renamed Mexn -> Mxs
parent 4ba12926
......@@ -375,7 +375,7 @@ type 'a later = pvsymbol Mstr.t -> register_old -> 'a
type dspec_final = {
ds_pre : term list;
ds_post : (pvsymbol * term) list;
ds_xpost : (pvsymbol * term) list Mexn.t;
ds_xpost : (pvsymbol * term) list Mxs.t;
ds_reads : pvsymbol list;
ds_writes : term list;
ds_diverge : bool;
......@@ -775,7 +775,7 @@ let create_invariant pl = List.map to_fmla pl
let create_post ity ql = List.map (fun (v,f) ->
ity_equal_check ity v.pv_ity; Ity.create_post v.pv_vs (to_fmla f)) ql
let create_xpost xql = Mexn.mapi (fun xs ql -> create_post xs.xs_ity ql) xql
let create_xpost xql = Mxs.mapi (fun xs ql -> create_post xs.xs_ity ql) xql
(** User effects *)
......@@ -815,7 +815,7 @@ let effect_of_dspec dsp =
| _ ->
Loc.errorm ?loc:t.t_loc "mutable expression expected" in
let wl, eff = List.fold_left add_write ([], eff_read pvs) dsp.ds_writes in
let eff = Mexn.fold (fun xs _ eff -> eff_raise eff xs) dsp.ds_xpost eff in
let eff = Mxs.fold (fun xs _ eff -> eff_raise eff xs) dsp.ds_xpost eff in
let eff = if dsp.ds_diverge then eff_diverge eff else eff in
wl, eff
......@@ -824,8 +824,8 @@ let effect_of_dspec dsp =
let check_spec inr dsp ecty ({e_loc = loc} as e) =
let bad_read reff eff = not (Spv.subset reff.eff_reads eff.eff_reads) in
let bad_write weff eff = not (Mreg.submap (fun _ s1 s2 -> Spv.subset s1 s2)
weff.eff_writes eff.eff_writes) in
let bad_raise xeff eff = not (Sexn.subset xeff.eff_raises eff.eff_raises) in
let bad_raise xeff eff = not (Sxs.subset xeff.eff_raises eff.eff_raises) in
(* computed effect vs user effect *)
let uwrl, ue = effect_of_dspec dsp in
let ucty = create_cty ecty.cty_args ecty.cty_pre ecty.cty_post
......@@ -847,7 +847,7 @@ let check_spec inr dsp ecty ({e_loc = loc} as e) =
"this@ write@ effect@ does@ not@ happen@ in@ the@ expression") uwrl;
if check_ue && bad_raise ueff eeff then Loc.errorm ?loc
"this@ expression@ does@ not@ raise@ exception@ %a"
print_xs (Sexn.choose (Sexn.diff ueff.eff_raises eeff.eff_raises));
print_xs (Sxs.choose (Sxs.diff ueff.eff_raises eeff.eff_raises));
if check_ue && ueff.eff_oneway && not eeff.eff_oneway then Loc.errorm ?loc
"this@ expression@ does@ not@ diverge";
(* check that every computed effect is listed *)
......@@ -858,10 +858,10 @@ let check_spec inr dsp ecty ({e_loc = loc} as e) =
if check_rw && bad_write eeff ueff then
Loc.errorm ?loc:(e_locate_effect (fun eff -> bad_write eff ueff) e)
"this@ expression@ produces@ an@ unlisted@ write@ effect";
if ecty.cty_args <> [] && bad_raise eeff ueff then Sexn.iter (fun xs ->
Loc.errorm ?loc:(e_locate_effect (fun eff -> Sexn.mem xs eff.eff_raises) e)
if ecty.cty_args <> [] && bad_raise eeff ueff then Sxs.iter (fun xs ->
Loc.errorm ?loc:(e_locate_effect (fun eff -> Sxs.mem xs eff.eff_raises) e)
"this@ expression@ raises@ unlisted@ exception@ %a"
print_xs xs) (Sexn.diff eeff.eff_raises ueff.eff_raises);
print_xs xs) (Sxs.diff eeff.eff_raises ueff.eff_raises);
if eeff.eff_oneway && not ueff.eff_oneway then
Loc.errorm ?loc:(e_locate_effect (fun eff -> eff.eff_oneway) e)
"this@ expression@ may@ diverge,@ but@ this@ is@ not@ \
......@@ -1210,8 +1210,8 @@ and try_expr uloc env ({de_dvty = argl,res} as de0) =
let vm, pat = create_prog_pattern dp.dp_pat xs.xs_ity mask in
let e = expr uloc (add_pv_map env vm) de in
Mstr.iter (fun _ v -> check_used_pv e v) vm;
Mexn.add xs ((pat, e) :: Mexn.find_def [] xs m) m in
let xsm = List.fold_left add_branch Mexn.empty bl in
Mxs.add xs ((pat, e) :: Mxs.find_def [] xs m) m in
let xsm = List.fold_left add_branch Mxs.empty bl in
let is_simple p = match p.pat_node with
| Papp (fs,[]) -> is_fs_tuple fs
| Pvar _ | Pwild -> true | _ -> false in
......@@ -1259,7 +1259,7 @@ and try_expr uloc env ({de_dvty = argl,res} as de0) =
let _,pp = create_prog_pattern PPwild xs.xs_ity mask in
(pp, e_raise xs e (ity_of_dity res)) :: bl in
vl, e_case e (List.rev bl) in
e_try e1 (Mexn.mapi mk_branch xsm)
e_try e1 (Mxs.mapi mk_branch xsm)
| DEraise (xs,de) ->
e_raise xs (expr uloc env de) (ity_of_dity res)
| DEghost de ->
......@@ -1301,7 +1301,7 @@ and rec_defn uloc ({inr = inr} as env) {fds = dfdl} =
let ghost = env.ghs || gh || kind = RKlemma in
let pvl = binders ghost bl in
let ity = Loc.try1 ?loc:de.de_loc ity_of_dity (dity_of_dvty dvty) in
let cty = create_cty ~mask pvl [] [] Mexn.empty Mpv.empty eff_empty ity in
let cty = create_cty ~mask pvl [] [] Mxs.empty Mpv.empty eff_empty ity in
let rs = create_rsymbol id ~ghost ~kind:RKnone cty in
add_rsymbol env rs, (rs, kind, mask, dsp, dvl, de) in
let env, fdl = Lists.map_fold_left step1 {env with inr = true} dfdl in
......@@ -1374,7 +1374,7 @@ let let_defn ?(keep_loc=true) (id, ghost, kind, de) =
let e = expr uloc env_empty de in
if mask_ghost e.e_mask && not ghost then Loc.errorm ?loc
"Function %s must be explicitly marked ghost" nm;
let c = c_fun [] [] [] Mexn.empty Mpv.empty e in
let c = c_fun [] [] [] Mxs.empty Mpv.empty e in
(* the rsymbol will carry a single postcondition "the result
is equal to the logical constant". Any user-written spec
will be checked once, in-place, under Eexec. Since kind
......@@ -64,7 +64,7 @@ type 'a later = pvsymbol Mstr.t -> register_old -> 'a
ds_pre : term list;
ds_diverge : bool;
......@@ -171,7 +171,7 @@ let create_projection s v =
let arg = create_pvsymbol (id_fresh "arg") ity in
let ls = create_fsymbol id [arg.pv_vs.vs_ty] v.pv_vs.vs_ty in
let q = make_post (fs_app ls [t_var arg.pv_vs] v.pv_vs.vs_ty) in
let c = create_cty [arg] [] [q] Mexn.empty Mpv.empty eff v.pv_ity in
let c = create_cty [arg] [] [q] Mxs.empty Mpv.empty eff v.pv_ity in
mk_rs ls.ls_name c (RLls ls) (Some v)
exception FieldExpected of rsymbol
......@@ -198,7 +198,7 @@ let create_constructor ~constr id s fl =
let eff = match ity.ity_node with
| Ityreg r -> eff_reset eff_empty (Sreg.singleton r)
| _ -> eff_empty in
let c = create_cty fl [] [q] Mexn.empty Mpv.empty eff ity in
let c = create_cty fl [] [q] Mxs.empty Mpv.empty eff ity in
mk_rs ls.ls_name c (RLls ls) None
let rs_of_ls ls =
......@@ -207,7 +207,7 @@ let rs_of_ls ls =
let t_args = List.map (fun v -> t_var v.pv_vs) v_args in
let q = make_post (t_app ls t_args ls.ls_value) in
let ity = ity_of_ty (t_type q) in
let c = create_cty v_args [] [q] Mexn.empty Mpv.empty eff_empty ity in
let c = create_cty v_args [] [q] Mxs.empty Mpv.empty eff_empty ity in
(** {2 Program patterns} *)
......@@ -310,7 +310,7 @@ and expr_node =
| Ecase of expr * (prog_pattern * expr) list
| Ewhile of expr * invariant list * variant list * expr
| Efor of pvsymbol * for_bounds * invariant list * expr
| Etry of expr * (pvsymbol list * expr) Mexn.t
| Etry of expr * (pvsymbol list * expr) Mxs.t
| Eraise of xsymbol * expr
| Eassert of assertion_kind * term
| Eghost of expr
......@@ -375,7 +375,7 @@ let e_fold fn acc e = match e.e_node with
| Elet (LDvar (_,d), e) | Ewhile (d,_,_,e) -> fn (fn acc d) e
| Eif (c,d,e) -> fn (fn (fn acc c) d) e
| Ecase (d,bl) -> List.fold_left (fun acc (_,e) -> fn acc e) (fn acc d) bl
| Etry (d,xl) -> Mexn.fold (fun _ (_,e) acc -> fn acc e) xl (fn acc d)
| Etry (d,xl) -> Mxs.fold (fun _ (_,e) acc -> fn acc e) xl (fn acc d)
exception FoundExpr of Loc.position option * expr
......@@ -732,7 +732,7 @@ let c_pur s vl ityl ity =
let res = Opt.map (fun _ -> ty_of_ity ity) s.ls_value in
let q = make_post (t_app s t_args res) in
let eff = eff_ghostify true eff_empty in
let cty = create_cty v_args [] [q] Mexn.empty Mpv.empty eff ity in
let cty = create_cty v_args [] [q] Mxs.empty Mpv.empty eff ity in
mk_cexp (Cpur (s,vl)) cty
let mk_proxy ghost e hd = match e.e_node with
......@@ -806,7 +806,7 @@ let rs_func_app = rs_of_ls fs_func_app
let ld_func_app =
let v_args = rs_func_app.rs_cty.cty_args in
let ity = rs_func_app.rs_cty.cty_result in
let c = create_cty v_args [] [] Mexn.empty Mpv.empty eff_empty ity in
let c = create_cty v_args [] [] Mxs.empty Mpv.empty eff_empty ity in
LDsym (rs_func_app, c_any c)
let e_func_app fn e =
......@@ -906,19 +906,19 @@ let e_try e xl =
| [v] -> v.pv_ity, mask_of_pv v
| vl -> ity_tuple (List.map (fun v -> v.pv_ity) vl),
MaskTuple (List.map mask_of_pv vl) in
Mexn.iter (fun xs (vl,d) ->
Mxs.iter (fun xs (vl,d) ->
let ity, mask = get_mask vl in
if mask_spill xs.xs_mask mask then
Loc.errorm "Non-ghost pattern in a ghost position";
ity_equal_check ity xs.xs_ity;
ity_equal_check d.e_ity e.e_ity) xl;
let ghost = e.e_effect.eff_ghost in
let eeff = Mexn.fold (fun xs _ eff ->
let eeff = Mxs.fold (fun xs _ eff ->
eff_catch eff xs) xl e.e_effect in
let dl = Mexn.fold (fun _ (_,d) l -> d::l) xl [] in
let dl = Mxs.fold (fun _ (_,d) l -> d::l) xl [] in
let add_mask mask d = mask_union mask d.e_mask in
let mask = List.fold_left add_mask e.e_mask dl in
let xeff = Mexn.fold (fun _ (vl,d) eff ->
let xeff = Mxs.fold (fun _ (vl,d) eff ->
let add s v = Spv.add_new (Invalid_argument "Expr.e_try") v s in
let deff = eff_bind (List.fold_left add Spv.empty vl) d.e_effect in
try_effect dl eff_union_par eff deff) xl eff_empty in
......@@ -984,7 +984,7 @@ let rec e_rs_subst sm e = e_label_copy e (match e.e_node with
| Ecase (d,bl) -> e_case (e_rs_subst sm d)
(List.map (fun (pp,e) -> pp, e_rs_subst sm e) bl)
| Etry (d,xl) -> e_try (e_rs_subst sm d)
(Mexn.map (fun (v,e) -> v, e_rs_subst sm e) xl))
(Mxs.map (fun (v,e) -> v, e_rs_subst sm e) xl))
and c_rs_subst sm ({c_node = n; c_cty = c} as d) = match n with
| Cany | Cpur _ -> d
......@@ -1311,7 +1311,7 @@ and print_enode pri fmt e = match e.e_node with
| Eraise (xs,e) ->
fprintf fmt "raise (%a %a)" print_xs xs print_expr e
| Etry (e,bl) ->
let bl = Mexn.bindings bl in
let bl = Mxs.bindings bl in
fprintf fmt "try %a with@\n@[<hov>%a@]@\nend"
print_expr e (Pp.print_list Pp.newline print_xbranch) bl
| Eabsurd ->
......@@ -124,7 +124,7 @@ and expr_node = private
| Eghost of expr
......@@ -182,7 +182,7 @@ val c_app : rsymbol -> pvsymbol list -> ity list -> ity -> cexp
val c_pur : lsymbol -> pvsymbol list -> ity list -> ity -> cexp
val c_fun : ?mask:mask -> pvsymbol list ->
pre list -> post list -> post list Mexn.t -> pvsymbol Mpv.t -> expr -> cexp
pre list -> post list -> post list Mxs.t -> pvsymbol Mpv.t -> expr -> cexp
val c_any : cty -> cexp
......@@ -218,7 +218,7 @@ val is_e_false : expr -> bool
val e_raise : xsymbol -> expr -> ity -> expr
val e_try : expr -> (pvsymbol list * expr) Mexn.t -> expr
val e_try : expr -> (pvsymbol list * expr) Mxs.t -> expr
val e_case : expr -> (prog_pattern * expr) list -> expr
......@@ -862,8 +862,8 @@ module Exn = MakeMSH (struct
let tag xs = Weakhtbl.tag_hash xs.xs_name.id_tag
end)
module Sexn = Exn.S
module Mexn = Exn.M
module Sxs = Exn.S
module Mxs = Exn.M
(* effects *)
......@@ -883,7 +883,7 @@ type effect = {
eff_taints : Sreg.t; (* ghost code writes *)
eff_covers : Sreg.t; (* surviving writes *)
eff_resets : Sreg.t; (* locked by covers *)
eff_raises : Sexn.t; (* raised exceptions *)
eff_raises : Sxs.t; (* raised exceptions *)
eff_oneway : bool; (* non-termination *)
eff_ghost : bool; (* ghost status *)
......@@ -894,7 +894,7 @@ let eff_empty = {
eff_taints = Sreg.empty;
eff_covers = Sreg.empty;
eff_resets = Sreg.empty;
eff_raises = Sexn.empty;
eff_raises = Sxs.empty;
eff_oneway = false;
eff_ghost = false;
......@@ -905,13 +905,13 @@ let eff_equal e1 e2 =
Sreg.equal e1.eff_taints e2.eff_taints &&
Sreg.equal e1.eff_covers e2.eff_covers &&
Sreg.equal e1.eff_resets e2.eff_resets &&
Sexn.equal e1.eff_raises e2.eff_raises &&
Sxs.equal e1.eff_raises e2.eff_raises &&
e1.eff_oneway = e2.eff_oneway &&
e1.eff_ghost = e2.eff_ghost
let eff_pure e =
Mreg.is_empty e.eff_writes &&
Sexn.is_empty e.eff_raises &&
Sxs.is_empty e.eff_raises &&
not e.eff_oneway
let check_writes {eff_writes = wrt} pvs =
......@@ -951,7 +951,7 @@ let eff_ghostify gh e =
let eff_ghostify_weak gh e =
if not gh || e.eff_ghost then e else
if e.eff_oneway || not (Sexn.is_empty e.eff_raises) then e else
if e.eff_oneway || not (Sxs.is_empty e.eff_raises) then e else
if not (Sreg.equal e.eff_taints (visible_writes e)) then e else
(* it is not enough to catch BadGhostWrite from eff_ghostify below,
because e may not have in eff_reads the needed visible variables
......@@ -1083,7 +1083,7 @@ let eff_assign asl =
eff_taints = taint;
eff_covers = Mreg.domain (Mreg.set_diff writes resets);
eff_resets = resets;
eff_oneway = false;
eff_ghost = ghost } in
(* verify that we can rebuild every value *)
......@@ -1108,8 +1108,8 @@ let eff_reset_overwritten ({eff_writes = wr} as e) =
let svv, rst = Mreg.fold add_write wr (Sreg.empty,Sreg.empty) in
{ e with eff_resets = Sreg.diff rst svv }
let eff_raise e x = { e with eff_raises = Sexn.add x e.eff_raises }
let eff_catch e x = { e with eff_raises = Sexn.remove x e.eff_raises }
let eff_raise e x = { e with eff_raises = Sxs.add x e.eff_raises }
let eff_catch e x = { e with eff_raises = Sxs.remove x e.eff_raises }
let merge_fields _ f1 f2 = Some (Spv.union f1 f2)
......@@ -1123,7 +1123,7 @@ let eff_union e1 e2 = {
eff_covers = Sreg.union (remove_stale e2 e1.eff_covers)
(remove_stale e1 e2.eff_covers);
eff_resets = Sreg.union e1.eff_resets e2.eff_resets;
eff_raises = Sexn.union e1.eff_raises e2.eff_raises;
eff_raises = Sxs.union e1.eff_raises e2.eff_raises;
eff_oneway = e1.eff_oneway || e2.eff_oneway;
eff_ghost = e1.eff_ghost && e2.eff_ghost }
......@@ -1142,12 +1142,12 @@ let eff_union e1 e2 =
let eff_contaminate e1 e2 =
if not e1.eff_ghost then e2 else
if Sexn.is_empty e1.eff_raises then e2 else
if Sxs.is_empty e1.eff_raises then e2 else
eff_ghostify true e2
let eff_contaminate_weak e1 e2 =
if Sexn.is_empty e1.eff_raises then eff_ghostify_weak true e2 else
if Sxs.is_empty e1.eff_raises then eff_ghostify_weak true e2 else
let eff_union_par e1 e2 =
......@@ -1221,7 +1221,7 @@ type cty = {
cty_args : pvsymbol list;
cty_pre : pre list;
cty_post : post list;
cty_xpost : post list Mexn.t;
cty_xpost : post list Mxs.t;
cty_oldies : pvsymbol Mpv.t;
cty_effect : effect;
cty_result : ity;
......@@ -1256,7 +1256,7 @@ let cty_ghostify gh ({cty_effect = eff} as c) =
let spec_t_fold fn_t acc pre post xpost =
let fn_l a fl = List.fold_left fn_t a fl in
let acc = fn_l (fn_l acc pre) post in
Mexn.fold (fun _ l a -> fn_l a l) xpost acc
Mxs.fold (fun _ l a -> fn_l a l) xpost acc
let check_tvs reads result pre post xpost =
(* every type variable in spec comes either from a known vsymbol
......@@ -1284,7 +1284,7 @@ let create_cty ?(mask=MaskVisible) args pre post xpost oldies effect result =
let exn = Invalid_argument "Ity.create_cty" in
(* pre, post, and xpost are well-typed *)
check_pre pre; check_post exn result post;
Mexn.iter (fun xs xq -> check_post exn xs.xs_ity xq) xpost;
Mxs.iter (fun xs xq -> check_post exn xs.xs_ity xq) xpost;
(* mask is consistent with result *)
mask_check exn result mask;
let mask = mask_reduce mask in
......@@ -1295,7 +1295,7 @@ let create_cty ?(mask=MaskVisible) args pre post xpost oldies effect result =
reads are forbidden, to simplify instantiation later. *)
Mpv.iter (fun {pv_ghost = gh; pv_ity = o} {pv_ity = t} ->
if not (gh && o == ity_purify t) then raise exn) oldies;
let preads = spec_t_fold t_freepvs sarg pre [] Mexn.empty in
let preads = spec_t_fold t_freepvs sarg pre [] Mxs.empty in
let qreads = spec_t_fold t_freepvs Spv.empty [] post xpost in
let effect = eff_read_post effect qreads in
let oldies = Mpv.set_inter oldies effect.eff_reads in
......@@ -1311,7 +1311,7 @@ let create_cty ?(mask=MaskVisible) args pre post xpost oldies effect result =
| _, {t_node = Tfalse} -> true | _ -> false in
let filter _ () = function
| [q] when is_false q -> None | _ -> Some () in
let raises = Mexn.diff filter effect.eff_raises xpost in
let raises = Mxs.diff filter effect.eff_raises xpost in
let effect = { effect with eff_raises = raises } in
(* remove effects on unknown regions. We reset eff_taints
instead of simply filtering the existing set in order
......@@ -1388,7 +1388,7 @@ let cty_apply c vl args res =
(fun t -> t_ty_subst tsb vsb t) in
let subst_l l = List.map subst_t l in
cty_unsafe (List.rev rargs) (subst_l c.cty_pre)
(subst_l c.cty_post) (Mexn.map subst_l c.cty_xpost)
(subst_l c.cty_post) (Mxs.map subst_l c.cty_xpost)
oldies eff res c.cty_mask freeze
let cty_tuple args =
......@@ -1401,7 +1401,7 @@ let cty_tuple args =
let eff = eff_read (Spv.of_list args) in
let eff = eff_ghostify (mask = MaskGhost) eff in
let frz = List.fold_right freeze_pv args isb_empty in
cty_unsafe [] [] [post] Mexn.empty Mpv.empty eff res mask frz
cty_unsafe [] [] [post] Mxs.empty Mpv.empty eff res mask frz
let cty_exec_post_raw c =
let ity = List.fold_right (fun a ity ->
......@@ -1465,7 +1465,7 @@ let cty_exec ({cty_effect = eff} as c) =
Still, Expr never uses it like this: it is merely attached to Eexec
to provide the converted specification for VC generation. Pvsymbols
that carry the resulting value, however, cannot be generalized. *)
cty_unsafe [] pre post Mexn.empty Mpv.empty eff ity MaskVisible c.cty_freeze
cty_unsafe [] pre post Mxs.empty Mpv.empty eff ity MaskVisible c.cty_freeze
let cty_exec c = if c.cty_args = [] then c else cty_exec c
......@@ -1485,14 +1485,14 @@ let cty_read_post c pvs =
let cty_add_pre pre c = if pre = [] then c else begin check_pre pre;
let c = cty_read_pre (List.fold_left t_freepvs Spv.empty pre) c in
let rd = List.fold_right Spv.add c.cty_args c.cty_effect.eff_reads in
check_tvs rd c.cty_result pre [] Mexn.empty;
check_tvs rd c.cty_result pre [] Mxs.empty;
{ c with cty_pre = pre @ c.cty_pre } end
let cty_add_post c post = if post = [] then c else begin
check_post (Invalid_argument "Ity.cty_add_post") c.cty_result post;
let c = cty_read_post c (List.fold_left t_freepvs Spv.empty post) in
check_tvs rd c.cty_result [] post Mexn.empty;
check_tvs rd c.cty_result [] post Mxs.empty;
{ c with cty_post = post @ c.cty_post } end
(** pretty-printing *)
......@@ -1666,7 +1666,7 @@ let print_spec args pre post xpost oldies eff fmt ity =
Pp.print_list Pp.nothing print_pre fmt pre;
Pp.print_list Pp.nothing print_old fmt (Mpv.bindings oldies);
Pp.print_list Pp.nothing print_post fmt post;
Pp.print_list Pp.nothing print_xpost fmt (Mexn.bindings xpost)
Pp.print_list Pp.nothing print_xpost fmt (Mxs.bindings xpost)
let print_cty fmt c = print_spec c.cty_args c.cty_pre c.cty_post
c.cty_xpost c.cty_oldies c.cty_effect fmt (Some c.cty_result)
......@@ -322,8 +322,8 @@ type xsymbol = private {
xs_mask : mask;
module Mexn : Extmap.S with type key = xsymbol
module Sexn : Extset.S with module M = Mexn
module Mxs : Extmap.S with type key = xsymbol
module Sxs : Extset.S with module M = Mxs
val xs_compare : xsymbol -> xsymbol -> int
val xs_equal : xsymbol -> xsymbol -> bool
......@@ -349,7 +349,7 @@ type effect = private {
......@@ -402,7 +402,7 @@ type cty = private {
cty_pre : pre list;
cty_result : ity;
......@@ -411,7 +411,7 @@ type cty = private {
val create_cty : ?mask:mask -> pvsymbol list ->
pvsymbol Mpv.t -> effect -> ity -> cty
(** [create_cty ?mask args pre post xpost oldies effect result] creates
a computation type. [post] and [mask] must be consistent with [result].
......@@ -496,5 +496,5 @@ val print_pvty : Format.formatter -> pvsymbol -> unit (* pvsymbol : type *)
val print_cty : Format.formatter -> cty -> unit (* computation type *)
val print_spec :
pvsymbol list -> pre list -> post list -> post list Mexn.t -> pvsymbol Mpv.t
pvsymbol list -> pre list -> post list -> post list Mxs.t -> pvsymbol Mpv.t
-> effect -> Format.formatter -> ity option -> unit (* piecemeal cty *)
......@@ -65,7 +65,7 @@ let create_semi_constructor id s fdl pjl invl =
| _ -> eff_empty in
let c = create_cty fdl invl [q] Mexn.empty Mpv.empty eff ity in
let c = create_cty fdl invl [q] Mxs.empty Mpv.empty eff ity in
create_rsymbol id c
let create_plain_record_decl ~priv ~mut id args fdl invl =
......@@ -186,8 +186,8 @@ let get_syms node pure =
let add_tl syms tl = syms_tl syms tl in
let add_xq xs ql syms = syms_xs xs (add_tl syms ql) in
let syms = add_tl (add_tl syms c.cty_pre) c.cty_post in
let syms = Mexn.fold add_xq c.cty_xpost syms in
Sexn.fold syms_xs c.cty_effect.eff_raises syms in
let syms = Mxs.fold add_xq c.cty_xpost syms in
Sxs.fold syms_xs c.cty_effect.eff_raises syms in
let rec syms_expr syms e = match e.e_node with
| Evar _ | Econst _ | Eabsurd -> syms
| Eassert (_,t) | Epure t -> syms_term syms t
......@@ -226,7 +226,7 @@ let get_syms node pure =
| Etry (d,xl) ->
let add_branch xs (vl,e) syms =
syms_xs xs (syms_pvl (syms_expr syms e) vl) in
Mexn.fold add_branch xl (syms_expr syms d)
Mxs.fold add_branch xl (syms_expr syms d)
| Eraise (xs,e) ->
syms_xs xs (syms_eity syms e)
and syms_eity syms e =
......@@ -623,7 +623,7 @@ let rec eval_expr env (e : expr) : result =
match r with
| Excep(ex,t) ->
begin
match Mexn.find ex el with
match Mxs.find ex el with
| ([], e2) ->
(* assert (t = Vvoid); *)
eval_expr env e2
......@@ -116,7 +116,7 @@ and mod_inst = {
mi_pk : prop_kind Mpr.t;
mi_pv : pvsymbol Mvs.t;
mi_rs : rsymbol Mrs.t;
mi_xs : xsymbol Mexn.t;
mi_xs : xsymbol Mxs.t;
let empty_mod_inst m = {
......@@ -128,7 +128,7 @@ let empty_mod_inst m = {
mi_pk = Mpr.empty;
mi_pv = Mvs.empty;
mi_rs = Mrs.empty;
mi_xs = Mexn.empty;
mi_xs = Mxs.empty;
(** {2 Module under construction} *)
......@@ -364,7 +364,7 @@ type clones = {
mutable fd_table : pvsymbol Mpv.t;
mutable pv_table : pvsymbol Mvs.t;
mutable rs_table : rsymbol Mrs.t;
mutable xs_table : xsymbol Mexn.t;
mutable xs_table : xsymbol Mxs.t;
let empty_clones m = {
......@@ -377,7 +377,7 @@ let empty_clones m = {
fd_table = Mpv.empty;
pv_table = Mvs.empty;
rs_table = Mrs.empty;
xs_table = Mexn.empty;
xs_table = Mxs.empty;
(* populate the clone structure *)
......@@ -468,7 +468,7 @@ let cl_find_rs cl rs =
let cl_find_xs cl xs =
if not (Sid.mem xs.xs_name cl.cl_local) then xs
else Mexn.find xs cl.xs_table
else Mxs.find xs cl.xs_table
let clone_ls inst cl ls =
if Mls.mem ls inst.mi_ls then raise (CannotInstantiate ls.ls_name);
......@@ -526,7 +526,7 @@ let cl_init_xs cl ({xs_name = id} as xs) xs' =
with TypeMismatch _ -> raise (BadInstance id) end;
if mask_spill xs'.xs_mask xs.xs_mask then
raise (BadInstance id);
cl.xs_table <- Mexn.add xs xs' cl.xs_table
cl.xs_table <- Mxs.add xs xs' cl.xs_table
let cl_init_pv cl ({vs_name = id} as vs) pv' =
let pv = restore_pv vs in
......@@ -546,7 +546,7 @@ let cl_init m inst =
Mls.iter (cl_init_ls cl) inst.mi_ls;
Mrs.iter (cl_init_rs cl) inst.mi_rs;
Mvs.iter (cl_init_pv cl) inst.mi_pv;
Mexn.iter (cl_init_xs cl) inst.mi_xs;
Mxs.iter (cl_init_xs cl) inst.mi_xs;
Mpr.iter (cl_init_pr cl) inst.mi_pk;
cl
......@@ -744,10 +744,10 @@ let clone_cty cl sm ?(drop_decr=false) cty =
let pre = if drop_decr then List.tl cty.cty_pre else cty.cty_pre in
let pre = clone_invl cl sm_args pre in
let post = clone_invl cl sm_olds cty.cty_post in
let xpost = Mexn.fold (fun xs fl q ->
let xpost = Mxs.fold (fun xs fl q ->
let xs = cl_find_xs cl xs in
let fl = clone_invl cl sm_olds fl in
Mexn.add xs fl q) cty.cty_xpost Mexn.empty in
Mxs.add xs fl q) cty.cty_xpost Mxs.empty in
let add_read v s = Spv.add (sm_find_pv sm_args v) s in
let reads = Spv.fold add_read (cty_reads cty) Spv.empty in
let reads = List.fold_right add_read cty.cty_args reads in
......@@ -760,7 +760,7 @@ let clone_cty cl sm ?(drop_decr=false) cty =
let resets = Sreg.fold add_reset cty.cty_effect.eff_resets Sreg.empty in
let eff = eff_reset (eff_write reads writes) resets in
let add_raise xs eff = eff_raise eff (cl_find_xs cl xs) in
let eff = Sexn.fold add_raise cty.cty_effect.eff_raises eff in
let eff = Sxs.fold add_raise cty.cty_effect.eff_raises eff in
let eff = if cty.cty_effect.eff_oneway then eff_diverge eff else eff in
let cty = create_cty ~mask:cty.cty_mask args pre post xpost olds eff res in
cty_ghostify (cty_ghost cty) cty
......@@ -826,8 +826,8 @@ let rec clone_expr cl sm e = e_label_copy e (match e.e_node with
let conv_br xs (vl, e) m =
let vl' = List.map (clone_pv cl) vl in
let sm = List.fold_left2 sm_save_pv sm vl vl' in
Mexn.add (cl_find_xs cl xs) (vl', clone_expr cl sm e) m in
e_try (clone_expr cl sm d) (Mexn.fold conv_br xl Mexn.empty)
Mxs.add (cl_find_xs cl xs) (vl', clone_expr cl sm e) m in
e_try (clone_expr cl sm d) (Mxs.fold conv_br xl Mxs.empty)
