eval_match: better names during tuple destruction
parent e55e1d35
...@@ -84,12 +84,32 @@ let unfold_inlineable kn ls tl ty = match find_inlineable kn ls with ...@@ -84,12 +84,32 @@ let unfold_inlineable kn ls tl ty = match find_inlineable kn ls with
Some (t_ty_subst (oty_match mt e.t_ty ty) mv e) Some (t_ty_subst (oty_match mt e.t_ty ty) mv e)
| None -> None | None -> None
exception FoundIdl of preid list
let rec add_quant kn (vl,tl,f) ({vs_ty = ty} as v) = let rec add_quant kn (vl,tl,f) ({vs_ty = ty} as v) =
match destructible kn ty with match destructible kn ty with
| Some ls -> | Some ls ->
let s = ty_match Mtv.empty (Opt.get ls.ls_value) ty in let s = ty_match Mtv.empty (Opt.get ls.ls_value) ty in
let mk_v ty = create_vsymbol (id_clone v.vs_name) (ty_inst s ty) in let mk_v id ty = create_vsymbol id (ty_inst s ty) in
let nvl = List.map mk_v ls.ls_args in let clone id = List.map (fun _ -> id_clone id) ls.ls_args in
let rec lookup_names f = match f.t_node with
| Tcase ({t_node = Tvar u}, [bt]) when vs_equal u v ->
begin match (fst (t_open_branch bt)).pat_node with
| Pvar x -> raise (FoundIdl (clone x.vs_name))
| Papp (cs, pl) when ls_equal ls cs ->
let name p = match p.pat_node with
| Pvar x -> id_clone x.vs_name
| _ -> id_clone v.vs_name in
raise (FoundIdl (List.map name pl))
| Papp _ | Pwild | Por _ | Pas _ -> ()
| Tcase (t, [bt]) ->
lookup_names t; lookup_names (snd (t_open_branch bt))
| Tcase (t, _) | Tbinop (Timplies, _, t) -> lookup_names t
| Tquant (_, qf) -> let _,_,f = t_open_quant qf in lookup_names f
| _ -> () in
let idl = try lookup_names f; clone v.vs_name with FoundIdl idl -> idl in
let nvl = List.map2 mk_v idl ls.ls_args in
let t = fs_app ls (List.map t_var nvl) ty in let t = fs_app ls (List.map t_var nvl) ty in
let f = t_let_close_simp v t f in let f = t_let_close_simp v t f in
let tl = tr_map (t_subst_single v t) tl in let tl = tr_map (t_subst_single v t) tl in
