12 +216,35 @@ let rec ty = function ...@@ -218,12 +216,35 @@ let rec ty = function
| Tyapp (s, tl) -> | Tyapp (s, tl) ->
Ty.ty_app s (List.map ty tl) Ty.ty_app s (List.map ty tl)
(* Specialize *)
try
Htv.find env tv
with Not_found ->
Htv.add env tv v;
v
let rec specialize env t = match t.Ty.ty_node with let rec specialize env t = match t.Ty.ty_node with
| Ty.Tyvar tv -> | Ty.Tyvar tv ->
Tyvar (find_type_var tv env) Tyvar (find_type_var tv env)
| Ty.Tyapp (s, tl) -> | Ty.Tyapp (s, tl) ->
Tyapp (s, List.map (specialize env) tl) Tyapp (s, List.map (specialize env) tl)
let specialize_fsymbol x env =
let s = find_fsymbol x env.env in
let tl, t = s.fs_scheme in
let env = Htv.create 17 in
s, List.map (specialize env) tl, specialize env t
let specialize_psymbol x env =
let s = find_psymbol x env.env in
s, List.map (specialize env) s.ps_scheme
(** Typing terms and formulas *) (** Typing terms and formulas *)
type dterm = { dt_node : dterm_node; dt_ty : dty } type dterm = { dt_node : dterm_node; dt_ty : dty }
...@@ -254,11 +275,6 @@ let binop = function ...@@ -254,11 +275,6 @@ let binop = function
| PPiff -> Fiff | PPiff -> Fiff
| _ -> assert false | _ -> assert false
let rec dterm env t = let rec dterm env t =
let n, ty = dterm_node t.pp_loc env t.pp_desc in let n, ty = dterm_node t.pp_loc env t.pp_desc in
{ dt_node = n; dt_ty = ty } { dt_node = n; dt_ty = ty }
...@@ -311,10 +327,9 @@ and dfmla env e = match e.pp_desc with ...@@ -311,10 +327,9 @@ and dfmla env e = match e.pp_desc with
let env = { env with dvars = M.add id ty env.dvars } in let env = { env with dvars = M.add id ty env.dvars } in
Fquant (Fexists, id, ty, dfmla env a) Fquant (Fexists, id, ty, dfmla env a)
| PPapp (x, tl) -> | PPapp (x, tl) ->
let s, tyl = let s, tyl =
try try
let s = find_psymbol x env.env in specialize_psymbol x env
with Not_found -> with Not_found ->
error ~loc:e.pp_loc (UnboundSymbol x) error ~loc:e.pp_loc (UnboundSymbol x)
in in
...@@ -414,7 +429,7 @@ let axiom loc s f env = ...@@ -414,7 +429,7 @@ let axiom loc s f env =
ignore (fmla env f); ignore (fmla env f);
env env
let add env = function let rec add_decl env = function
| TypeDecl (loc, ext, sl, s) -> | TypeDecl (loc, ext, sl, s) ->
add_type loc ext sl s env add_type loc ext sl s env
| Logic (loc, ext, ids, PPredicate pl) -> | Logic (loc, ext, ids, PPredicate pl) ->
...@@ -423,5 +438,16 @@ let add env = function ...@@ -423,5 +438,16 @@ let add env = function
List.fold_left (add_function loc pl t) env ids List.fold_left (add_function loc pl t) env ids
| Axiom (loc, s, f) -> | Axiom (loc, s, f) ->
axiom loc s f env axiom loc s f env
| Theory (loc, s, u, dl) ->
add_theory loc s u dl env
| _ -> | _ ->
assert false (*TODO*) assert false (*TODO*)
and add_decls env = List.fold_left add_decl env
and add_theory loc s u dl env =
assert (is_empty env);
if M.mem s env.theories then error ~loc (ClashTheory s);
let env = add_decls env dl in
{ empty with theories = M.add s env env.theories }
...@@ -33,7 +33,8 @@ val fmla : env -> Ptree.lexpr -> fmla ...@@ -33,7 +33,8 @@ val fmla : env -> Ptree.lexpr -> fmla
(** building environments *) (** building environments *)
val add : env -> Ptree.logic_decl -> env val add_decl : env -> Ptree.logic_decl -> env
val add_decls : env -> Ptree.logic_decl list -> env
(** error reporting *) (** error reporting *)
