GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
ce76d88f
ce76d88f
MARCHE Claude
release 0.82
5663e8aa
3
3 changed files
39 additions
17 deletions
+39
-17
CHANGES
CHANGES
+14
-13
Makefile.in
Makefile.in
+22
-1
ROADMAP
ROADMAP
+3
-3
CHANGES
ce76d88f
@@ -2,8 +2,8 @@
@@ -2,8 +2,8 @@
* marks an incompatible change
version 0.82, December
9
, 2013
12
, 2013
o lemma functions
o lemma functions
o polymorphic recursion permitted
@@ -29,16 +29,17 @@ version 0.82, December 9, 2013
* [emacs] why.el renamed to why3.el
* [GTK sourceview] why.lang renamed to why3.lang
* Loc.try[1-7] functions now take location as an optional parameter
* [fix] remove extra leading zeros in decimal literals when a prover don't like them
o [fix] remove extra leading zeros in decimal literals when a prover don't like them
* [fix] PVS output: types are always non-empty
o [fix] PVS output: types are always non-empty
* [fix] PVS: fixed configuration and installation process
o [fix] PVS: fixed configuration and installation process
* [fix] Coq tactic: now loads dynamic plug-ins
o [fix] Coq tactic: now loads dynamic plug-ins
* [fix] bug #15493: correct Coq output for polymorphic algebraic data types
o [fix] bug #15493: correct Coq output for polymorphic algebraic data types
* [fix] wish #15053: Remove proof time from "Goals proved by only one prover" section of why3session info --stats
* [fix] bug #13736: why3ml was slow when there are many inclusions
* [fix] bug #16488: decimals in TPTP syntax
o [fix] bug #13736: why3ml was slow when there are many inclusions
* [fix] bug #16454: do not send arithmetic triggers anymore to alt-Ergo
o [fix] bug #16488: decimals in TPTP syntax
* [fix] syntax highlighting bugs: should be fixed by removing the old language
o [fix] bug #16454: do not send arithmetic triggers anymore to alt-Ergo
o [fix] syntax highlighting bugs: should be fixed by removing the old language
file alt-ergo.lang from alt-ergo distribution
version 0.81, March 25, 2013
Makefile.in
ce76d88f
@@ -1693,7 +1693,7 @@ DISTRIB_FILES = Version Makefile.in configure.in configure \
src/
.ml
src/
.dep src/
.ml
src/
.dep src/
.c
src/
.ml
src/
.dep src/
.ml
src/
.dep src/
.c
plugins/printer/.keepme plugins/
.ml
plugins/
.dep
.ml
plugins/
.dep
lib/why3/META.in lib/why3/why3.ml
bin
/why3-call-pvs
lib
/why3-call-pvs
doc/version.tex.in doc/manual.pdf
drivers/
.drv drivers/
.gen
drivers/
.drv drivers/
.gen
examples/
.mlw examples/logic/
.why
examples/
.why
@@ -1705,11 +1705,17 @@ DISTRIB_FILES = Version Makefile.in configure.in configure \
examples/foveoos11-cm/
.mlw
.mlw
examples/
.xml examples/
.xml examples/
.xml
examples/
.xml examples/
.xml examples/
.xml
examples/
.v examples/
.v examples/
.v
examples/
.v examples/
.v examples/
.v
examples/
.pvs examples/
.pvs examples/
.pvs
examples/
.prf examples/
.prf examples/
.prf
examples/
.thy examples/
.thy examples/
.thy
examples/use_api/
.ml
examples/use_api/
.ml
theories/
.why
theories/
.why
modules/
.mlw
modules/
.mlw
lib/coq/
.v lib/coq/
.v lib/coq-tactic/
.v
lib/coq/
.v lib/coq/
.v lib/coq-tactic/
.v
lib/pvs/
.pvs lib/pvs/
.prf
lib/pvs/
.pvs lib/pvs/
.prf
lib/isabelle/why3.ML lib/isabelle/ROOT lib/isabelle/
.thy
lib/isabelle/etc lib/isabelle/Tools
lib/ocaml/
.ml lib/ocaml/
.dep
share/provers-detection-data.conf
share/why3session.dtd
share/javascript/
.js share/javascript/
.css
share/javascript/
.css
@@ -1754,6 +1760,21 @@ $(DISTRIB_TAR): doc/manual.pdf
$(COQPGENERATED)
$(WHY3DOCGENERATED)
$(PLUGGENERATED)
$(COQPGENERATED)
$(WHY3DOCGENERATED)
$(PLUGGENERATED)
cd
distrib
tar
cf
$(NAME)
.tar
$(NAME)
gzip
-f
--best
$(NAME)
.tar
cd
distrib
tar
cf
$(NAME)
.tar
$(NAME)
gzip
-f
--best
$(NAME)
.tar
EXTRA_DIST
configure doc/manual.pdf
dist
$(EXTRA_DIST)
rm
-rf
$(DISTRIB_TAR)
$(DISTRIB_DIR)
mkdir
$(DISTRIB_DIR)
for
d
in
git ls-tree
-d
-r
--name-only
HEAD
do
mkdir
$(DISTRIB_DIR)
d
done
for
f
in
git ls-tree
-r
--name-only
HEAD
$(EXTRA_DIST)
do
cp
f
$(DISTRIB_DIR)
f
done
rm
find
$(DISTRIB_DIR)
-name
.gitignore
rm
-rf
$(DISTRIB_DIR)
/examples/in_progress
rm
-rf
$(DISTRIB_DIR)
/misc
cd
$(DISTRIB_DIR)
rm
ROADMAP DEVELOPER.readme
cd
distrib
tar
cf
$(NAME)
.tar
$(NAME)
gzip
-f
--best
$(NAME)
.tar
# distrib export: source export-doc export-www export-examples export-examples-c linux
# export-www:
# export-www:
ROADMAP
ce76d88f
@@ -214,8 +214,8 @@ Scheduled for 9 december 2013
* check the file CHANGES, add the release date
* manual in PDF: check that macro \todo is commented out
in ./macros.tex, and then "make doc"
* manual in HTML: "make doc/html/index.html"
(check that manual in HTML is also generated, doc/html/index.html)
* do "make dist
rib
* do "make dist"
* test distrib/why3-0.82.tar.gz
* install web page for why2 which includes an updated page for the
quick migration guide. (sources are in CVS repository
@@ -245,7 +245,7 @@ Scheduled for 9 december 2013
rm /users/www-perso/projets/why3/api
ln -s /users/www-perso/projets/why3/api-0.82 \
PROBLEME avec style.css
(PROBLEME avec style.css ? Ou est le probleme ?)
- update the main HTML page (sources are in repository why3-www)
edit index.html
edit index.html
make export
make export
