why3bench: we ensure that timeout is not 0
parent d99306fc
...@@ -48,8 +48,8 @@ let rec goal whyconf env path dbgoal wgoal = ...@@ -48,8 +48,8 @@ let rec goal whyconf env path dbgoal wgoal =
let (res_status,_res_time) = BenchUtil.proof_status_to_db_result res in let (res_status,_res_time) = BenchUtil.proof_status_to_db_result res in
if proof_status <> res_status then if proof_status <> res_status then
printf "Diff : %a instead of %a in %a@." printf "Diff : %a instead of %a in %a@."
BenchUtil.print_proof_status proof_status
BenchUtil.print_proof_status res_status BenchUtil.print_proof_status res_status
print_paths path print_paths path
else else
Debug.dprintf debug "Same : %a for %a@." Debug.dprintf debug "Same : %a for %a@."
...@@ -64,7 +64,7 @@ let rec goal whyconf env path dbgoal wgoal = ...@@ -64,7 +64,7 @@ let rec goal whyconf env path dbgoal wgoal =
in in
let call_prover : Call_provers.pre_prover_call = let call_prover : Call_provers.pre_prover_call =
Driver.prove_task Driver.prove_task
~timelimit:(truncate (ceil (time*.1.1))) ~timelimit:(truncate (ceil (0.1 +. time *. 1.1)))
~command (load_driver env driver) ?old wgoal in ~command (load_driver env driver) ?old wgoal in
BenchUtil.new_external_proof (call_prover,cb) BenchUtil.new_external_proof (call_prover,cb)
with Exit -> () with Exit -> ()
