Commit d2e6abc4 authored by Stefan Berghofer's avatar Stefan Berghofer Committed by MARCHE Claude
Check that name of Why3 file matches theory name
parent 6c26fe96
...@@ -640,11 +640,20 @@ fun close incomplete thy = ...@@ -640,11 +640,20 @@ fun close incomplete thy =
| _ => err_no_env ()) |> | _ => err_no_env ()) |>
Sign.parent_path; Sign.parent_path;
fun process_decls consts types x = elem "theory" (fn atts => fun process_decls consts types x path = elem "theory" (fn atts =>
(fn imports :: xs => elem "realized" (fn _ => fn rs => fn thy => (fn imports :: xs => elem "realized" (fn _ => fn rs => fn thy =>
let let
val thyname = get_name atts; val thyname = get_name atts;
val realize = get_bool "realize" atts; val realize = get_bool "realize" atts;
val _ =
realize orelse
Path.is_basic path andalso
let val (path', ext) = Path.split_ext path
in
Path.implode path' = Context.theory_name thy andalso
ext = "xml"
end orelse
error "Name of Why3 file does not match name of theory";
val (ds, thy') = thy |> val (ds, thy') = thy |>
Sign.add_path thyname |> Sign.add_path thyname |>
init_decls thyname consts types |> init_decls thyname consts types |>
...@@ -781,11 +790,11 @@ fun show_status thy sel = ...@@ -781,11 +790,11 @@ fun show_status thy sel =
(**** commands ****) (**** commands ****)
fun why3_open ((files, consts), types) thy = fun why3_open ((files, consts), types) thy =
let val ([{lines, ...}: Token.file], thy') = files thy; let val ([{src_path, lines, ...}: Token.file], thy') = files thy;
in process_decls in process_decls
(map (apsnd (Sign.intern_const thy)) consts) (map (apsnd (Sign.intern_const thy)) consts)
(map (apsnd (Sign.intern_type thy)) types) (map (apsnd (Sign.intern_type thy)) types)
(parse_xml (cat_lines lines)) thy' (parse_xml (cat_lines lines)) src_path thy'
end; end;
fun prove_vc vc_name lthy = fun prove_vc vc_name lthy =
