Commit d6e37147 authored by MARCHE Claude's avatar MARCHE Claude
Metitarski, improved driver
parent e8e3b394
...@@ -24,8 +24,8 @@ time "why3cpulimit time : %s s" ...@@ -24,8 +24,8 @@ time "why3cpulimit time : %s s"
(* to be improved *) (* to be improved *)
transformation "inline_trivial" transformation "inline_trivial"
transformation "eliminate_builtin" transformation "eliminate_builtin"
transformation "inline_all"
transformation "eliminate_definition" transformation "eliminate_definition"
transformation "eliminate_inductive" transformation "eliminate_inductive"
transformation "eliminate_algebraic" transformation "eliminate_algebraic"
...@@ -118,6 +118,7 @@ theory real.Square ...@@ -118,6 +118,7 @@ theory real.Square
prelude "include('Axioms/sqrt-general.ax')." prelude "include('Axioms/sqrt-general.ax')."
syntax function sqr "(%1)^2" syntax function sqr "(%1)^2"
syntax function sqrt "sqrt(%1)"
(* This follows from Metitarski's general axioms. *) (* This follows from Metitarski's general axioms. *)
remove prop Sqrt_positive remove prop Sqrt_positive
...@@ -130,6 +131,17 @@ theory real.Trigonometry ...@@ -130,6 +131,17 @@ theory real.Trigonometry
prelude "include('Axioms/pi.ax')." prelude "include('Axioms/pi.ax')."
remove prop Pi_interval remove prop Pi_interval
remove prop Cos_pi
remove prop Sin_pi
remove prop Cos_pi2
remove prop Sin_pi2
remove prop Cos_plus_pi
remove prop Sin_plus_pi
remove prop Cos_plus_pi2
remove prop Sin_plus_pi2
prelude "include('Axioms/tan.ax')." prelude "include('Axioms/tan.ax')."
prelude "include('Axioms/arctan-lower.ax')." prelude "include('Axioms/arctan-lower.ax')."
...@@ -138,17 +150,20 @@ theory real.Trigonometry ...@@ -138,17 +150,20 @@ theory real.Trigonometry
syntax function atan "arctan(%1)" syntax function atan "arctan(%1)"
syntax function tan "tan(%1)" syntax function tan "tan(%1)"
(* These follow from Metitarski's base axioms. *)
prelude "include('Axioms/cos.ax')." prelude "include('Axioms/cos.ax')."
prelude "include('Axioms/sin.ax')." prelude "include('Axioms/sin.ax')."
syntax function cos "cos(%1)"
syntax function sin "sin(%1)"
remove prop Cos_0 remove prop Cos_0
remove prop Sin_0 remove prop Sin_0
(* These follow from Metitarski's auxiliary axioms. *)
prelude "include('Axioms/cos-constant.ax')." prelude "include('Axioms/cos-constant.ax')."
prelude "include('Axioms/sin-constant.ax')." prelude "include('Axioms/sin-constant.ax')."
remove prop Cos_le_one remove prop Cos_le_one
remove prop Sin_le_one remove prop Sin_le_one
end end
...@@ -10,4 +10,28 @@ theory P ...@@ -10,4 +10,28 @@ theory P
goal sqr_pos : goal sqr_pos :
forall x:real. sqr x >= 0.0 forall x:real. sqr x >= 0.0
end end
\ No newline at end of file
theory P2
use import real.Real
use import real.Square
goal sqr_pos :
theory P3
use import real.Trigonometry
goal cos_bound :
forall x:real. -1.0 <= cos x <= 1.0
goal cos_bound_harder :
forall x:real. 0.0 <= x <= 0.1 -> 0.1 <= cos x <= 1.0
...@@ -71,8 +71,10 @@ let number_format = { ...@@ -71,8 +71,10 @@ let number_format = {
Number.def_int_support = Number.Number_unsupported; Number.def_int_support = Number.Number_unsupported;
Number.dec_real_support = Number.Number_default; Number.dec_real_support = Number.Number_default;
Number.hex_real_support = Number.Number_unsupported; Number.hex_real_support = Number.Number_unsupported;
Number.frac_real_support = Number.Number_unsupported; Number.frac_real_support = Number.Number_custom
Number.def_real_support = Number.Number_unsupported; (Number.PrintFracReal ("%s", "(%s * %s)", "(%s / %s)"));
let rec print_app info fmt ls tl oty = let rec print_app info fmt ls tl oty =
