Commit d5579de5 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Update INSTALL instructions and fix nightly bench.
parent 0a4926e8
...@@ -23,9 +23,10 @@ Installation from the git repository ...@@ -23,9 +23,10 @@ Installation from the git repository
First run First run
autoconf autoconf
automake --add-missing
to build the file ./configure, then follow instructions from the to build the ./configure file and install the helper scripts, then follow
section above. instructions from the section above.
Detailed instructions Detailed instructions
...@@ -35,6 +35,7 @@ echo "Starting time (UTC): "`date --utc +%H:%M` >> $REPORT ...@@ -35,6 +35,7 @@ echo "Starting time (UTC): "`date --utc +%H:%M` >> $REPORT
# configuration # configuration
autoconf autoconf
./configure --enable-local &> $OUT ./configure --enable-local &> $OUT
if test "$?" != "0" ; then if test "$?" != "0" ; then
echo "Configure failed" >> $REPORT echo "Configure failed" >> $REPORT
Supports Markdown
