GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
cc748e4f
cc748e4f
Andrei Paskevich
Parser: fix erroneous variable redefinition
thanks to Sylvain for noticing.
2c43796b
src/parser/parser.mly
cc748e4f
@@ -969,8 +969,8 @@ single_expr_:
let
e
e
expr_desc
Ewhile
e1
inv
var
cont
e2
in
let
e
e
expr_desc
Ewhile
e1
inv
var
cont
e2
in
let
id
id
id_str
id
id_str
break_id
in
let
id
id
id_str
id
id_str
break_id
in
Eoptexn
id
Ity
MaskVisible
e
Eoptexn
id
Ity
MaskVisible
e
Efor
i
d
ef
dir
et
inv
e1
Efor
i
ef
dir
et
inv
e1
let
e
e
expr_desc
Efor
i
d
ef
dir
et
inv
cont
e1
in
let
e
e
expr_desc
Efor
i
ef
dir
et
inv
cont
e1
in
let
id
id
id_str
id
id_str
break_id
in
let
id
id
id_str
id
id_str
break_id
in
Eoptexn
id
Ity
MaskVisible
e
Eoptexn
id
Ity
MaskVisible
e
d
d
in
d
d
in
@@ -981,7 +981,7 @@ single_expr_:
let
e
5
expr_desc
Eoptexn
id_c
Ity
MaskVisible
5
in
let
e
5
expr_desc
Eoptexn
id_c
Ity
MaskVisible
5
in
let
e
mk_expr
Ewhile
2
fst
4
snd
4
e
startpos
endpos
in
let
e
mk_expr
Ewhile
2
fst
4
snd
4
e
startpos
endpos
in
Eoptexn
id_b
Ity
MaskVisible
e
Eoptexn
id_b
Ity
MaskVisible
e
FOR
lident_nq
EQUAL
seq_expr
for_dir
ection
seq_expr
DO
invariant
loop_body
DONE
FOR
lident_nq
EQUAL
seq_expr
for_dir
seq_expr
DO
invariant
loop_body
DONE
let
id_b
mk_id
break_id
startpos
7
endpos
7
in
let
id_b
mk_id
break_id
startpos
7
endpos
7
in
let
id_c
mk_id
continue_id
startpos
7
endpos
7
in
let
id_c
mk_id
continue_id
startpos
7
endpos
7
in
let
e
9
expr_desc
Eoptexn
id_c
Ity
MaskVisible
9
in
let
e
9
expr_desc
Eoptexn
id_c
Ity
MaskVisible
9
in
@@ -1100,7 +1100,7 @@ assertion_kind:
ASSUME
Expr
Assume
ASSUME
Expr
Assume
CHECK
Expr
Check
CHECK
Expr
Check
for_dir
ection
for_dir
TO
Expr
To
TO
Expr
To
DOWNTO
Expr
DownTo
DOWNTO
Expr
DownTo
