Commit da49e047 authored by Clément Fumex's avatar Clément Fumex
- correct bv test output
- add "map" to the smtv2 printer blacklist (from z3)
- change smtv2 driver so that errors (in particular z3's) are correctly reported
parent 329ee669
...@@ -4,11 +4,12 @@ prelude ";;; this is a prelude for smt-lib v2" ...@@ -4,11 +4,12 @@ prelude ";;; this is a prelude for smt-lib v2"
printer "smtv2" printer "smtv2"
filename "%f-%t-%g.smt2" filename "%f-%t-%g.smt2"
valid "^unsat"
unknown "^\\(unknown\\|sat\\|Fail\\)" "" unknown "^\\(unknown\\|sat\\|Fail\\)" ""
outofmemory "(error \".*out of memory\")\\|Cannot allocate memory" outofmemory "^(error \".*out of memory\")\\|Cannot allocate memory"
fail "^(error \"\\(.*\\)\")" "Error: \1"
timeout "interrupted by timeout" timeout "interrupted by timeout"
time "why3cpulimit time : %s s" time "why3cpulimit time : %s s"
valid "^unsat"
(* À discuter *) (* À discuter *)
transformation "inline_trivial" transformation "inline_trivial"
This diff is collapsed.
...@@ -7,7 +7,7 @@ ...@@ -7,7 +7,7 @@
<prover id="2" name="CVC4" version="1.4" timelimit="5" memlimit="1000"/> <prover id="2" name="CVC4" version="1.4" timelimit="5" memlimit="1000"/>
<prover id="3" name="Z3" version="4.3.2" timelimit="5" memlimit="1000"/> <prover id="3" name="Z3" version="4.3.2" timelimit="5" memlimit="1000"/>
<file name="../bv.why" expanded="true"> <file name="../bv.why" expanded="true">
<theory name="CheckBV64" sum="fe7139da2eda649fe69da9f64adc83de"> <theory name="CheckBV64" sum="fe7139da2eda649fe69da9f64adc83de" expanded="true">
<goal name="ok_zero"> <goal name="ok_zero">
<proof prover="0"><result status="valid" time="0.02" steps="66"/></proof> <proof prover="0"><result status="valid" time="0.02" steps="66"/></proof>
<proof prover="1"><result status="valid" time="0.02"/></proof> <proof prover="1"><result status="valid" time="0.02"/></proof>
...@@ -151,8 +151,7 @@ ...@@ -151,8 +151,7 @@
<proof prover="2"><result status="valid" time="0.02"/></proof> <proof prover="2"><result status="valid" time="0.02"/></proof>
<proof prover="3"><result status="valid" time="0.01"/></proof> <proof prover="3"><result status="valid" time="0.01"/></proof>
</goal> </goal>
<goal name="ok24"> <goal name="ok24" expanded="true">
<proof prover="0"><result status="valid" time="0.85" steps="342"/></proof>
<proof prover="1"><result status="valid" time="0.45"/></proof> <proof prover="1"><result status="valid" time="0.45"/></proof>
<proof prover="2"><result status="valid" time="0.01"/></proof> <proof prover="2"><result status="valid" time="0.01"/></proof>
<proof prover="3"><result status="valid" time="0.00"/></proof> <proof prover="3"><result status="valid" time="0.00"/></proof>
...@@ -723,8 +722,7 @@ ...@@ -723,8 +722,7 @@
<proof prover="2"><result status="valid" time="0.03"/></proof> <proof prover="2"><result status="valid" time="0.03"/></proof>
</goal> </goal>
<proof prover="0"><result status="valid" time="3.36" steps="332"/></proof>
<proof prover="1"><result status="valid" time="0.59"/></proof> <proof prover="1"><result status="valid" time="0.59"/></proof>
...@@ -943,8 +941,7 @@ ...@@ -943,8 +941,7 @@
</goal> </goal>
<proof prover="0"><result status="valid" time="3.82" steps="332"/></proof>
<proof prover="1"><result status="valid" time="0.64"/></proof> <proof prover="1"><result status="valid" time="0.64"/></proof>
<proof prover="2"><result status="valid" time="0.00"/></proof> <proof prover="2"><result status="valid" time="0.00"/></proof>
...@@ -63,7 +63,10 @@ let ident_printer = ...@@ -63,7 +63,10 @@ let ident_printer =
"Bool"; "true"; "false"; "Bool"; "true"; "false";
"Array";"const"; "Array";"const";
"abs"; "abs";
"BitVec"; "extract"; "bv2nat"; "nat2bv" "BitVec"; "extract"; "bv2nat"; "nat2bv";
(** From Z3 *)
"map"
in in
let san = sanitizer char_to_alpha char_to_alnumus in let san = sanitizer char_to_alpha char_to_alnumus in
