Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit c9b80a74 authored by Mário Pereira's avatar Mário Pereira
Compile: cosmetic
parent 45a76d04
......@@ -233,7 +233,7 @@ module Translate = struct
(* remove ghost components from tuple, using mask *)
let visible_of_mask m sl = match m with
| MaskGhost -> assert false (* FIXME *)
| MaskGhost -> assert false (* FIXME ? *)
| MaskVisible -> sl
| MaskTuple ml ->
let add_ity acc m ity = if mask_ghost m then acc else ity :: acc in
......@@ -299,19 +299,17 @@ module Translate = struct
(* individual types *)
let mlty_of_ity mask t =
let rec loop t = match t.ity_node with
| _ when mask_ghost mask ->
ML.tunit
| Ityvar (tvs, _) ->
Mltree.Tvar tvs
| Ityapp ({its_ts = ts}, itl, _) when is_ts_tuple ts ->
let itl = List.rev (visible_of_mask mask itl) in
Mltree.Ttuple (List.map loop itl)
| Ityapp ({its_ts = ts}, itl, _) ->
Mltree.Tapp (ts.ts_name, List.map loop itl)
| Ityreg {reg_its = its; reg_args = args} ->
let args = List.map loop args in
Mltree.Tapp (its.its_ts.ts_name, args) in
| _ when mask_ghost mask -> ML.tunit
| Ityvar (tvs, _) ->
Mltree.Tvar tvs
loop t
let pvty pv =
......@@ -625,12 +623,9 @@ module Translate = struct
(* assert false (\*TODO*\) *)
and ebranch info ({pp_pat = p; pp_mask = m}, e) =
(* If the [case] expression is not ghost but there is (at least) one ghost
branch, then it must be the case that this is an effectful [case],
i.e., at least one of the non-ghost branches is effectful. In extract
code, the onlye sound meaning for this [case] expression is to keep for
each branch the effectul sub-expression. This is similar to the case
of a [let x = e1 in e2] where [x] is a ghost [pvsymbol] *)
(* if the [case] expression is not ghost but there is (at least) one ghost
branch, then it must be the case that all the branches return [unit]
and at least one of the non-ghost branches is effectful *)
if e.e_effect.eff_ghost then (pat m p, ML.mk_unit)
else (pat m p, expr info e)
......@@ -683,7 +678,7 @@ module Translate = struct
let rec fun_expr_of_mask mask e =
let open Mltree in
let mk_e e_node = { e with e_node = e_node } in
(* assert (mask <> MaskGhost); *)
match e.e_node with
| Econst _ | Evar _ | Efun _ | Eassign _ | Ewhile _
| Efor _ | Eraise _ | Eexn _ | Eabsurd | Ehole -> e
......@@ -725,15 +720,9 @@ module Translate = struct
(* raise (ExtractionVal _rs) *)
| PDlet (LDsym (_, {c_node = Cfun e})) when is_val e.e_node ->
| PDlet (LDsym ({rs_cty = cty} as rs, {c_node = Cfun e; c_cty = _c_cty})) ->
| PDlet (LDsym ({rs_cty = cty} as rs, {c_node = Cfun e})) ->
let args = params cty.cty_args in
(* let open Format in *)
(* let pr_mask fmt = function *)
(* | MaskVisible -> fprintf fmt "Visible@." *)
(* | MaskTuple _ -> fprintf fmt "Tuple@." *)
(* | MaskGhost -> fprintf fmt "Ghost@." in *)
let res = mlty_of_ity cty.cty_mask cty.cty_result in
(* eprintf "Mask of %s:%a@." rs.rs_name.id_string pr_mask c_cty.cty_mask; *)
let e = expr info e in
let e = fun_expr_of_mask cty.cty_mask e in
[Mltree.Dlet (Mltree.Lsym (rs, res, args, e))]
