GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
dd787602
dd787602
Clément Fumex
load proof first attempt
9e698189
2
Expand all
2 changed files
297 additions
180 deletions
+297
-180
src/session/session_itp.ml
+279
-168
src/session/session_itp.mli
+18
-12
dd787602
This diff is collapsed.
dd787602
@@ -7,9 +7,11 @@ type trans_arg
(* (\** New Proof sessions ("Refectoire") *\) *)
(* note: la fonction register des transformations doit permettre de declarer les types des arguments
type trans_arg_type = TTint | TTstring | TTterm | TTty | TTtysymbol | TTlsymbol | TTprsymbol
@@ -19,32 +21,36 @@ val graft_proof_attempt : session -> proofNodeID -> proof_attempt -> unit
(** [graft_proof_attempt s id pa] adds the proof attempt [pa] as a
child of the task [id] of the session [s]. *)
val
graft_transf
session
proofNodeID
string
trans_arg
list
Task
task
list
unit
val
graft_transf
session
proofNodeID
string
trans_arg
list
Task
task
list
unit
(** [graft_transf s id name l tl] adds the transformation [name] as a
child of the task [id] of the session [s]. [l] is the list of argument
of the transformation; [tl] is the resulting list of tasks *)
argument of the transformation; [tl] is the resulting list of
tasks *)
val
remove_proof_attempt
session
proofNodeID
Whyconf
prover
unit
val
session
proofNodeID
Whyconf
prover
unit
(** [remove_proof_attempt s id pr] removes the proof attempt from the
prover [pr] from the proof node [id] of the session [s] *)
val
remove_transformation
session
proofNodeID
transID
unit
val
session
transID
unit
(** [remove_transformation s
pid tid] removes the transformation [tid] from
id] removes the transformation [id]
the proof node [pid] of
the session [s] *)
from
the session [s] *)
val
save_session
string
session
unit
(* val save_session : string -> session -> unit *)
(** [save_session f s] Save the session [s] in file [f] *)
val
load_session
string
session
val
load_session
string
session
bool
(** [load_session f] load a session from a file [f]; all the tasks are
initialised to None *)
couche au-dessus: "scheduler" cad modifications asynchrones de la session
session
- gere une file de travaux de modifications a faire
- recupere les resultats de travaux , et les applique s'ils sont encore valides
encore valides
type theory =
type theory =
