Commit c1491413 authored by MARCHE Claude's avatar MARCHE Claude
redesign mlw interp in progress
parent 4b850225
...@@ -1582,7 +1582,7 @@ let eval const result = ...@@ -1582,7 +1582,7 @@ let eval const result =
Mlw_interp.eval_global_term e.S.env Mlw_interp.eval_global_term e.S.env
th.Theory.th_known t th.Theory.th_known t
in in
Pp.sprintf "@[<hov 2>%a@]" Pretty.print_term t Pp.sprintf "@[<hov 2>%a@]" Mlw_interp.print_value t
| _ -> | _ ->
Pp.sprintf Pp.sprintf
"Symbol '%s' is not a constant in theory '%s.%s'" "Symbol '%s' is not a constant in theory '%s.%s'"
...@@ -532,7 +532,7 @@ let do_theory env drv fname tname th glist elist = ...@@ -532,7 +532,7 @@ let do_theory env drv fname tname th glist elist =
match l with match l with
let t = Mlw_interp.eval_global_term env th.th_known t in let t = Mlw_interp.eval_global_term env th.th_known t in
printf "@[<hov 2>Evaluation of %s:@ %a@]@." x Pretty.print_term t printf "@[<hov 2>Evaluation of %s:@ %a@]@." x Mlw_interp.print_value t
| _ -> | _ ->
eprintf "Symbol '%s' is not a constant in theory '%s'.@." x tname; eprintf "Symbol '%s' is not a constant in theory '%s'.@." x tname;
exit 1 exit 1
This diff is collapsed.
...@@ -11,7 +11,11 @@ ...@@ -11,7 +11,11 @@
(* WhyML interpretation *) (* WhyML interpretation *)
val eval_global_term: Env.env -> Decl.known_map -> Term.term -> Term.term type value
val print_value: Format.formatter -> value -> unit
val eval_global_term: Env.env -> Decl.known_map -> Term.term -> value
type result type result
...@@ -107,7 +107,7 @@ module Mut ...@@ -107,7 +107,7 @@ module Mut
x.i <- y.i; x.i <- y.i;
y.i <- 4 * y.i + tmp; y.i <- 4 * y.i + tmp;
sum.i <- sum.i + tmp sum.i <- sum.i + tmp
done; done;
sum.i sum.i
let run1 () = f 10 (* should be 10 *) let run1 () = f 10 (* should be 10 *)
...@@ -145,6 +145,20 @@ module Ref ...@@ -145,6 +145,20 @@ module Ref
let run2 () = f 4000000 (* should be 4613732 *) let run2 () = f 4000000 (* should be 4613732 *)
let g () : int =
for i=1 to 10 do
let x = ref i in
x := !x + 1
done;
42
let rec h n : int =
let x = ref 0 in
x := !x + 1;
if n = 0 then 0 else h (n-1) + !x
let hh () = h 10
end end
