GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
df417ca3
df417ca3
Andrei Paskevich
store loadpath as a set of paths, not as a list
Thanks to Johannes Kanig for the suggestion.
2726d45a
src/core/env.ml
df417ca3
@@ -39,7 +39,7 @@ exception TheoryNotFound of pathname * string
exception
AmbiguousPath
of
filename
filename
type
env
env_path
filename
lis
t
env_path
Sstr
t
env_tag
Hashweak
tag
@@ -50,11 +50,11 @@ module Wenv = Hashweak.Make(struct type t = env let tag = env_tag end)
(** Environment construction and utilisation *)
let
create_env
let
c
ref
in
fun
lp
env_path
lp
env_path
fold_right
Sstr
add
lp
Sstr
empty
env_tag
incr
c
Hashweak
create_tag
c
let
get_loadpath
env
env
env_path
let
get_loadpath
env
Sstr
elements
env
env_path
let
read_format_table
Hashtbl
create
17
(* format name -> read_format *)
let
extensions_table
Hashtbl
create
17
(* suffix -> format name *)
@@ -115,7 +115,7 @@ let locate_lib_file env path exts =
let
add_ext
ext
file
ext
in
let
fl
if
exts
then
file
else
map
add_ext
exts
in
let
add_dir
dir
map
Filename
concat
dir
fl
in
let
fl
concat
map
add_dir
env
env_path
in
let
fl
concat
map
add_dir
get_loadpath
env
in
match
filter
Sys
file_exists
fl
raise
LibFileNotFound
path
file
file
