Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit dfda5336 authored by Andrei Paskevich's avatar Andrei Paskevich
make driver/ independent of parser/
- move common lexing functions to util/lexlib.mll
- move and rename Typing.create_user_tv to Ty.tv_of_string
parent 5e064bc3
...@@ -175,6 +175,7 @@ pvsbin/ ...@@ -175,6 +175,7 @@ pvsbin/
# /src/util/ # /src/util/
/src/util/config.ml /src/util/config.ml
/src/util/lexlib.ml
/src/util/rc.ml /src/util/rc.ml
# /src/session # /src/session
...@@ -105,7 +105,7 @@ endif ...@@ -105,7 +105,7 @@ endif
LIBGENERATED = src/util/config.ml \ LIBGENERATED = src/util/config.ml \
src/util/rc.ml src/parser/lexer.ml \ src/util/rc.ml src/util/lexlib.ml src/parser/lexer.ml \
src/parser/parser.mli src/parser/parser.ml \ src/parser/parser.mli src/parser/parser.ml \
src/driver/driver_parser.mli src/driver/driver_parser.ml \ src/driver/driver_parser.mli src/driver/driver_parser.ml \
src/driver/driver_lexer.ml \ src/driver/driver_lexer.ml \
...@@ -114,17 +114,17 @@ LIBGENERATED = src/util/config.ml \ ...@@ -114,17 +114,17 @@ LIBGENERATED = src/util/config.ml \
LIB_UTIL = config bigInt util opt lists strings \ LIB_UTIL = config bigInt util opt lists strings \
extmap extset exthtbl weakhtbl \ extmap extset exthtbl weakhtbl \
hashcons stdlib exn_printer pp debug loc print_tree \ hashcons stdlib exn_printer pp debug loc lexlib print_tree \
cmdline warning sysutil rc plugin bigInt number pqueue cmdline warning sysutil rc plugin bigInt number pqueue
LIB_CORE = ident ty term pattern decl theory \ LIB_CORE = ident ty term pattern decl theory \
task pretty dterm env trans printer task pretty dterm env trans printer
LIB_PARSER = ptree glob parser typing lexer
LIB_DRIVER = call_provers driver_ast driver_parser driver_lexer driver \ LIB_DRIVER = call_provers driver_ast driver_parser driver_lexer driver \
whyconf autodetection whyconf autodetection
LIB_TRANSFORM = simplify_formula inlining split_goal induction \ LIB_TRANSFORM = simplify_formula inlining split_goal induction \
eliminate_definition eliminate_algebraic \ eliminate_definition eliminate_algebraic \
eliminate_inductive eliminate_let eliminate_if \ eliminate_inductive eliminate_let eliminate_if \
...@@ -145,8 +145,8 @@ LIB_WHYML = mlw_ty mlw_expr mlw_decl mlw_pretty mlw_wp mlw_module \ ...@@ -145,8 +145,8 @@ LIB_WHYML = mlw_ty mlw_expr mlw_decl mlw_pretty mlw_wp mlw_module \
LIBMODULES = $(addprefix src/util/, $(LIB_UTIL)) \ LIBMODULES = $(addprefix src/util/, $(LIB_UTIL)) \
$(addprefix src/core/, $(LIB_CORE)) \ $(addprefix src/core/, $(LIB_CORE)) \
$(addprefix src/parser/, $(LIB_PARSER)) \
$(addprefix src/driver/, $(LIB_DRIVER)) \ $(addprefix src/driver/, $(LIB_DRIVER)) \
$(addprefix src/transform/, $(LIB_TRANSFORM)) \ $(addprefix src/transform/, $(LIB_TRANSFORM)) \
$(addprefix src/printer/, $(LIB_PRINTER)) \ $(addprefix src/printer/, $(LIB_PRINTER)) \
$(addprefix src/whyml/, $(LIB_WHYML)) $(addprefix src/whyml/, $(LIB_WHYML))
...@@ -155,7 +155,7 @@ LIB_SESSION = compress xml termcode session session_tools session_scheduler ...@@ -155,7 +155,7 @@ LIB_SESSION = compress xml termcode session session_tools session_scheduler
LIBSESSIONMODULES = $(addprefix src/session/, $(LIB_SESSION)) LIBSESSIONMODULES = $(addprefix src/session/, $(LIB_SESSION))
LIBDIRS = util core parser driver transform printer whyml LIBDIRS = util core driver parser transform printer whyml
LIBINCLUDES = $(addprefix -I src/, $(LIBDIRS)) LIBINCLUDES = $(addprefix -I src/, $(LIBDIRS))
LIBSESSIONDIRS = session LIBSESSIONDIRS = session
...@@ -33,6 +33,13 @@ let tv_compare tv1 tv2 = id_compare tv1.tv_name tv2.tv_name ...@@ -33,6 +33,13 @@ let tv_compare tv1 tv2 = id_compare tv1.tv_name tv2.tv_name
let create_tvsymbol n = { tv_name = id_register n } let create_tvsymbol n = { tv_name = id_register n }
let tv_of_string =
let hs = Hstr.create 17 in fun s ->
try Hstr.find hs s with Not_found ->
let tv = create_tvsymbol (id_fresh s) in
Hstr.add hs s tv;
tv
(* type symbols and types *) (* type symbols and types *)
type tysymbol = { type tysymbol = {
...@@ -27,6 +27,8 @@ val tv_hash : tvsymbol -> int ...@@ -27,6 +27,8 @@ val tv_hash : tvsymbol -> int
val create_tvsymbol : preid -> tvsymbol val create_tvsymbol : preid -> tvsymbol
val tv_of_string : string -> tvsymbol
type tysymbol = private { type tysymbol = private {
...@@ -150,7 +150,7 @@ let load_driver = let driver_tag = ref (-1) in fun env file extra_files -> ...@@ -150,7 +150,7 @@ let load_driver = let driver_tag = ref (-1) in fun env file extra_files ->
| Rmeta (s,al) -> | Rmeta (s,al) ->
let rec ty_of_pty = function let rec ty_of_pty = function
| PTyvar x -> | PTyvar x ->
Ty.ty_var (Typing.create_user_tv x) Ty.ty_var (Ty.tv_of_string x)
| PTyapp ((loc,_) as q,tyl) -> | PTyapp ((loc,_) as q,tyl) ->
let ts = find_ts th q in let ts = find_ts th q in
let tyl = List.map ty_of_pty tyl in let tyl = List.map ty_of_pty tyl in
...@@ -13,7 +13,6 @@ ...@@ -13,7 +13,6 @@
open Format open Format
open Lexing open Lexing
open Driver_parser open Driver_parser
open Lexer
exception IllegalCharacter of char exception IllegalCharacter of char
...@@ -67,13 +66,13 @@ let op_char = ['=' '<' '>' '~' '+' '-' '*' '/' '%' ...@@ -67,13 +66,13 @@ let op_char = ['=' '<' '>' '~' '+' '-' '*' '/' '%'
rule token = parse rule token = parse
| '\n' | '\n'
{ newline lexbuf; token lexbuf } { Lexlib.newline lexbuf; token lexbuf }
| space+ | space+
{ token lexbuf } { token lexbuf }
{ LEFTPAR_STAR_RIGHTPAR } { LEFTPAR_STAR_RIGHTPAR }
{ comment lexbuf; token lexbuf } { Lexlib.comment lexbuf; token lexbuf }
| '_' | '_'
{ UNDERSCORE } { UNDERSCORE }
| ident as id | ident as id
...@@ -99,16 +98,15 @@ rule token = parse ...@@ -99,16 +98,15 @@ rule token = parse
| op_char+ as op | op_char+ as op
{ OPERATOR op } { OPERATOR op }
{ STRING (string lexbuf) } { STRING (Lexlib.string lexbuf) }
| "import" space* "\"" | "import" space* "\""
{ INPUT (string lexbuf) } { INPUT (Lexlib.string lexbuf) }
| eof | eof
{ EOF } { EOF }
| _ as c | _ as c
{ raise (IllegalCharacter c) } { raise (IllegalCharacter c) }
let parse_file_gen parse input_lexbuf lexbuf = let parse_file_gen parse input_lexbuf lexbuf =
let s = Stack.create () in let s = Stack.create () in
Stack.push lexbuf s; Stack.push lexbuf s;
...@@ -9,8 +9,6 @@ ...@@ -9,8 +9,6 @@
(** parsing entry points *)
val library_of_env : Env.env -> unit Env.library val library_of_env : Env.env -> unit Env.library
val parse_logic_file : val parse_logic_file :
...@@ -20,13 +18,3 @@ val parse_program_file : ...@@ -20,13 +18,3 @@ val parse_program_file :
Ptree.incremental -> Lexing.lexbuf -> unit Ptree.incremental -> Lexing.lexbuf -> unit
val token_counter : Lexing.lexbuf -> int * int val token_counter : Lexing.lexbuf -> int * int
(** other functions to be re-used in other lexers/parsers *)
val newline : Lexing.lexbuf -> unit
val comment : Lexing.lexbuf -> unit
val string : Lexing.lexbuf -> string
val remove_leading_plus : string -> string
...@@ -11,19 +11,12 @@ ...@@ -11,19 +11,12 @@
open Lexing
open Parser open Parser
(* lexical errors *)
exception UnterminatedComment
exception UnterminatedString
let () = Exn_printer.register (fun fmt e -> match e with let () = Exn_printer.register (fun fmt e -> match e with
| IllegalCharacter c -> fprintf fmt "illegal character %c" c | IllegalCharacter c -> fprintf fmt "illegal character %c" c
| UnterminatedComment -> fprintf fmt "unterminated comment"
| UnterminatedString -> fprintf fmt "unterminated string"
| _ -> raise e) | _ -> raise e)
let keywords = Hashtbl.create 97 let keywords = Hashtbl.create 97
...@@ -99,52 +92,8 @@ ...@@ -99,52 +92,8 @@
"while", WHILE; "while", WHILE;
"writes", WRITES; "writes", WRITES;
let newline lexbuf =
let pos = lexbuf.lex_curr_p in
lexbuf.lex_curr_p <-
{ pos with pos_lnum = pos.pos_lnum + 1; pos_bol = pos.pos_cnum }
let string_start_loc = ref Loc.dummy_position
let string_buf = Buffer.create 1024
let comment_start_loc = ref Loc.dummy_position
let char_for_backslash = function
| 'n' -> '\n'
| 't' -> '\t'
| c -> c
let update_loc lexbuf file line chars =
let new_file = match file with None -> pos.pos_fname | Some s -> s in
{ pos with
pos_fname = new_file;
pos_lnum = int_of_string line;
pos_bol = pos.pos_cnum - int_of_string chars;
let remove_leading_plus s =
let n = String.length s in
if n > 0 && s.[0] = '+' then String.sub s 1 (n-1) else s
let loc lb = Loc.extract (lexeme_start_p lb, lexeme_end_p lb)
let remove_underscores s =
if String.contains s '_' then begin
let count =
let nb = ref 0 in
String.iter (fun c -> if c = '_' then incr nb) s;
!nb in
let t = String.create (String.length s - count) in
let i = ref 0 in
String.iter (fun c -> if c <> '_' then (t.[!i] <-c; incr i)) s;
t
end else s
let newline = '\n'
let space = [' ' '\t' '\r'] let space = [' ' '\t' '\r']
let lalpha = ['a'-'z' '_'] let lalpha = ['a'-'z' '_']
let ualpha = ['A'-'Z'] let ualpha = ['A'-'Z']
...@@ -167,14 +116,15 @@ let op_char_pref = ['!' '?'] ...@@ -167,14 +116,15 @@ let op_char_pref = ['!' '?']
| "##" space* ("\"" ([^ '\010' '\013' '"' ]* as file) "\"")? | "##" space* ("\"" ([^ '\010' '\013' '"' ]* as file) "\"")?
space* (digit+ as line) space* (digit+ as char) space* "##" space* (digit+ as line) space* (digit+ as char) space* "##"
{ update_loc lexbuf file line char; token lexbuf } { Lexlib.update_loc lexbuf file (int_of_string line) (int_of_string char);
token lexbuf }
| "#" space* "\"" ([^ '\010' '\013' '"' ]* as file) "\"" | "#" space* "\"" ([^ '\010' '\013' '"' ]* as file) "\""
space* (digit+ as line) space* (digit+ as bchar) space* space* (digit+ as line) space* (digit+ as bchar) space*
(digit+ as echar) space* "#" (digit+ as echar) space* "#"
{ POSITION (Loc.user_position file (int_of_string line) { POSITION (Loc.user_position file (int_of_string line)
(int_of_string bchar) (int_of_string echar)) } (int_of_string bchar) (int_of_string echar)) }
| newline | '\n'
| space+ | space+
| '_' | '_'
...@@ -184,27 +134,29 @@ rule token = parse ...@@ -184,27 +134,29 @@ rule token = parse
| uident as id | uident as id
{ UIDENT id } { UIDENT id }
| ['0'-'9'] ['0'-'9' '_']* as s | ['0'-'9'] ['0'-'9' '_']* as s
{ INTEGER (Number.int_const_dec (remove_underscores s)) } { INTEGER (Number.int_const_dec (Lexlib.remove_underscores s)) }
| '0' ['x' 'X'] (['0'-'9' 'A'-'F' 'a'-'f']['0'-'9' 'A'-'F' 'a'-'f' '_']* as s) | '0' ['x' 'X'] (['0'-'9' 'A'-'F' 'a'-'f']['0'-'9' 'A'-'F' 'a'-'f' '_']* as s)
{ INTEGER (Number.int_const_hex (remove_underscores s)) } { INTEGER (Number.int_const_hex (Lexlib.remove_underscores s)) }
| '0' ['o' 'O'] (['0'-'7'] ['0'-'7' '_']* as s) | '0' ['o' 'O'] (['0'-'7'] ['0'-'7' '_']* as s)
{ INTEGER (Number.int_const_oct (remove_underscores s)) } { INTEGER (Number.int_const_oct (Lexlib.remove_underscores s)) }
| '0' ['b' 'B'] (['0'-'1'] ['0'-'1' '_']* as s) | '0' ['b' 'B'] (['0'-'1'] ['0'-'1' '_']* as s)
{ INTEGER (Number.int_const_bin (remove_underscores s)) } { INTEGER (Number.int_const_bin (Lexlib.remove_underscores s)) }
| (digit+ as i) ("" as f) ['e' 'E'] (['-' '+']? digit+ as e) | (digit+ as i) ("" as f) ['e' 'E'] (['-' '+']? digit+ as e)
| (digit+ as i) '.' (digit* as f) (['e' 'E'] (['-' '+']? digit+ as e))? | (digit+ as i) '.' (digit* as f) (['e' 'E'] (['-' '+']? digit+ as e))?
| (digit* as i) '.' (digit+ as f) (['e' 'E'] (['-' '+']? digit+ as e))? | (digit* as i) '.' (digit+ as f) (['e' 'E'] (['-' '+']? digit+ as e))?
{ FLOAT (Number.real_const_dec i f (Opt.map remove_leading_plus e)) } { FLOAT (Number.real_const_dec i f
(Opt.map Lexlib.remove_leading_plus e)) }
| '0' ['x' 'X'] (hexadigit+ as i) ("" as f) ['p' 'P'] (['-' '+']? digit+ as e) | '0' ['x' 'X'] (hexadigit+ as i) ("" as f) ['p' 'P'] (['-' '+']? digit+ as e)
| '0' ['x' 'X'] (hexadigit+ as i) '.' (hexadigit* as f) | '0' ['x' 'X'] (hexadigit+ as i) '.' (hexadigit* as f)
(['p' 'P'] (['-' '+']? digit+ as e))? (['p' 'P'] (['-' '+']? digit+ as e))?
| '0' ['x' 'X'] (hexadigit* as i) '.' (hexadigit+ as f) | '0' ['x' 'X'] (hexadigit* as i) '.' (hexadigit+ as f)
{ FLOAT (Number.real_const_hex i f (Opt.map remove_leading_plus e)) } { FLOAT (Number.real_const_hex i f
{ comment_start_loc := loc lexbuf; comment lexbuf; token lexbuf } { Lexlib.comment lexbuf; token lexbuf }
| "~'" (lident as id) | "~'" (lident as id)
{ OPAQUE_QUOTE_LIDENT id } { OPAQUE_QUOTE_LIDENT id }
| "'" (lident as id) | "'" (lident as id)
...@@ -264,43 +216,13 @@ rule token = parse ...@@ -264,43 +216,13 @@ rule token = parse
| op_char_4+ as s | op_char_4+ as s
{ OP4 s } { OP4 s }
{ string_start_loc := loc lexbuf; STRING (string lexbuf) } { STRING (Lexlib.string lexbuf) }
| eof | eof
{ EOF } { EOF }
| _ as c | _ as c
and comment = parse
{ comment lexbuf }
{ comment lexbuf; comment lexbuf }
| newline
{ newline lexbuf; comment lexbuf }
| eof
{ raise (Loc.Located (!comment_start_loc, UnterminatedComment)) }
| _
{ comment lexbuf }
and string = parse
{ let s = Buffer.contents string_buf in
Buffer.clear string_buf;
s }
| "\\" (_ as c)
{ if c = '\n' then newline lexbuf;
Buffer.add_char string_buf (char_for_backslash c); string lexbuf }
| newline
{ newline lexbuf; Buffer.add_char string_buf '\n'; string lexbuf }
| eof
{ raise (Loc.Located (!string_start_loc, UnterminatedString)) }
| _ as c
{ Buffer.add_char string_buf c; string lexbuf }
let parse_logic_file env path lb = let parse_logic_file env path lb =
open_file token (Lexing.from_string "") (Typing.open_file env path); open_file token (Lexing.from_string "") (Typing.open_file env path);
Loc.with_location (logic_file token) lb; Loc.with_location (logic_file token) lb;
...@@ -99,20 +99,13 @@ let find_namespace_ns ns q = ...@@ -99,20 +99,13 @@ let find_namespace_ns ns q =
(** Parsing types *) (** Parsing types *)
let create_user_tv =
Hstr.add hs s tv;
tv
let ty_of_pty ?(noop=true) uc pty = let ty_of_pty ?(noop=true) uc pty =
let rec get_ty = function let rec get_ty = function
| PPTtyvar ({id_loc = loc}, true) when noop -> | PPTtyvar ({id_loc = loc}, true) when noop ->
Loc.errorm ~loc "Opaqueness@ annotations@ are@ only@ \ Loc.errorm ~loc "Opaqueness@ annotations@ are@ only@ \
allowed@ in@ function@ and@ predicate@ prototypes" allowed@ in@ function@ and@ predicate@ prototypes"
| PPTtyvar ({id = x}, _) -> | PPTtyvar ({id = x}, _) ->
ty_var (create_user_tv x) ty_var (tv_of_string x)
| PPTtyapp (q, tyl) -> | PPTtyapp (q, tyl) ->
let ts = find_tysymbol uc q in let ts = find_tysymbol uc q in
let tyl = List.map get_ty tyl in let tyl = List.map get_ty tyl in
...@@ -129,7 +122,7 @@ let ty_of_pty ?(noop=true) uc pty = ...@@ -129,7 +122,7 @@ let ty_of_pty ?(noop=true) uc pty =
let opaque_tvs args = let opaque_tvs args =
let rec opaque_tvs acc = function let rec opaque_tvs acc = function
| PPTtyvar (id, true) -> Stv.add (create_user_tv id.id) acc | PPTtyvar (id, true) -> Stv.add (tv_of_string id.id) acc
| PPTtyvar (_, false) -> acc | PPTtyvar (_, false) -> acc
| PPTtyapp (_, pl) | PPTtyapp (_, pl)
| PPTtuple pl -> List.fold_left opaque_tvs acc pl | PPTtuple pl -> List.fold_left opaque_tvs acc pl
...@@ -409,7 +402,7 @@ let add_types dl th = ...@@ -409,7 +402,7 @@ let add_types dl th =
let vl = List.map (fun id -> let vl = List.map (fun id ->
if Hstr.mem vars id.id then if Hstr.mem vars id.id then
Loc.error ~loc:id.id_loc (DuplicateTypeVar id.id); Loc.error ~loc:id.id_loc (DuplicateTypeVar id.id);
let i = create_user_tv id.id in let i = tv_of_string id.id in
Hstr.add vars id.id i; Hstr.add vars id.id i;
i) d.td_params i) d.td_params
in in
...@@ -772,7 +765,7 @@ let type_inst th t s = ...@@ -772,7 +765,7 @@ let type_inst th t s =
| CStsym (loc,p,tvl,pty) -> | CStsym (loc,p,tvl,pty) ->
let ts1 = find_tysymbol_ns t.th_export p in let ts1 = find_tysymbol_ns t.th_export p in
let id = id_user (ts1.ts_name.id_string ^ "_subst") loc in let id = id_user (ts1.ts_name.id_string ^ "_subst") loc in
let tvl = List.map (fun id -> create_user_tv id.id) tvl in let tvl = List.map (fun id -> tv_of_string id.id) tvl in
let def = Some (ty_of_pty th pty) in let def = Some (ty_of_pty th pty) in
let ts2 = Loc.try3 ~loc create_tysymbol id tvl def in let ts2 = Loc.try3 ~loc create_tysymbol id tvl def in
if Mts.mem ts1 s.inst_ts if Mts.mem ts1 s.inst_ts
...@@ -12,7 +12,6 @@ ...@@ -12,7 +12,6 @@
(** Typing environments *) (** Typing environments *)
open Stdlib open Stdlib
open Ty
open Term open Term
open Theory open Theory
...@@ -39,7 +38,6 @@ val close_file : unit -> theory Mstr.t ...@@ -39,7 +38,6 @@ val close_file : unit -> theory Mstr.t
(** The following is exported for program typing (src/whyml/mlw_typing.ml) *) (** The following is exported for program typing (src/whyml/mlw_typing.ml) *)
val create_user_tv : string -> tvsymbol
val create_user_id : Ptree.ident -> Ident.preid val create_user_id : Ptree.ident -> Ident.preid
val qloc : Ptree.qualid -> Loc.position val qloc : Ptree.qualid -> Loc.position
(* The Why3 Verification Platform / The Why3 Development Team *)
(* Copyright 2010-2014 -- INRIA - CNRS - Paris-Sud University *)
(* This software is distributed under the terms of the GNU Lesser *)
(* General Public License version 2.1, with the special exception *)
(* on linking described in file LICENSE. *)
(** common functions to be used in lexers/parsers *)
val update_loc : Lexing.lexbuf -> string option -> int -> int -> unit
val remove_underscores : string -> string
open Format
open Lexing
| _ -> raise e)
