Commit d26cadfb authored by Guillaume Melquiond's avatar Guillaume Melquiond
Avoid lazy variables in the Gappa printer, as it might happen that two tasks...
Avoid lazy variables in the Gappa printer, as it might happen that two tasks do not share the same environment.
See http://lists.gforge.inria.fr/pipermail/why3-commits/2011-April/000053.html for details.
There are still global references to unary minus symbols, but they are now refreshed each time.
parent 3f724028
...@@ -50,51 +50,24 @@ let find_th env file th = ...@@ -50,51 +50,24 @@ let find_th env file th =
let theory = Env.find_theory env [file] th in let theory = Env.find_theory env [file] th in
fun id -> Theory.ns_find_ls theory.Theory.th_export [id] fun id -> Theory.ns_find_ls theory.Theory.th_export [id]
let get_info = let get_info env task =
let arith_symbols = ref None in (* unary minus for constants *)
let ops_of_rels = ref Mls.empty in int_minus := find_th env "int" "Int" "prefix -";
let _inline = ref Sls.empty in real_minus := find_th env "real" "Real" "prefix -";
fun env task -> (* handling of inequalities *)
let syn = get_syntax_map task in let ops = on_meta arith_meta (fun acc meta_arg ->
let l =
match !arith_symbols with
| None ->
let find_int = find_th env "int" "Int" in
int_minus := find_int "prefix -";
let find_real = find_th env "real" "Real" in
real_minus := find_real "prefix -";
let no_overflow_single = find_single_theory "no_overflow" in
match meta_arg with match meta_arg with
| [MAls ls;MAstr s;MAstr op;MAstr rev_op] -> | [MAls ls; MAstr s; MAstr op; MAstr rev_op] ->
Mls.add ls (s,op,rev_op) acc Mls.add ls (s,op,rev_op) acc
| _ -> assert false) Mls.empty task in | _ -> assert false) Mls.empty task in
ops_of_rels := ops;
(* sets of known symbols *) (* sets of known symbols *)
let l = Mid.map (Util.const ()) syn in let syn = get_syntax_map task in
let l = Mls.fold (fun ls _ acc -> Sid.add ls.ls_name acc) ops l in let symb = Mid.map (Util.const ()) syn in
let l = let symb = Mls.fold (fun ls _ acc -> Sid.add ls.ls_name acc) ops symb in
List.fold_right (fun ls -> Sid.add ls.ls_name) let symb = Sid.add ps_equ.ls_name symb in
[ps_equ] l
in
arith_symbols := Some l;
inline :=
List.fold_left
(fun acc ls -> Sls.add ls acc)
Sls.empty
[ real_lei ;
l
| Some l -> l
in
info_symbols = l; info_symbols = symb;
info_ops_of_rel = !ops_of_rels; info_ops_of_rel = ops;
info_syn = syn; info_syn = syn;
info_rem = get_remove_set task; info_rem = get_remove_set task;
