Commit d2d9a34f authored by Johannes Kanig's avatar Johannes Kanig
why3server: nonblocking read was actually a busy wait
Fixed this by avoiding the recursive call in the case the read is
blocked
parent 8dff5008
...@@ -73,11 +73,12 @@ let disconnect () = ...@@ -73,11 +73,12 @@ let disconnect () =
let run_server () = let run_server () =
let exec = Filename.concat Config.libdir "why3server" in let exec = Filename.concat Config.libdir "why3server" in
Unix.create_process exec ignore
(Unix.create_process exec
[|exec; "--socket"; !socket_name; [|exec; "--socket"; !socket_name;
"--single-client"; "--single-client";
"-j"; string_of_int !max_running_provers |] "-j"; string_of_int !max_running_provers |]
Unix.stdin Unix.stdout Unix.stderr Unix.stdin Unix.stdout Unix.stderr)
let force_connect () = let force_connect () =
match !socket with match !socket with
...@@ -107,7 +108,8 @@ let send_request ~id ~timelimit ~memlimit ~cmd = ...@@ -107,7 +108,8 @@ let send_request ~id ~timelimit ~memlimit ~cmd =
let rec read_lines blocking = let rec read_lines blocking =
let s = read_from_client blocking in let s = read_from_client blocking in
if String.contains s '\n' then begin if s = "" then []
else if String.contains s '\n' then begin
let s = Buffer.contents buf ^ s in let s = Buffer.contents buf ^ s in
Buffer.clear buf; Buffer.clear buf;
let l = Strings.rev_split '\n' s in let l = Strings.rev_split '\n' s in
