Commit db6b1d16 authored by MARCHE Claude's avatar MARCHE Claude
Allow alternative icon set
parent c55dba85
...@@ -111,7 +111,7 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -111,7 +111,7 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
- (CLAUDE) complete api.tex: explain how to build theories, apply - (CLAUDE) complete api.tex: explain how to build theories, apply
transformations, write new functions on terms (A) transformations, write new functions on terms (A)
* Ajouter un result de prouveur "outofmemory" analogue a "timeout" * DONE Ajouter un result de prouveur "outofmemory" analogue a "timeout"
* Contre-exemples de Alt-Ergo * Contre-exemples de Alt-Ergo
...@@ -18,8 +18,9 @@ outofmemory_obs = "obsdeletefile32" ...@@ -18,8 +18,9 @@ outofmemory_obs = "obsdeletefile32"
failure_obs = "obsbug32" failure_obs = "obsbug32"
yes = "accept32" yes = "accept32"
no = "delete32" no = "delete32"
directory = "folder32" file = "folder32"
file = "file32" theory = "folder32"
goal = "file32"
prover = "wizard32" prover = "wizard32"
transf = "configure32" transf = "configure32"
editor = "edit32" editor = "edit32"
...@@ -28,3 +29,35 @@ cancel = "cut32" ...@@ -28,3 +29,35 @@ cancel = "cut32"
reload = "movefile32" reload = "movefile32"
remove = "delete32" remove = "delete32"
cleaning = "trashb32" cleaning = "trashb32"
[iconset fatcow]
name = "FatCow"
default = "delete"
undone = "bullet_white"
scheduled = "control_pause_blue"
running = "control_play_blue"
valid = "accept"
unknown = "help"
invalid = "exclamation"
timeout = "timeline"
outofmemory = "ddr_memory"
failure = "bomb"
valid_obs = "bullet_green"
unknown_obs = "bullet_blue"
invalid_obs = "bullet_red"
timeout_obs = "bullet_white"
outofmemory_obs = "bullet_white"
failure_obs = "bullet_black"
yes = "accept"
no = "delete"
file = "package"
theory = "folder"
goal = "script"
prover = "magic_wand_2"
transf = "multitool"
editor = "pencil"
replay = "update"
cancel = "cancel"
reload = "delete"
remove = "delete"
cleaning = "bin"
...@@ -52,6 +52,7 @@ type t = ...@@ -52,6 +52,7 @@ type t =
mutable premise_color : string; mutable premise_color : string;
mutable goal_color : string; mutable goal_color : string;
mutable error_color : string; mutable error_color : string;
mutable iconset : string;
(** colors *) (** colors *)
mutable env : Env.env; mutable env : Env.env;
mutable config : Whyconf.config; mutable config : Whyconf.config;
...@@ -77,6 +78,7 @@ type ide = { ...@@ -77,6 +78,7 @@ type ide = {
ide_premise_color : string; ide_premise_color : string;
ide_goal_color : string; ide_goal_color : string;
ide_error_color : string; ide_error_color : string;
ide_iconset : string;
ide_default_editor : string; ide_default_editor : string;
(* ide_replace_prover : conf_replace_prover; *) (* ide_replace_prover : conf_replace_prover; *)
ide_hidden_provers : string list; ide_hidden_provers : string list;
...@@ -96,6 +98,7 @@ let default_ide = ...@@ -96,6 +98,7 @@ let default_ide =
ide_premise_color = "chartreuse"; ide_premise_color = "chartreuse";
ide_goal_color = "gold"; ide_goal_color = "gold";
ide_error_color = "orange"; ide_error_color = "orange";
ide_iconset = "boomy";
(* ide_replace_prover = CRP_Ask; *) (* ide_replace_prover = CRP_Ask; *)
ide_default_editor = ide_default_editor =
(try Sys.getenv "EDITOR" ^ " %f" (try Sys.getenv "EDITOR" ^ " %f"
...@@ -135,6 +138,9 @@ let load_ide section = ...@@ -135,6 +138,9 @@ let load_ide section =
ide_error_color = ide_error_color =
get_string section ~default:default_ide.ide_error_color get_string section ~default:default_ide.ide_error_color
"error_color"; "error_color";
ide_iconset =
get_string section ~default:default_ide.ide_iconset
"iconset";
get_string section ~default:default_ide.ide_default_editor get_string section ~default:default_ide.ide_default_editor
"default_editor"; "default_editor";
...@@ -204,6 +210,7 @@ let load_config config original_config = ...@@ -204,6 +210,7 @@ let load_config config original_config =
premise_color = ide.ide_premise_color; premise_color = ide.ide_premise_color;
goal_color = ide.ide_goal_color; goal_color = ide.ide_goal_color;
error_color = ide.ide_error_color; error_color = ide.ide_error_color;
iconset = ide.ide_iconset;
default_editor = ide.ide_default_editor; default_editor = ide.ide_default_editor;
config = config; config = config;
original_config = original_config; original_config = original_config;
...@@ -269,6 +276,7 @@ let save_config t = ...@@ -269,6 +276,7 @@ let save_config t =
let ide = set_string ide "premise_color" t.premise_color in let ide = set_string ide "premise_color" t.premise_color in
let ide = set_string ide "goal_color" t.goal_color in let ide = set_string ide "goal_color" t.goal_color in
let ide = set_string ide "error_color" t.error_color in let ide = set_string ide "error_color" t.error_color in
let ide = set_string ide "iconset" t.iconset in
let ide = set_string ide "default_editor" t.default_editor in let ide = set_string ide "default_editor" t.default_editor in
let ide = set_stringl ide "hidden_prover" t.hidden_provers in let ide = set_stringl ide "hidden_prover" t.hidden_provers in
let config = set_section config "ide" ide in let config = set_section config "ide" ide in
...@@ -306,16 +314,6 @@ let get_main () = (get_main (config ()).config) ...@@ -306,16 +314,6 @@ let get_main () = (get_main (config ()).config)
let image ?size f =
let main = get_main () in
let n = Filename.concat (datadir main) (Filename.concat "images" (f^".png"))
in
match size with
| None ->
GdkPixbuf.from_file n
| Some s ->
GdkPixbuf.from_file_at_size ~width:s ~height:s n
let image_default = ref (GdkPixbuf.create ~width:1 ~height:1 ()) let image_default = ref (GdkPixbuf.create ~width:1 ~height:1 ())
(** dumb pixbuf *) (** dumb pixbuf *)
let image_undone = ref !image_default let image_undone = ref !image_default
...@@ -335,8 +333,9 @@ let image_outofmemory_obs = ref !image_default ...@@ -335,8 +333,9 @@ let image_outofmemory_obs = ref !image_default
let image_failure_obs = ref !image_default let image_failure_obs = ref !image_default
let image_yes = ref !image_default let image_yes = ref !image_default
let image_no = ref !image_default let image_no = ref !image_default
let image_directory = ref !image_default
let image_file = ref !image_default let image_file = ref !image_default
let image_theory = ref !image_default
let image_goal = ref !image_default
let image_prover = ref !image_default let image_prover = ref !image_default
let image_transf = ref !image_default let image_transf = ref !image_default
let image_editor = ref !image_default let image_editor = ref !image_default
...@@ -348,7 +347,17 @@ let image_cleaning = ref !image_default ...@@ -348,7 +347,17 @@ let image_cleaning = ref !image_default
let why_icon = ref !image_default let why_icon = ref !image_default
let iconset = "boomy" let image ?size f =
let n =
in
match size with
| None ->
| Some s ->
let iconname_default = ref "" let iconname_default = ref ""
let iconname_undone = ref "" let iconname_undone = ref ""
...@@ -368,8 +377,9 @@ let iconname_outofmemory_obs = ref "" ...@@ -368,8 +377,9 @@ let iconname_outofmemory_obs = ref ""
let iconname_failure_obs = ref "" let iconname_failure_obs = ref ""
let iconname_yes = ref "" let iconname_yes = ref ""
let iconname_no = ref "" let iconname_no = ref ""
let iconname_directory = ref ""
let iconname_file = ref "" let iconname_file = ref ""
let iconname_theory = ref ""
let iconname_goal = ref ""
let iconname_prover = ref "" let iconname_prover = ref ""
let iconname_transf = ref "" let iconname_transf = ref ""
let iconname_editor = ref "" let iconname_editor = ref ""
...@@ -380,6 +390,8 @@ let iconname_remove = ref "" ...@@ -380,6 +390,8 @@ let iconname_remove = ref ""
let iconname_cleaning = ref "" let iconname_cleaning = ref ""
let load_icon_names () = let load_icon_names () =
let ide = config () in
let iconset = ide.iconset in
let main = get_main () in let main = get_main () in
let n = let n =
Filename.concat (datadir main) (Filename.concat "images" "icons.rc") Filename.concat (datadir main) (Filename.concat "images" "icons.rc")
...@@ -387,34 +399,38 @@ let load_icon_names () = ...@@ -387,34 +399,38 @@ let load_icon_names () =
let d = Rc.from_file n in let d = Rc.from_file n in
let d = Rc.get_family d "iconset" in let d = Rc.get_family d "iconset" in
let d = List.assoc iconset d in let d = List.assoc iconset d in
iconname_default := get_string ~default:"default" d "default"; let get_icon_name n =
iconname_undone := get_string ~default:"default" d "undone"; Filename.concat iconset (get_string ~default:"default" d n)
iconname_scheduled := get_string ~default:"default" d "scheduled"; in
iconname_running := get_string ~default:"default" d "running"; iconname_default := get_icon_name "default";
iconname_valid := get_string ~default:"default" d "valid"; iconname_undone := get_icon_name "undone";
iconname_unknown := get_string ~default:"default" d "unknown"; iconname_scheduled := get_icon_name "scheduled";
iconname_invalid := get_string ~default:"default" d "invalid"; iconname_running := get_icon_name "running";
iconname_timeout := get_string ~default:"default" d "timeout"; iconname_valid := get_icon_name "valid";
iconname_outofmemory := get_string ~default:"default" d "outofmemory"; iconname_unknown := get_icon_name "unknown";
iconname_failure := get_string ~default:"default" d "failure"; iconname_invalid := get_icon_name "invalid";
iconname_valid_obs := get_string ~default:"default" d "valid_obs"; iconname_timeout := get_icon_name "timeout";
iconname_unknown_obs := get_string ~default:"default" d "unknown_obs"; iconname_outofmemory := get_icon_name "outofmemory";
iconname_invalid_obs := get_string ~default:"default" d "invalid_obs"; iconname_failure := get_icon_name "failure";
iconname_timeout_obs := get_string ~default:"default" d "timeout_obs"; iconname_valid_obs := get_icon_name "valid_obs";
iconname_outofmemory_obs := get_string ~default:"default" d "outofmemory_obs"; iconname_unknown_obs := get_icon_name "unknown_obs";
iconname_failure_obs := get_string ~default:"default" d "failure_obs"; iconname_invalid_obs := get_icon_name "invalid_obs";
iconname_yes := get_string ~default:"default" d "yes"; iconname_timeout_obs := get_icon_name "timeout_obs";
iconname_no := get_string ~default:"default" d "no"; iconname_outofmemory_obs := get_icon_name "outofmemory_obs";
iconname_directory := get_string ~default:"default" d "directory"; iconname_failure_obs := get_icon_name "failure_obs";
iconname_file := get_string ~default:"default" d "file"; iconname_yes := get_icon_name "yes";
iconname_prover := get_string ~default:"default" d "prover"; iconname_no := get_icon_name "no";
iconname_transf := get_string ~default:"default" d "transf"; iconname_file := get_icon_name "file";
iconname_editor := get_string ~default:"default" d "editor"; iconname_theory := get_icon_name "theory";
iconname_replay := get_string ~default:"default" d "replay"; iconname_goal := get_icon_name "goal";
iconname_cancel := get_string ~default:"default" d "cancel"; iconname_prover := get_icon_name "prover";
iconname_reload := get_string ~default:"default" d "reload"; iconname_transf := get_icon_name "transf";
iconname_remove := get_string ~default:"default" d "remove"; iconname_editor := get_icon_name "editor";
iconname_cleaning := get_string ~default:"default" d "cleaning"; iconname_replay := get_icon_name "replay";
iconname_cancel := get_icon_name "cancel";
iconname_reload := get_icon_name "reload";
iconname_remove := get_icon_name "remove";
iconname_cleaning := get_icon_name "cleaning";
let resize_images size = let resize_images size =
...@@ -436,8 +452,9 @@ let resize_images size = ...@@ -436,8 +452,9 @@ let resize_images size =
image_failure_obs := image ~size !iconname_failure_obs; image_failure_obs := image ~size !iconname_failure_obs;
image_yes := image ~size !iconname_yes; image_yes := image ~size !iconname_yes;
image_no := image ~size !iconname_no; image_no := image ~size !iconname_no;
image_directory := image ~size !iconname_directory;
image_file := image ~size !iconname_file; image_file := image ~size !iconname_file;
image_theory := image ~size !iconname_theory;
image_goal := image ~size !iconname_goal;
image_prover := image ~size !iconname_prover; image_prover := image ~size !iconname_prover;
image_transf := image ~size !iconname_transf; image_transf := image ~size !iconname_transf;
image_editor := image ~size !iconname_editor; image_editor := image ~size !iconname_editor;
...@@ -467,9 +484,11 @@ let show_legend_window () = ...@@ -467,9 +484,11 @@ let show_legend_window () =
let it s = b#insert ~iter:b#end_iter ~tags:[tt] s in let it s = b#insert ~iter:b#end_iter ~tags:[tt] s in
let ib i = b#insert_pixbuf ~iter:b#end_iter ~pixbuf:!i in let ib i = b#insert_pixbuf ~iter:b#end_iter ~pixbuf:!i in
it "Tree view\n"; it "Tree view\n";
ib image_directory;
i " Theory, containing a set of goals\n";
ib image_file; ib image_file;
i " File, containing a set of theories\n";
ib image_theory;
ib image_goal;
i " Goal\n"; i " Goal\n";
ib image_prover; ib image_prover;
i " External prover\n"; i " External prover\n";
...@@ -36,6 +36,7 @@ type t = ...@@ -36,6 +36,7 @@ type t =
mutable env : Why3.Env.env; mutable env : Why3.Env.env;
original_config : Whyconf.config; original_config : Whyconf.config;
...@@ -64,8 +65,9 @@ val why_icon : GdkPixbuf.pixbuf ref ...@@ -64,8 +65,9 @@ val why_icon : GdkPixbuf.pixbuf ref
val image_yes : GdkPixbuf.pixbuf ref val image_yes : GdkPixbuf.pixbuf ref
(* tree object icons *) (* tree object icons *)
val image_directory : GdkPixbuf.pixbuf ref
val image_file : GdkPixbuf.pixbuf ref val image_file : GdkPixbuf.pixbuf ref
val image_theory : GdkPixbuf.pixbuf ref
val image_goal : GdkPixbuf.pixbuf ref
val image_prover : GdkPixbuf.pixbuf ref val image_prover : GdkPixbuf.pixbuf ref
val image_transf : GdkPixbuf.pixbuf ref val image_transf : GdkPixbuf.pixbuf ref
val image_editor : GdkPixbuf.pixbuf ref val image_editor : GdkPixbuf.pixbuf ref
...@@ -671,9 +671,9 @@ let init = ...@@ -671,9 +671,9 @@ let init =
(* useless since it has no child: goals_view#expand_row row#path; *) (* useless since it has no child: goals_view#expand_row row#path; *)
goals_model#set ~row:row#iter ~column:icon_column goals_model#set ~row:row#iter ~column:icon_column
(match any with (match any with
| S.Goal _ -> !image_file | S.Goal _ -> !image_goal
| S.Theory _ | S.Theory _ -> !image_theory
| S.File _ -> !image_directory | S.File _ -> !image_file
| S.Proof_attempt _ -> !image_prover | S.Proof_attempt _ -> !image_prover
| S.Transf _ -> !image_transf); | S.Transf _ -> !image_transf);
notify any notify any
