Commit d9bffa2b authored by MARCHE Claude's avatar MARCHE Claude
[Isabelle] fix message when not building heap
parent 26e3d6c8
...@@ -1183,16 +1183,18 @@ install_no_local:: ...@@ -1183,16 +1183,18 @@ install_no_local::
cp drivers/isabelle-realizations.aux $(DATADIR)/why3/drivers/ cp drivers/isabelle-realizations.aux $(DATADIR)/why3/drivers/
@(d=`isabelle components -l | grep why3`; \ @(d=`isabelle components -l | grep why3`; \
if test $$d != $(LIBDIR)/why3/isabelle; then \ if test $$d != $(LIBDIR)/why3/isabelle; then \
echo "Cannot build isabelle heap because component lib [$$d]"; \ echo "[Warning] Cannot pre-build the Isabelle heap because the";
echo "is not the same as the install dir [$(LIBDIR)/why3/isabelle]"; \ echo " current Why3 path in Isabelle component configuration [$$d]"; \
echo " is not the same as the current install dir [$(LIBDIR)/why3/isabelle]"; \
else isabelle build -bc Why3 ; \ else isabelle build -bc Why3 ; \
fi) fi)
install_local:: install_local::
if test $$d != `pwd`/lib/isabelle; then \ if test $$d != `pwd`/lib/isabelle; then \
echo "is not the same as the install dir [`pwd`/lib/isabelle]"; \ echo " current Why3 path in Isabelle component configuration [$$d]"; \
echo " is not the same as the current install dir [`pwd`/lib/isabelle]"; \
fi) fi)
Supports Markdown
