Commit ce83f94d authored by Andrei Paskevich's avatar Andrei Paskevich
Term: the result type of a constructor must cover every type variable
also, remove the useless ?constr parameter of create_psymbol
parent 3a8f5e2d
...@@ -69,20 +69,27 @@ let check_opaque opaque args value = ...@@ -69,20 +69,27 @@ let check_opaque opaque args value =
let s = List.fold_left diff (Opt.fold diff opaque value) args in let s = List.fold_left diff (Opt.fold diff opaque value) args in
if Stv.is_empty s then opaque else invalid_arg "Term.create_lsymbol" if Stv.is_empty s then opaque else invalid_arg "Term.create_lsymbol"
let check_constr constr args value =
if constr = 0 then constr else
if constr < 0 then invalid_arg "Term.create_lsymbol" else
let tva = List.fold_left ty_freevars Stv.empty args in
let tvv = oty_freevars Stv.empty value in
if value <> None && Stv.subset tva tvv then
constr else invalid_arg "Term.create_lsymbol"
let create_lsymbol ?(opaque=Stv.empty) ?(constr=0) name args value = { let create_lsymbol ?(opaque=Stv.empty) ?(constr=0) name args value = {
ls_name = id_register name; ls_name = id_register name;
ls_args = args; ls_args = args;
ls_value = value; ls_value = value;
ls_opaque = check_opaque opaque args value; ls_opaque = check_opaque opaque args value;
ls_constr = if constr = 0 || (constr > 0 && value <> None) ls_constr = check_constr constr args value;
then constr else invalid_arg "Term.create_lsymbol";
let create_fsymbol ?opaque ?constr nm al vl = let create_fsymbol ?opaque ?constr nm al vl =
create_lsymbol ?opaque ?constr nm al (Some vl) create_lsymbol ?opaque ?constr nm al (Some vl)
let create_psymbol ?opaque ?constr nm al = let create_psymbol ?opaque nm al =
create_lsymbol ?opaque ?constr nm al None create_lsymbol ?opaque ~constr:0 nm al None
let ls_ty_freevars ls = let ls_ty_freevars ls =
let acc = oty_freevars Stv.empty ls.ls_value in let acc = oty_freevars Stv.empty ls.ls_value in
...@@ -58,7 +58,7 @@ val create_fsymbol : ...@@ -58,7 +58,7 @@ val create_fsymbol :
?opaque:Stv.t -> ?constr:int -> preid -> ty list -> ty -> lsymbol ?opaque:Stv.t -> ?constr:int -> preid -> ty list -> ty -> lsymbol
val create_psymbol : val create_psymbol :
?opaque:Stv.t -> ?constr:int -> preid -> ty list -> lsymbol ?opaque:Stv.t -> preid -> ty list -> lsymbol
val ls_ty_freevars : lsymbol -> Stv.t val ls_ty_freevars : lsymbol -> Stv.t
