Commit d87e4263 authored by MARCHE Claude's avatar MARCHE Claude
split does not introduce extras disjunctions
parent 67d70d58
...@@ -1242,7 +1242,7 @@ let f_map_sign fnT fnF sign f = f_label_copy f (match f.f_node with ...@@ -1242,7 +1242,7 @@ let f_map_sign fnT fnF sign f = f_label_copy f (match f.f_node with
let f1p = fnF sign f1 in let f1n = fnF (not sign) f1 in let f1p = fnF sign f1 in let f1n = fnF (not sign) f1 in
let f2 = fnF sign f2 in let f3 = fnF sign f3 in let f2 = fnF sign f2 in let f3 = fnF sign f3 in
if f_equal f1p f1n then f_if f1p f2 f3 else if sign if f_equal f1p f1n then f_if f1p f2 f3 else if sign
then f_and (f_implies f1n f2) (f_or f1p f3) then f_and (f_implies f1n f2) (f_implies (f_not f1p) f3)
else f_or (f_and f1p f2) (f_and (f_not f1n) f3) else f_or (f_and f1p f2) (f_and (f_not f1n) f3)
| _ -> f_map fnT (fnF sign) f) | _ -> f_map fnT (fnF sign) f)
...@@ -1064,23 +1064,23 @@ let root_goals () = ...@@ -1064,23 +1064,23 @@ let root_goals () =
let add_file = assert false let add_file _ = assert false
let add_theory = assert false let add_theory _ = assert false
let add_goal = assert false let add_goal _ = assert false
let add_transformation = assert false let add_transformation _ = assert false
let set_edited_as = assert false let set_edited_as _ = assert false
let set_obsolete = assert false let set_obsolete _ = assert false
let set_status = assert false let set_status _ = assert false
let add_proof_attempt = assert false let add_proof_attempt _ = assert false
let prover_from_name = assert false let prover_from_name _ = assert false
exception AlreadyExist exception AlreadyExist
let files = assert false let files _ = assert false
let init_base = assert false let init_base _ = assert false
let theories = assert false let theories _ = assert false
let file_name = assert false let file_name _ = assert false
let verified = assert false let verified _ = assert false
let goals = assert false let goals _ = assert false
let theory_name = assert false let theory_name _ = assert false
...@@ -95,7 +95,7 @@ and elim_f sign f = match f.f_node with ...@@ -95,7 +95,7 @@ and elim_f sign f = match f.f_node with
let f1n = elim_f (not sign) f1 in let f1n = elim_f (not sign) f1 in
let f2 = elim_f sign f2 in let f2 = elim_f sign f2 in
let f3 = elim_f sign f3 in let f3 = elim_f sign f3 in
if sign then f_and (f_implies f1n f2) (f_or f1p f3) if sign then f_and (f_implies f1n f2) (f_implies (f_not f1p) f3)
| _ -> | _ ->
f_map_sign elim_t elim_f sign f f_map_sign elim_t elim_f sign f
...@@ -56,7 +56,8 @@ let rec split_pos acc f = match f.f_node with ...@@ -56,7 +56,8 @@ let rec split_pos acc f = match f.f_node with
| Fnot f -> | Fnot f ->
apply_append f_not acc (split_neg [] f) apply_append f_not acc (split_neg [] f)
| Fif (fif,fthen,felse) -> | Fif (fif,fthen,felse) ->
split_pos (split_pos acc (f_implies fif fthen)) (f_or fif felse) split_pos (split_pos acc (f_implies fif fthen))
(f_implies (f_not fif) felse)
| Flet (t,fb) -> let vs,f = f_open_bound fb in | Flet (t,fb) -> let vs,f = f_open_bound fb in
apply_append (f_let_close vs t) acc (split_pos [] f) apply_append (f_let_close vs t) acc (split_pos [] f)
| Fcase (tl,bl) -> | Fcase (tl,bl) ->
...@@ -20,7 +20,12 @@ ...@@ -20,7 +20,12 @@
val asym_split : Ident.label val asym_split : Ident.label
val split_pos : Term.fmla list -> Term.fmla -> Term.fmla list val split_pos : Term.fmla list -> Term.fmla -> Term.fmla list
(** [split_pos l f] returns a list [g1;..;gk] @ l such that
f is logically equivalent to g1 /\ .. /\ gk *)
val split_neg : Term.fmla list -> Term.fmla -> Term.fmla list val split_neg : Term.fmla list -> Term.fmla -> Term.fmla list
(** [split_neg l f] returns a list [g1;..;gk] @ l such that
f is logically equivalent to g1 \/ .. \/ gk *)
val split_goal : Task.task Trans.tlist val split_goal : Task.task Trans.tlist
val split_all : Task.task Trans.tlist val split_all : Task.task Trans.tlist
