Commit d9a03ee3 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Make trywhy3 compatible with recent versions of js_of_ocaml.
parent a4c46093
...@@ -1576,7 +1576,7 @@ endif ...@@ -1576,7 +1576,7 @@ endif
ALTERGODIR=src/trywhy3/alt-ergo ALTERGODIR=src/trywhy3/alt-ergo
JSOCAMLC=ocamlfind ocamlc -package js_of_ocaml -g -package js_of_ocaml.syntax \ JSOCAMLC=ocamlfind ocamlc -package js_of_ocaml -g -package js_of_ocaml.ppx \
-package ocplib-simplex -I src/trywhy3 \ -package ocplib-simplex -I src/trywhy3 \
-I $(ALTERGODIR)/lib/util \ -I $(ALTERGODIR)/lib/util \
-I $(ALTERGODIR)/lib/structures \ -I $(ALTERGODIR)/lib/structures \
...@@ -1700,8 +1700,6 @@ src/trywhy3/%.cmi: src/trywhy3/%.mli ...@@ -1700,8 +1700,6 @@ src/trywhy3/%.cmi: src/trywhy3/%.mli
src/trywhy3/%.cmo: BFLAGS += -w -48 src/trywhy3/%.cmo: BFLAGS += -w -48
src/trywhy3/worker_proto.cmo src/trywhy3/trywhy3.cmo: BFLAGS += -syntax camlp4o
clean:: clean::
rm -f src/trywhy3/trywhy3.js src/trywhy3/trywhy3.byte src/trywhy3/trywhy3.cm* \ rm -f src/trywhy3/trywhy3.js src/trywhy3/trywhy3.byte src/trywhy3/trywhy3.cm* \
src/trywhy3/why3_worker.js src/trywhy3/why3_worker.byte src/trywhy3/why3_worker.cm* \ src/trywhy3/why3_worker.js src/trywhy3/why3_worker.byte src/trywhy3/why3_worker.cm* \
PKG js_of_ocaml js_of_ocaml.syntax ocplib-simplex PKG js_of_ocaml js_of_ocaml.ppx ocplib-simplex
REC REC
...@@ -12,6 +12,7 @@ ...@@ -12,6 +12,7 @@
open Format open Format
open Worker_proto open Worker_proto
module Worker = Js_of_ocaml.Worker
module SAT = (val (Sat_solver.get_current ()) : Sat_solver_sig.S) module SAT = (val (Sat_solver.get_current ()) : Sat_solver_sig.S)
module FE = Frontend.Make (SAT) module FE = Frontend.Make (SAT)
This diff is collapsed.
...@@ -18,7 +18,8 @@ open Why3 ...@@ -18,7 +18,8 @@ open Why3
module Sys_js = Js_of_ocaml.Sys_js
let () = log_time ("Initialising why3 worker: start ") let () = log_time ("Initialising why3 worker: start ")
...@@ -45,6 +45,6 @@ let status_of_result = function ...@@ -45,6 +45,6 @@ let status_of_result = function
let log s = ignore (Firebug.console ## log (Js.string s)) let log s = ignore (Firebug.console ## log (Js.string s))
let log_time s = let log_time s =
let date = jsnew Js.date_now () in let date = new%js Js.date_now in
let date_str = string_of_float ((date ## getTime ()) /. 1000.) in let date_str = string_of_float (date ## getTime /. 1000.) in
log (date_str ^ " : " ^ s) log (date_str ^ " : " ^ s)
