Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit c34adb3b authored by Andrei Paskevich's avatar Andrei Paskevich
Ity: refresh effects
parent 6a3b6896
...@@ -658,10 +658,7 @@ let freeze_of_writes wr = ...@@ -658,10 +658,7 @@ let freeze_of_writes wr =
List.fold_left2 freeze_unhit frz s.its_regions rl in List.fold_left2 freeze_unhit frz s.its_regions rl in
Mreg.fold freeze_of_write wr Mtv.empty Mreg.fold freeze_of_write wr Mtv.empty
let merge_covers reg sreg1 sreg2 = type refresh = Sreg.t Mreg.t
Sreg.union
(Sreg.filter (fun r -> not (ity_r_stale reg sreg1 r)) sreg2)
(Sreg.filter (fun r -> not (ity_r_stale reg sreg2 r)) sreg1)
let eff_assign e asl = let eff_assign e asl =
let seen,e = List.fold_left (fun (seen,e) (r,f,ity) -> let seen,e = List.fold_left (fun (seen,e) (r,f,ity) ->
...@@ -686,19 +683,46 @@ let eff_assign e asl = ...@@ -686,19 +683,46 @@ let eff_assign e asl =
ity_match sbst fity ity, ity_match sbst fity ity,
ity_match sbsf ity fity) fs acc) seen (frz,frz) in ity_match sbsf ity fity) fs acc) seen (frz,frz) in
(* every RHS region is reset unless it is preserved *) (* every RHS region is reset unless it is preserved *)
let rst = Mtv.set_diff sbsf sbst in
let e = Mtv.fold (fun v r e -> let e = Mtv.fold (fun v r e ->
if Mtv.mem v sbst then e else
let s,tl,rl,_ = open_region r in let s,tl,rl,_ = open_region r in
(* [ity_mut_unsafe] will ignore [s], [tl], and [rl], and will (* [ity_mut_unsafe] will ignore [s], [tl], and [rl], and will
restore (via hash-consing) the type corresponding to [v]. restore (via hash-consing) the type corresponding to [v].
We could use [ity_mut_unsafe ts_unit [] [] v] instead. *) We could use [ity_mut_unsafe ts_unit [] [] v] instead. *)
let r = ity_mut_unsafe s tl rl v in eff_reset e (ity_mut_unsafe s tl rl v)) rst e in
eff_reset e r) sbsf e in
e
(* every region not instantiated to itself is refreshed *) (* every region not instantiated to itself is refreshed *)
let refr = Mreg.fold (fun r _ refr -> let rfr = Mreg.fold (fun r _ rfr ->
*) let sbst = Mtv.inter (fun v reg i -> match i.ity_node with
| Itymut (_,_,_,u) when not (tv_equal u v) -> Some reg
| _ -> None) (ity_match Mtv.empty r r) sbst in
let add_rfr _ reg rfr = Mreg.change (function
| Some cvr -> Some (Sreg.add r cvr)
| None -> Some (Sreg.singleton r)) reg rfr in
Mtv.fold add_rfr sbst rfr) seen Mreg.empty in
e, rfr
let refresh_of_effect e =
let frz = freeze_of_writes e.eff_writes in
let sbst = Mtv.set_diff (ity_match Mtv.empty r r) frz in
Mtv.fold add_rfr sbst rfr) e.eff_writes Mreg.empty
let merge_covers reg cvr1 cvr2 = Sreg.union
(Sreg.filter (fun r -> not (ity_r_stale reg cvr1 r)) cvr2)
(Sreg.filter (fun r -> not (ity_r_stale reg cvr2 r)) cvr1)
let merge_refresh e rfr1 rfr2 =
let e = ref e in
let merge reg cvr1 cvr2 =
let cvr = merge_covers reg cvr1 cvr2 in
if Sreg.is_empty cvr
then (e := eff_reset !e reg; None)
else Some cvr in
let rfr = Mreg.union merge rfr1 rfr2 in
!e, rfr
exception IllegalAlias of region exception IllegalAlias of region
...@@ -225,7 +225,13 @@ val eff_reset : effect -> region -> effect ...@@ -225,7 +225,13 @@ val eff_reset : effect -> region -> effect
val eff_diverge : effect -> effect val eff_diverge : effect -> effect
val eff_assign : effect -> (region * pvsymbol * ity) list -> effect type refresh = Sreg.t Mreg.t
val eff_assign : effect -> (region * pvsymbol * ity) list -> effect * refresh
val refresh_of_effect : effect -> refresh
val merge_refresh : effect -> refresh -> refresh -> effect * refresh
val eff_refresh : effect -> region -> region -> effect val eff_refresh : effect -> region -> region -> effect
