GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
d5579de5
d5579de5
Guillaume Melquiond
Update INSTALL instructions and fix nightly bench.
0a4926e8
2
2 changed files
4 additions
2 deletions
+4
-2
INSTALL
INSTALL
+3
-2
examples/nightly-bench.sh
+1
INSTALL
d5579de5
@@ -23,9 +23,10 @@ Installation from the git repository
First run
autoconf
automake --add-missing
to build the
file ./configure, then follow instructions from the
section above.
to build the
./configure file and install the helper scripts, then follow
section above.
Detailed instructions
d5579de5
@@ -35,6 +35,7 @@ echo "Starting time (UTC): "`date --utc +%H:%M` >> $REPORT
# configuration
autoconf
automake
--add-missing
./configure
--enable-local
$OUT
if
test
"0"
then
echo
"Configure failed"
$REPORT
