Commit c4254b35 authored by Andrei Paskevich's avatar Andrei Paskevich
store the qualifier prefix in Theory.theory.th_path
For built-in and local theories the prefix is empty.
parent fee930ef
...@@ -41,7 +41,7 @@ type find_channel = fformat -> pathname -> filename * in_channel ...@@ -41,7 +41,7 @@ type find_channel = fformat -> pathname -> filename * in_channel
type env = { type env = {
env_find : find_channel; env_find : find_channel;
env_memo : (string list, theory Mstr.t) Hashtbl.t; env_memo : (pathname, theory Mstr.t) Hashtbl.t;
env_tag : Hashweak.tag; env_tag : Hashweak.tag;
...@@ -51,7 +51,8 @@ module Wenv = Hashweak.Make(struct type t = env let tag = env_tag end) ...@@ -51,7 +51,8 @@ module Wenv = Hashweak.Make(struct type t = env let tag = env_tag end)
(** Input formats *) (** Input formats *)
type read_channel = env -> filename -> in_channel -> theory Mstr.t type read_channel =
env -> pathname -> filename -> in_channel -> theory Mstr.t
let read_channel_table = Hashtbl.create 17 (* format name -> read_channel *) let read_channel_table = Hashtbl.create 17 (* format name -> read_channel *)
let extensions_table = Hashtbl.create 17 (* suffix -> format name *) let extensions_table = Hashtbl.create 17 (* suffix -> format name *)
...@@ -76,12 +77,15 @@ let get_format file = ...@@ -76,12 +77,15 @@ let get_format file =
try Hashtbl.find extensions_table ext try Hashtbl.find extensions_table ext
with Not_found -> raise (UnknownExtension ext) with Not_found -> raise (UnknownExtension ext)
let read_channel ?format env file ic = let real_read_channel ?format env path file ic =
let name = match format with let name = match format with
| Some name -> name | Some name -> name
| None -> get_format file in | None -> get_format file in
let rc,_ = lookup_format name in let rc,_ = lookup_format name in
rc env file ic rc env path file ic
real_read_channel ?format env [] file ic
let read_file ?format env file = let read_file ?format env file =
let ic = open_in file in let ic = open_in file in
...@@ -143,7 +147,7 @@ let find_library env sl = ...@@ -143,7 +147,7 @@ let find_library env sl =
let file, ic = env.env_find "why" sl in let file, ic = env.env_find "why" sl in
try try
Hashtbl.replace env.env_memo sl Mstr.empty; Hashtbl.replace env.env_memo sl Mstr.empty;
let mth = read_channel ~format:"why" env file ic in let mth = real_read_channel ~format:"why" env sl file ic in
Hashtbl.replace env.env_memo sl mth; Hashtbl.replace env.env_memo sl mth;
close_in ic; close_in ic;
mth mth
...@@ -44,7 +44,8 @@ exception TheoryNotFound of pathname * string ...@@ -44,7 +44,8 @@ exception TheoryNotFound of pathname * string
open Theory open Theory
type read_channel = env -> filename -> in_channel -> theory Util.Mstr.t type read_channel =
env -> pathname -> filename -> in_channel -> theory Util.Mstr.t
(** a function of type [read_channel] parses a channel using (** a function of type [read_channel] parses a channel using
its own syntax. The string argument indicates the origin of its own syntax. The string argument indicates the origin of
the stream (e.g. file name) to be used in error messages. *) the stream (e.g. file name) to be used in error messages. *)
...@@ -57,8 +58,9 @@ val register_format : fformat -> extension list -> read_channel -> unit ...@@ -57,8 +58,9 @@ val register_format : fformat -> extension list -> read_channel -> unit
@raise KnownFormat [name] if the format is already registered *) @raise KnownFormat [name] if the format is already registered *)
val read_channel : ?format:fformat -> read_channel val read_channel :
(** [read_channel ?format env file ch] returns the theories in [ch]. ?format:fformat -> env -> filename -> in_channel -> theory Util.Mstr.t
(** [read_channel ?format env path file ch] returns the theories in [ch].
When given, [format] enforces the format, otherwise we choose When given, [format] enforces the format, otherwise we choose
the format according to [file]'s extension. Nothing ensures the format according to [file]'s extension. Nothing ensures
that [ch] corresponds to the contents of [f]. that [ch] corresponds to the contents of [f].
...@@ -157,6 +157,7 @@ let list_metas () = Hashtbl.fold (fun _ v acc -> v::acc) meta_table [] ...@@ -157,6 +157,7 @@ let list_metas () = Hashtbl.fold (fun _ v acc -> v::acc) meta_table []
type theory = { type theory = {
th_name : ident; (* theory name *) th_name : ident; (* theory name *)
th_path : string list;(* environment qualifiers *)
th_decls : tdecl list; (* theory declarations *) th_decls : tdecl list; (* theory declarations *)
th_export : namespace; (* exported namespace *) th_export : namespace; (* exported namespace *)
th_known : known_map; (* known identifiers *) th_known : known_map; (* known identifiers *)
...@@ -255,6 +256,7 @@ let td_hash td = td.td_tag ...@@ -255,6 +256,7 @@ let td_hash td = td.td_tag
type theory_uc = { type theory_uc = {
uc_name : ident; uc_name : ident;
uc_path : string list;
uc_decls : tdecl list; uc_decls : tdecl list;
uc_import : namespace list; uc_import : namespace list;
uc_export : namespace list; uc_export : namespace list;
...@@ -266,8 +268,9 @@ type theory_uc = { ...@@ -266,8 +268,9 @@ type theory_uc = {
exception CloseTheory exception CloseTheory
exception NoOpenedNamespace exception NoOpenedNamespace
let empty_theory n = { let empty_theory n p = {
uc_name = id_register n; uc_name = id_register n;
uc_path = p;
uc_decls = []; uc_decls = [];
uc_import = [empty_ns]; uc_import = [empty_ns];
uc_export = [empty_ns]; uc_export = [empty_ns];
...@@ -279,6 +282,7 @@ let empty_theory n = { ...@@ -279,6 +282,7 @@ let empty_theory n = {
let close_theory uc = match uc.uc_export with let close_theory uc = match uc.uc_export with
| [e] -> { | [e] -> {
th_name = uc.uc_name; th_name = uc.uc_name;
th_path = uc.uc_path;
th_decls = List.rev uc.uc_decls; th_decls = List.rev uc.uc_decls;
th_export = e; th_export = e;
th_known = uc.uc_known; th_known = uc.uc_known;
...@@ -735,24 +739,25 @@ let on_meta _meta fn acc theory = ...@@ -735,24 +739,25 @@ let on_meta _meta fn acc theory =
(** Base theories *) (** Base theories *)
let builtin_theory = let builtin_theory =
let uc = empty_theory (id_fresh "BuiltIn") in let uc = empty_theory (id_fresh "BuiltIn") [] in
let uc = add_ty_decl uc [ts_int, Tabstract] in let uc = add_ty_decl uc [ts_int, Tabstract] in
let uc = add_ty_decl uc [ts_real, Tabstract] in let uc = add_ty_decl uc [ts_real, Tabstract] in
let uc = add_logic_decl uc [ps_equ, None] in let uc = add_logic_decl uc [ps_equ, None] in
close_theory uc close_theory uc
let highord_theory = let highord_theory =
let uc = empty_theory (id_fresh "HighOrd") in let uc = empty_theory (id_fresh "HighOrd") [] in
let uc = add_ty_decl uc [ts_func, Tabstract] in let uc = add_ty_decl uc [ts_func, Tabstract] in
let uc = add_ty_decl uc [ts_pred, Tabstract] in let uc = add_ty_decl uc [ts_pred, Tabstract] in
let uc = add_logic_decl uc [fs_func_app, None] in let uc = add_logic_decl uc [fs_func_app, None] in
let uc = add_logic_decl uc [ps_pred_app, None] in let uc = add_logic_decl uc [ps_pred_app, None] in
let create_theory n = use_export (empty_theory n) builtin_theory let create_theory ?(path=[]) n =
use_export (empty_theory n path) builtin_theory
let tuple_theory = Util.memo_int 17 (fun n -> let tuple_theory = Util.memo_int 17 (fun n ->
let uc = empty_theory (id_fresh ("Tuple" ^ string_of_int n)) in let uc = empty_theory (id_fresh ("Tuple" ^ string_of_int n)) [] in
let uc = add_ty_decl uc [ts_tuple n, Talgebraic [fs_tuple n]] in let uc = add_ty_decl uc [ts_tuple n, Talgebraic [fs_tuple n]] in
close_theory uc) close_theory uc)
...@@ -83,6 +83,7 @@ val list_metas : unit -> meta list ...@@ -83,6 +83,7 @@ val list_metas : unit -> meta list
type theory = private { type theory = private {
...@@ -118,7 +119,7 @@ val td_hash : tdecl -> int ...@@ -118,7 +119,7 @@ val td_hash : tdecl -> int
type theory_uc (* a theory under construction *) type theory_uc (* a theory under construction *)
val create_theory : preid -> theory_uc val create_theory : ?path:string list -> preid -> theory_uc
val close_theory : theory_uc -> theory val close_theory : theory_uc -> theory
val open_namespace : theory_uc -> theory_uc val open_namespace : theory_uc -> theory_uc
...@@ -19,7 +19,8 @@ ...@@ -19,7 +19,8 @@
(** parsing entry points *) (** parsing entry points *)
val parse_logic_file : Env.env -> Lexing.lexbuf -> Theory.theory Util.Mstr.t val parse_logic_file :
Env.env -> string list -> Lexing.lexbuf -> Theory.theory Util.Mstr.t
val parse_program_file : Lexing.lexbuf -> Ptree.program_file val parse_program_file : Lexing.lexbuf -> Ptree.program_file
...@@ -314,16 +314,16 @@ and string = parse ...@@ -314,16 +314,16 @@ and string = parse
| Loc.Located _ as e -> raise e | Loc.Located _ as e -> raise e
| e -> raise (Loc.Located (loc lb, e)) | e -> raise (Loc.Located (loc lb, e))
let parse_logic_file env lb = let parse_logic_file env path lb =
pre_logic_file token (Lexing.from_string "") env; pre_logic_file token (Lexing.from_string "") env path;
with_location (logic_file token) lb with_location (logic_file token) lb
let parse_program_file = with_location (program_file token) let parse_program_file = with_location (program_file token)
let read_channel env file c = let read_channel env path file c =
let lb = Lexing.from_channel c in let lb = Lexing.from_channel c in
Loc.set_file file lb; Loc.set_file file lb;
parse_logic_file env lb parse_logic_file env path lb
let () = Env.register_format "why" ["why"] read_channel let () = Env.register_format "why" ["why"] read_channel
...@@ -22,6 +22,7 @@ module Incremental = struct ...@@ -22,6 +22,7 @@ module Incremental = struct
let env_ref = ref [] let env_ref = ref []
let lenv_ref = ref [] let lenv_ref = ref []
let uc_ref = ref [] let uc_ref = ref []
let path_ref = ref []
let ref_get ref = List.hd !ref let ref_get ref = List.hd !ref
let ref_tail ref = List.tl !ref let ref_tail ref = List.tl !ref
...@@ -31,14 +32,19 @@ module Incremental = struct ...@@ -31,14 +32,19 @@ module Incremental = struct
let ref_push ref v = ref := v :: !ref let ref_push ref v = ref := v :: !ref
let ref_set ref v = ref := v :: ref_tail ref let ref_set ref v = ref := v :: ref_tail ref
let open_logic_file env = let open_logic_file env path =
ref_push env_ref env; ref_push lenv_ref Util.Mstr.empty ref_push env_ref env;
ref_push path_ref path;
let close_logic_file () = let close_logic_file () =
ref_drop env_ref; ref_pop lenv_ref ref_drop path_ref;
ref_drop env_ref;
ref_pop lenv_ref
let open_theory id = let open_theory id =
ref_push uc_ref (Theory.create_theory (Denv.create_user_id id)) let path = ref_get path_ref in
ref_push uc_ref (Theory.create_theory ~path (Denv.create_user_id id))
let close_theory loc = let close_theory loc =
let uc = ref_pop uc_ref in let uc = ref_pop uc_ref in
...@@ -252,7 +258,7 @@ end ...@@ -252,7 +258,7 @@ end
/* Entry points */ /* Entry points */
%type <Env.env -> unit> pre_logic_file %type <Env.env -> string list -> unit> pre_logic_file
%start pre_logic_file %start pre_logic_file
%type <Theory.theory Util.Mstr.t> logic_file %type <Theory.theory Util.Mstr.t> logic_file
%start logic_file %start logic_file
...@@ -30,7 +30,7 @@ type t = { ...@@ -30,7 +30,7 @@ type t = {
memo : (string list, module_file) Hashtbl.t; memo : (string list, module_file) Hashtbl.t;
and retrieve_module = t -> string -> in_channel -> module_file and retrieve_module = t -> string list -> string -> in_channel -> module_file
let get_env penv = penv.env let get_env penv = penv.env
...@@ -48,7 +48,7 @@ let find_library penv sl = ...@@ -48,7 +48,7 @@ let find_library penv sl =
with Not_found -> with Not_found ->
Hashtbl.add penv.memo sl (Mstr.empty, Mstr.empty); Hashtbl.add penv.memo sl (Mstr.empty, Mstr.empty);
let file, c = Env.find_channel penv.env "whyml" sl in let file, c = Env.find_channel penv.env "whyml" sl in
let r = penv.retrieve penv file c in let r = penv.retrieve penv sl file c in
close_in c; close_in c;
Hashtbl.replace penv.memo sl r; Hashtbl.replace penv.memo sl r;
r r
...@@ -27,7 +27,7 @@ val get_env : t -> Env.env ...@@ -27,7 +27,7 @@ val get_env : t -> Env.env
type module_file = Theory.theory Util.Mstr.t * Pgm_module.t Util.Mstr.t type module_file = Theory.theory Util.Mstr.t * Pgm_module.t Util.Mstr.t
type retrieve_module = t -> string -> in_channel -> module_file type retrieve_module = t -> string list -> string -> in_channel -> module_file
val create : Env.env -> retrieve_module -> t val create : Env.env -> retrieve_module -> t
...@@ -34,10 +34,10 @@ let () = Exn_printer.register (fun fmt e -> match e with ...@@ -34,10 +34,10 @@ let () = Exn_printer.register (fun fmt e -> match e with
| ClashModule m -> fprintf fmt "clash with previous module %s" m | ClashModule m -> fprintf fmt "clash with previous module %s" m
| _ -> raise e) | _ -> raise e)
let add_theory env lenv m = let add_theory env path lenv m =
let id = m.pth_name in let id = m.pth_name in
let loc = id.id_loc in let loc = id.id_loc in
let th = Theory.create_theory (Denv.create_user_id id) in let th = Theory.create_theory ~path (Denv.create_user_id id) in
let rec add_decl th = function let rec add_decl th = function
| Dlogic d -> | Dlogic d ->
Typing.add_decl env lenv th d Typing.add_decl env lenv th d
...@@ -50,12 +50,12 @@ let add_theory env lenv m = ...@@ -50,12 +50,12 @@ let add_theory env lenv m =
let th = List.fold_left add_decl th m.pth_decl in let th = List.fold_left add_decl th m.pth_decl in
close_theory loc lenv th close_theory loc lenv th
let add_module ?(type_only=false) env penv (ltm, lmod) m = let add_module ?(type_only=false) env penv path (ltm, lmod) m =
let id = m.mod_name in let id = m.mod_name in
if Mstr.mem id.id lmod then raise (Loc.Located (loc, ClashModule id.id)); if Mstr.mem id.id lmod then raise (Loc.Located (loc, ClashModule id.id));
let wp = not type_only in let wp = not type_only in
let uc = create_module (Ident.id_user id.id loc) in let uc = create_module ~path (Ident.id_user id.id loc) in
let prelude = Env.find_theory env ["bool"] "Bool" in let prelude = Env.find_theory env ["bool"] "Bool" in
let uc = use_export_theory uc prelude in let uc = use_export_theory uc prelude in
let uc = let uc =
...@@ -65,11 +65,11 @@ let add_module ?(type_only=false) env penv (ltm, lmod) m = ...@@ -65,11 +65,11 @@ let add_module ?(type_only=false) env penv (ltm, lmod) m =
Mstr.add ("WP " ^ id.id) md.m_pure ltm, (* avoids a theory/module clash *) Mstr.add ("WP " ^ id.id) md.m_pure ltm, (* avoids a theory/module clash *)
Mstr.add id.id md lmod Mstr.add id.id md lmod
let add_theory_module ?(type_only=false) env penv (ltm, lmod) = function let add_theory_module ?(type_only=false) env penv path (ltm, lmod) = function
| Ptheory t -> add_theory env ltm t, lmod | Ptheory t -> add_theory env path ltm t, lmod
| Pmodule m -> add_module ~type_only env penv (ltm, lmod) m | Pmodule m -> add_module ~type_only env penv path (ltm, lmod) m
let retrieve penv file c = let retrieve penv path file c =
let ml = Lexer.parse_program_file lb in let ml = Lexer.parse_program_file lb in
...@@ -78,7 +78,7 @@ let retrieve penv file c = ...@@ -78,7 +78,7 @@ let retrieve penv file c =
else else
let type_only = Debug.test_flag Typing.debug_type_only in let type_only = Debug.test_flag Typing.debug_type_only in
let env = Pgm_env.get_env penv in let env = Pgm_env.get_env penv in
List.fold_left (add_theory_module ~type_only env penv) List.fold_left (add_theory_module ~type_only env penv path)
(Mstr.empty, Mstr.empty) ml (Mstr.empty, Mstr.empty) ml
let pgm_env_of_env = let pgm_env_of_env =
...@@ -91,9 +91,9 @@ let pgm_env_of_env = ...@@ -91,9 +91,9 @@ let pgm_env_of_env =
Env.Wenv.set h env penv; Env.Wenv.set h env penv;
penv penv
let penv = pgm_env_of_env env in let penv = pgm_env_of_env env in
let tm, _ = retrieve penv file c in let tm, _ = retrieve penv path file c in
tm tm
let () = Env.register_format "whyml" ["mlw"] read_channel let () = Env.register_format "whyml" ["mlw"] read_channel
...@@ -193,13 +193,13 @@ let th_prelude = ...@@ -193,13 +193,13 @@ let th_prelude =
let uc = add_logic_decl uc [fs_old, None] in let uc = add_logic_decl uc [fs_old, None] in
let empty_module n = let empty_module path n =
let m = { let m = {
uc_impure = Theory.create_theory n; uc_impure = Theory.create_theory ~path n;
uc_effect = Theory.create_theory n; uc_effect = Theory.create_theory ~path n;
uc_pure = Theory.create_theory n; uc_pure = Theory.create_theory ~path n;
uc_export = [empty_ns]; } uc_export = [empty_ns]; }
in in
...@@ -267,8 +267,8 @@ let use_export_theory uc th = ...@@ -267,8 +267,8 @@ let use_export_theory uc th =
in in
add_ns th.th_export uc add_ns th.th_export uc
let create_module id = let create_module ?(path=[]) id =
let uc = empty_module id in let uc = empty_module path id in
use_export_theory uc th_prelude use_export_theory uc th_prelude
let add_impure_pdecl env ltm d uc = let add_impure_pdecl env ltm d uc =
...@@ -51,7 +51,7 @@ type t = private { ...@@ -51,7 +51,7 @@ type t = private {
m_export : namespace; m_export : namespace;
val create_module : preid -> uc val create_module : ?path:string list -> preid -> uc
val close_module : uc -> t val close_module : uc -> t
val open_namespace : uc -> uc val open_namespace : uc -> uc
...@@ -69,13 +69,13 @@ end = struct ...@@ -69,13 +69,13 @@ end = struct
TptpParser.tptp TptpLexer.token lb TptpParser.tptp TptpLexer.token lb
let read_channel _env file c = let read_channel _env path file c =
let decls = getDeclsFromChan c in let decls = getDeclsFromChan c in
if Debug.test_flag Typing.debug_parse_only || if Debug.test_flag Typing.debug_parse_only ||
Debug.test_flag Typing.debug_type_only Debug.test_flag Typing.debug_type_only
then Util.Mstr.empty then Util.Mstr.empty
else else
let my_theory = theory_of_decls file decls in let my_theory = theory_of_decls path file decls in
Util.Mstr.add "Tptp" my_theory Util.Mstr.empty Util.Mstr.add "Tptp" my_theory Util.Mstr.empty
end end
...@@ -298,8 +298,8 @@ module Translate = struct ...@@ -298,8 +298,8 @@ module Translate = struct
(** from a list of untyped declarations, translates them into a why theory *) (** from a list of untyped declarations, translates them into a why theory *)
let theory_of_decls theoryName decls = let theory_of_decls path theoryName decls =
let theory = Theory.create_theory (Ident.id_fresh theoryName) in let theory = Theory.create_theory ~path (Ident.id_fresh theoryName) in
let theory = Theory.add_ty_decl theory [ts, Decl.Tabstract] in let theory = Theory.add_ty_decl theory [ts, Decl.Tabstract] in
let theory = S.fold addAtomForwardDecl (Summary.findAllAtoms decls) theory in let theory = S.fold addAtomForwardDecl (Summary.findAllAtoms decls) theory in
(* Format.eprintf "atoms forward decls finished.@."; *) (* Format.eprintf "atoms forward decls finished.@."; *)
...@@ -19,5 +19,6 @@ ...@@ -19,5 +19,6 @@
val theory_of_decls : string -> TptpTree.decl list -> Why3.Theory.theory val theory_of_decls :
string list -> string -> TptpTree.decl list -> Why3.Theory.theory
