Commit c7f19ca0 authored by Andrei Paskevich's avatar Andrei Paskevich
more agressive simplifications in Eliminate_algebraic
parent a38672c9
...@@ -145,7 +145,7 @@ end ...@@ -145,7 +145,7 @@ end
module CompileTerm = Compile (struct module CompileTerm = Compile (struct
type action = term type action = term
type branch = term_branch type branch = term_branch
let mk_let v s t = t_let_close v s t let mk_let v s t = t_let_close_simp v s t
let mk_branch p t = t_close_branch p t let mk_branch p t = t_close_branch p t
let mk_case t bl = t_case t bl let mk_case t bl = t_case t bl
end) end)
...@@ -153,7 +153,7 @@ end) ...@@ -153,7 +153,7 @@ end)
module CompileFmla = Compile (struct module CompileFmla = Compile (struct
type action = fmla type action = fmla
type branch = fmla_branch type branch = fmla_branch
let mk_let v t f = f_let_close v t f let mk_let v t f = f_let_close_simp v t f
let mk_branch p f = f_close_branch p f let mk_branch p f = f_close_branch p f
let mk_case t bl = f_case t bl let mk_case t bl = f_case t bl
end) end)
...@@ -1855,20 +1855,34 @@ let f_if_simp f1 f2 f3 = match f1.f_node, f2.f_node, f3.f_node with ...@@ -1855,20 +1855,34 @@ let f_if_simp f1 f2 f3 = match f1.f_node, f2.f_node, f3.f_node with
| _, _, Ffalse -> f_and_simp f1 f2 | _, _, Ffalse -> f_and_simp f1 f2
| _, _, _ -> if f_equal f2 f3 then f2 else f_if f1 f2 f3 | _, _, _ -> if f_equal f2 f3 then f2 else f_if f1 f2 f3
let f_let_simp t ((_,_,f) as bf) = match f.f_node with let t_let_simp e ((v,_,t) as bt) = match e.t_node with
| Ftrue | Ffalse -> f | _ -> f_let t bf | _ when not (Svs.mem v t.t_vars) -> t
| Tvar _ -> t_subst_single v e t
let f_let_close_simp v t f = match f.f_node with | _ -> t_let e bt
| Ftrue | Ffalse -> f | _ -> f_let_close v t f
let f_let_simp e ((v,_,f) as bf) = match e.t_node with
let f_quant_simp q ((_,_,_,f) as qf) = match f.f_node with | _ when not (Svs.mem v f.f_vars) -> f
| Ftrue | Ffalse -> f | _ -> f_quant q qf | Tvar _ -> f_subst_single v e f
| _ -> f_let e bf
let t_let_close_simp v e t = t_let_simp e (t_close_bound v t)
let f_let_close_simp v e f = f_let_simp e (f_close_bound v f)
let f_quant_simp q ((vl,_,tl,f) as qf) =
if List.for_all (fun v -> Svs.mem v f.f_vars) vl then
f_quant q qf
else
let vl = List.filter (fun v -> Svs.mem v f.f_vars) vl in
let e_vars = e_apply (fun t -> t.t_vars) (fun f -> f.f_vars) in
let tl = List.filter
(List.for_all (fun e -> Svs.subset (e_vars e) f.f_vars)) tl
in
f_quant_close q vl tl f
let f_forall_simp = f_quant_simp Fforall let f_forall_simp = f_quant_simp Fforall
let f_exists_simp = f_quant_simp Fexists let f_exists_simp = f_quant_simp Fexists
let f_quant_close_simp q vl tl f = match f.f_node with let f_quant_close_simp q vl tl f = f_quant_simp q (f_close_quant vl tl f)
| Ftrue | Ffalse -> f | _ -> f_quant_close q vl tl f
let f_forall_close_simp = f_quant_close_simp Fforall let f_forall_close_simp = f_quant_close_simp Fforall
let f_exists_close_simp = f_quant_close_simp Fexists let f_exists_close_simp = f_quant_close_simp Fexists
...@@ -304,8 +304,10 @@ val f_iff_simp : fmla -> fmla -> fmla ...@@ -304,8 +304,10 @@ val f_iff_simp : fmla -> fmla -> fmla
val f_not_simp : fmla -> fmla val f_not_simp : fmla -> fmla
val t_if_simp : fmla -> term -> term -> term val t_if_simp : fmla -> term -> term -> term
val f_if_simp : fmla -> fmla -> fmla -> fmla val f_if_simp : fmla -> fmla -> fmla -> fmla
val t_let_simp : term -> term_bound -> term
val f_let_simp : term -> fmla_bound -> fmla val f_let_simp : term -> fmla_bound -> fmla
val t_let_close_simp : vsymbol -> term -> term -> term
val f_let_close_simp : vsymbol -> term -> fmla -> fmla val f_let_close_simp : vsymbol -> term -> fmla -> fmla
val f_quant_close_simp : quant -> vsymbol list -> trigger list -> fmla -> fmla val f_quant_close_simp : quant -> vsymbol list -> trigger list -> fmla -> fmla
val f_forall_close_simp : vsymbol list -> trigger list -> fmla -> fmla val f_forall_close_simp : vsymbol list -> trigger list -> fmla -> fmla
...@@ -79,7 +79,7 @@ let rec rewriteT kn state t = match t.t_node with ...@@ -79,7 +79,7 @@ let rec rewriteT kn state t = match t.t_node with
match p with match p with
| { pat_node = Papp (cs,pl) } -> | { pat_node = Papp (cs,pl) } ->
let add_var e p pj = match p.pat_node with let add_var e p pj = match p.pat_node with
| Pvar v -> t_let_close v (t_app pj [t1] v.vs_ty) e | Pvar v -> t_let_close_simp v (t_app pj [t1] v.vs_ty) e
| _ -> Printer.unsupportedTerm t uncompiled | _ -> Printer.unsupportedTerm t uncompiled
in in
let pjl = Mls.find cs state.pj_map in let pjl = Mls.find cs state.pj_map in
...@@ -130,7 +130,7 @@ and rewriteF kn state av sign f = match f.f_node with ...@@ -130,7 +130,7 @@ and rewriteF kn state av sign f = match f.f_node with
let hd = t_app cs (List.map t_var vl) t1.t_ty in let hd = t_app cs (List.map t_var vl) t1.t_ty in
match t1.t_node with match t1.t_node with
| Tvar v when Svs.mem v av -> | Tvar v when Svs.mem v av ->
let hd = f_let_close v hd e in if sign let hd = f_let_close_simp v hd e in if sign
then f_forall_close_simp vl [] hd then f_forall_close_simp vl [] hd
else f_exists_close_simp vl [] hd else f_exists_close_simp vl [] hd
| _ -> | _ ->
...@@ -150,7 +150,7 @@ and rewriteF kn state av sign f = match f.f_node with ...@@ -150,7 +150,7 @@ and rewriteF kn state av sign f = match f.f_node with
(rewriteF kn state Svs.empty sign) tr in (rewriteF kn state Svs.empty sign) tr in
let av = List.fold_left (fun s v -> Svs.add v s) av vl in let av = List.fold_left (fun s v -> Svs.add v s) av vl in
let f1 = rewriteF kn state av sign f1 in let f1 = rewriteF kn state av sign f1 in
f_quant q (close vl tr f1) f_quant_simp q (close vl tr f1)
| Fbinop (o, _, _) when (o = Fand && sign) || (o = For && not sign) -> | Fbinop (o, _, _) when (o = Fand && sign) || (o = For && not sign) ->
f_map_sign (rewriteT kn state) (rewriteF kn state av) sign f f_map_sign (rewriteT kn state) (rewriteF kn state av) sign f
| Flet (t1, _) -> | Flet (t1, _) ->
