Commit ce5c39a0 authored by MARCHE Claude's avatar MARCHE Claude
Merge branch 'next' into new_ide
parents eab4e2b7 ea5c8ece
...@@ -220,6 +220,8 @@ let loadpath m = ...@@ -220,6 +220,8 @@ let loadpath m =
Strings.split ':' d Strings.split ':' d
with Not_found -> m.loadpath with Not_found -> m.loadpath
let set_loadpath m l = { m with loadpath = l}
let timelimit m = m.timelimit let timelimit m = m.timelimit
let memlimit m = m.memlimit let memlimit m = m.memlimit
let running_provers_max m = m.running_provers_max let running_provers_max m = m.running_provers_max
...@@ -72,6 +72,8 @@ val set_main : config -> main -> config ...@@ -72,6 +72,8 @@ val set_main : config -> main -> config
val libdir: main -> string val libdir: main -> string
val datadir: main -> string val datadir: main -> string
val loadpath: main -> string list val loadpath: main -> string list
val set_loadpath : main -> string list -> main
val default_loadpath : string list
val timelimit: main -> int val timelimit: main -> int
val memlimit: main -> int val memlimit: main -> int
val running_provers_max: main -> int val running_provers_max: main -> int
...@@ -24,6 +24,7 @@ let usage_msg = ...@@ -24,6 +24,7 @@ let usage_msg =
let conf_file = ref None let conf_file = ref None
let autoprovers = ref false let autoprovers = ref false
let autoplugins = ref false let autoplugins = ref false
let resetloadpath = ref false
let opt_list_prover_ids = ref false let opt_list_prover_ids = ref false
...@@ -49,8 +50,8 @@ let option_list = Arg.align [ ...@@ -49,8 +50,8 @@ let option_list = Arg.align [
" search for provers in $PATH"; " search for provers in $PATH";
"--detect-plugins", Arg.Set autoplugins, "--detect-plugins", Arg.Set autoplugins,
" search for plugins in the default library directory"; " search for plugins in the default library directory";
"--detect", Arg.Unit (fun () -> autoprovers := true; autoplugins := true), "--detect", Arg.Unit (fun () -> resetloadpath := true; autoprovers := true; autoplugins := true),
" search for both provers and plugins"; " search for both provers and plugins, and resets the default loadpath";
"--add-prover", Arg.Tuple "--add-prover", Arg.Tuple
(let id = ref "" in (let id = ref "" in
[Arg.Set_string id; [Arg.Set_string id;
...@@ -162,7 +163,12 @@ let main () = ...@@ -162,7 +163,12 @@ let main () =
if not (Sys.file_exists conf_file) then begin if not (Sys.file_exists conf_file) then begin
autoprovers := true; autoprovers := true;
autoplugins := true; autoplugins := true;
end; end;
let config =
if !resetloadpath then
set_main config (set_loadpath (get_main config) default_loadpath)
else config
in
let config = let config =
if !autoprovers if !autoprovers
then Autodetection.run_auto_detection config then Autodetection.run_auto_detection config
