Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit de593c35 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
python: new example sort
parent a73d9d9a
......@@ -221,6 +221,7 @@ pvsbin/
/plugins/python/examples/guess/
/plugins/python/examples/mult/
/plugins/python/examples/dicho/
/plugins/python/examples/sort/
# /drivers
/drivers/coq-realizations.aux
from random import randint
n = 42
a = [0] * n
for i in range(0, len(a)):
a[i] = randint(0, 100)
print(a[i])
#for m in range(1, len(a)):
m = 1
while m < len(a):
#@ invariant 0 <= m <= len(a)
#@ invariant forall i,j. 0 <= i <= j < m -> a[i] <= a[j]
#@ variant len(a) - m
x = a[m]
k = m
while k > 0 and a[k-1] > x:
#@ invariant 0 <= k <= m
#@ invariant forall j. k < j <= m -> x < a[j]
#@ invariant forall i,j. k < i <= j <= m -> a[i] <= a[j]
#@ invariant forall i,j. 0 <= i <= j < k -> a[i] <= a[j]
#@ invariant forall i,j. 0 <= i < k < j <= m -> a[i] <= a[j]
#@ variant k
a[k] = a[k-1]
k = k - 1
a[k] = x
m = m + 1
#@ assert forall i,j. 0 <= i <= j < len(a) -> a[i] <= a[j]
print(a[i])
......@@ -55,6 +55,7 @@ and stmt_desc =
| Sset of expr * expr * expr (* e1[e2] = e3 *)
| Sassert of Ptree.assertion_kind * Ptree.term
| Sbreak
| Slabel of ident
and block = stmt list
......@@ -40,6 +40,7 @@
["invariant", INVARIANT; "variant", VARIANT;
"assert", ASSERT; "assume", ASSUME; "check", CHECK;
"requires", REQUIRES; "ensures", ENSURES;
"label", LABEL;
fun s -> try Hashtbl.find h s with Not_found ->
raise (Lexing_error ("no such annotation '" ^ s ^ "'"))
......@@ -103,20 +103,21 @@ let loop_annotation env a =
let add_loop_invariant i a =
{ a with loop_invariant = i :: a.loop_invariant }
let rec has_stmt p s =
p s || match s.Py_ast.stmt_desc with
| Py_ast.Sbreak | Py_ast.Sreturn _ | Py_ast.Sassign _
| Py_ast.Seval _ | Py_ast.Sset _ | Py_ast.Sassert _
| Py_ast.Swhile _ -> false
| Py_ast.Sif (_, bl1, bl2) -> has_stmtl p bl1 || has_stmtl p bl2
| Py_ast.Sfor (_, _, _, bl) -> has_stmtl p bl
and has_stmtl p bl = List.exists (has_stmt p) bl
let rec has_break s = match s.stmt_desc with
| Sbreak -> true
| Sreturn _ | Sassign _ | Slabel _
| Seval _ | Sset _ | Sassert _ | Swhile _ -> false
| Sif (_, bl1, bl2) -> has_breakl bl1 || has_breakl bl2
| Sfor (_, _, _, bl) -> has_breakl bl
and has_breakl bl = List.exists has_break bl
let has_breakl =
has_stmtl (function {stmt_desc = Sbreak } -> true | _ -> false)
(* FIXME: raise an error on missing return statements *)
let has_returnl =
has_stmtl (function {stmt_desc = Sreturn _ } -> true | _ -> false)
let rec has_return s = match s.stmt_desc with
| Sreturn _ -> true
| Sbreak | Sassign _ | Slabel _
| Seval _ | Sset _ | Sassert _ -> false
| Sif (_, bl1, bl2) -> has_returnl bl1 || has_returnl bl2
| Swhile (_, _, bl) | Sfor (_, _, _, bl) -> has_returnl bl
and has_returnl bl = List.exists has_return bl
let rec expr env {Py_ast.expr_loc = loc; Py_ast.expr_desc = d } = match d with
| Py_ast.Enone ->
......@@ -203,6 +204,8 @@ let rec stmt env ({Py_ast.stmt_loc = loc; Py_ast.stmt_desc = d } as s) =
else loop
| Py_ast.Sbreak ->
mk_expr ~loc (Eraise (break ~loc, None))
| Py_ast.Slabel _ ->
mk_unit ~loc (* ignore lonely marks *)
| Py_ast.Sfor (id, e, inv, body) ->
(* for x in e:
s
......@@ -233,6 +236,8 @@ let rec stmt env ({Py_ast.stmt_loc = loc; Py_ast.stmt_desc = d } as s) =
and block env ?(loc=Loc.dummy_position) = function
mk_unit ~loc
| { stmt_loc = loc; stmt_desc = Slabel id } :: sl ->
mk_expr ~loc (Emark (id, block env ~loc sl))
| { Py_ast.stmt_loc = loc; stmt_desc = Py_ast.Sassign (id, e) } :: sl
when not (Mstr.mem id.id_str env.vars) ->
let e = expr env e in (* check e *before* adding id to environment *)
......@@ -69,7 +69,7 @@
%token LEFTPAR RIGHTPAR LEFTSQ RIGHTSQ COMMA EQUAL COLON BEGIN END NEWLINE
%token PLUS MINUS TIMES DIV MOD
(* annotations *)
%token INVARIANT VARIANT ASSUME ASSERT CHECK REQUIRES ENSURES
%token INVARIANT VARIANT ASSUME ASSERT CHECK REQUIRES ENSURES LABEL
%token ARROW LRARROW FORALL EXISTS DOT THEN LET
(* precedences *)
......@@ -238,6 +238,8 @@ simple_stmt_desc:
{ Seval e }
| BREAK
{ Sbreak }
| LABEL id=ident
{ Slabel id }
assertion_kind:
def testat():
x = 0
#@ label L
x = x+1
#@ assert at(x,L) == 0
def f(x):
#@ ensures result > x
return x+1
