GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
c0d087be
c0d087be
Sylvain Dailler
Adding Edit_req
Unfinished work to retrieve manual proofs. (minor) added a use case for stack_trace
4dcb5f63
10
10 changed files
263 additions
16 deletions
+263
-16
src/session/controller_itp.ml
+134
src/session/controller_itp.mli
+15
-1
src/session/itp_communication.ml
+2
-1
src/session/itp_communication.mli
+1
src/session/itp_server.ml
+45
-4
src/session/json_util.ml
+9
src/session/server_utils.ml
+5
-1
src/session/server_utils.mli
+1
src/session/session_itp.ml
+39
-5
src/session/session_itp.mli
+12
-4
c0d087be
open
Format
open
Format
open
Session_itp
open
Session_itp
let
debug_sched
Debug
register_info_flag
"scheduler"
desc
"Print@ debugging@ messages@ about@ scheduling@ of@ prover@ calls@ \
and@ transformation@ applications."
exception
Noprogress
exception
Noprogress
let
Exn_printer
let
Exn_printer
@@ -568,6 +573,135 @@ let schedule_proof_attempt c id pr ~counterexmp ~limit ~callback ~notification =
in
in
schedule_proof_attempt_r
c
id
pr
counterexmp
limit
callback
c
id
pr
counterexmp
limit
callback
(* create the path to a file for saving the external proof script *)
let
create_file_rel_path
c
pr
pn
let
config
c
controller_config
in
let
c_env
c
controller_env
in
let
session
c
controller_session
in
let
prover_conf
Whyconf
get_prover_config
config
pr
in
let
driver
prover_conf
Whyconf
driver
in
let
driver
Driver
load_driver
c_env
driver
prover_conf
Whyconf
extra_drivers
in
let
task
Session_itp
get_task
session
pn
in
let
session_dir
Session_itp
get_dir
session
in
let
th
get_encapsulating_theory
session
APn
pn
in
let
th_name
Session_itp
theory_name
th
Ident
id_string
in
let
f
get_encapsulating_file
session
ATh
th
in
let
fn
f
file_name
in
let
file
Driver
file_of_task
driver
fn
th_name
task
in
let
file
Filename
concat
session_dir
file
in
let
file
Sysutil
uniquify
file
in
let
file
Sysutil
relativize_filename
session_dir
file
in
file
let
update_edit_external_proof
c
pn
panid
pr
let
config
c
controller_config
in
let
c_env
c
controller_env
in
let
session
c
controller_session
in
let
prover_conf
Whyconf
get_prover_config
config
pr
in
let
driver
prover_conf
Whyconf
driver
in
let
driver
Driver
load_driver
c_env
driver
prover_conf
Whyconf
extra_drivers
in
let
task
Session_itp
get_task
session
pn
in
let
session_dir
Session_itp
get_dir
session
in
let
file
match
panid
None
c
pr
pn
Some
panid
let
pa
get_proof_attempt_node
session
panid
in
Opt
get
pa
proof_script
in
let
file
Filename
concat
session_dir
file
in
let
old
if
Sys
file_exists
file
then
begin
let
backup
file
".bak"
in
if
Sys
file_exists
backup
then
Sys
remove
backup
Sys
rename
file
backup
Some
open_in
backup
else
None
in
let
ch
open_out
file
in
let
fmt
formatter_of_out_channel
ch
in
(* Name table is only used in ITP printing *)
Driver
print_task
cntexample
false
old
driver
fmt
task
Opt
iter
close_in
old
close_out
ch
file
(* TODO
let schedule_from_spark =
graft_proof_attempt with file given
schedule_edition
exception
Editor_not_found
let
schedule_edition
c
id
pr
file
callback
notification
Debug
dprintf
debug_sched
"[Sched] Scheduling an edition@."
let
config
c
controller_config
in
let
session
c
controller_session
in
let
prover_conf
Whyconf
get_prover_config
config
pr
in
let
session_dir
Session_itp
get_dir
session
in
(* Notification node *)
let
callback
panid
s
callback
panid
s
match
s
Scheduled
Running
Done
_
update_goal_node
notification
c
id
_
in
let
limit
Call_provers
empty_limit
in
let
editor
match
prover_conf
Whyconf
editor
None
s
try
let
ed
Whyconf
editor_by_id
config
s
in
Some
String
concat
ed
Whyconf
editor_command
ed
Whyconf
editor_options
Not_found
None
in
let
proof_attempts_id
get_proof_attempt_ids
session
id
in
let
panid
try
Some
Hprover
find
proof_attempts_id
pr
_
None
in
(* make sure to actually create the file and the proof attempt *)
let
panid
file
match
panid
file
None
None
let
file
c
id
pr
in
let
filename
Sysutil
relativize_filename
session_dir
file
in
let
panid
graft_proof_attempt
c
controller_session
id
pr
file
filename
limit
in
panid
file
None
Some
file
let
panid
graft_proof_attempt
c
controller_session
id
pr
file
limit
in
let
file
c
id
panid
pr
in
panid
file
Some
panid
_
let
file
c
id
panid
pr
in
panid
file
in
Debug
dprintf
debug_sched
"[Editing] goal %s with command '%s' on file %s@."
Session_itp
get_proof_name
session
id
Ident
id_string
match
editor
None
Some
s
s
file
match
editor
None
begin
raise
Editor_not_found
Some
editor
begin
let
call
Call_provers
call_editor
command
editor
file
in
callback
panid
Running
Queue
add
c
controller_session
id
pr
callback
panid
false
call
prover_tasks_in_progress
run_timeout_handler
let
schedule_transformation_r
c
id
name
args
callback
let
c
id
name
args
callback
let
apply_trans
let
apply_trans
let
task
get_task
c
controller_session
id
in
let
task
get_task
c
controller_session
id
in
c0d087be
@@ -183,13 +183,27 @@ val schedule_proof_attempt :
limit
Call_provers
resource_limit
limit
Call_provers
resource_limit
callback
proofAttemptID
proof_attempt_status
unit
callback
proofAttemptID
unit
notification
notifier
unit
notification
notifier
unit
(** [schedule_proof_attempt
s id p ~timelimit ~callback
] schedules a
c id p ~timelimit ~callback ~notification
] schedules a
proof attempt for a goal specified by [id] with the prover [p] with
time limit [timelimit]; the function [callback] will be called each
time the proof attempt status changes. Typically at Scheduled, then
Running, then Done. If there is already a proof attempt with [p] it
is updated. *)
is updated. *)
val
schedule_edition
controller
proofNodeID
Whyconf
prover
file
string
callback
proofAttemptID
unit
notification
notifier
unit
(** [schedule_edition c id pr ?file ~callback ~notification] runs
the editor for prover [pr] on proofnode [id] on a file automatically
generated in [file] (or created path). It will runs callback each time
the proof status changes and notification will be called each time a
change is made to the proof_state (in the whole proof tree of the session)
val
val
controller
controller
proofNodeID
proofNodeID
c0d087be
@@ -92,6 +92,7 @@ type ide_request =
Prove_req
of
node_ID
prover
Call_provers
resource_limit
Prove_req
of
node_ID
prover
Call_provers
resource_limit
Transform_req
of
node_ID
transformation
string
list
Transform_req
of
node_ID
transformation
string
list
Strategy_req
of
node_ID
strategy
Strategy_req
of
node_ID
strategy
Edit_req
of
node_ID
prover
| Open_session_req of string
@@ -118,7 +119,7 @@ let modify_session (r: ide_request) =
match
r
match
r
Command_req
_
Prove_req
_
Transform_req
_
Strategy_req
_
Command_req
_
Prove_req
_
Transform_req
_
Strategy_req
_
Add_file_req
_
Remove_subtree
_
Copy_paste
_
Copy_detached
_
Add_file_req
_
Remove_subtree
_
Copy_paste
_
Copy_detached
_
Replay_req
Clean_req
Mark_obsolete_req
_
true
Replay_req
Clean_req
Mark_obsolete_req
_
Edit_req
_
true
(*| Open_session_req _ *)
Set_max_tasks_req
_
Get_file_contents
_
Set_max_tasks_req
_
Get_file_contents
_
c0d087be
@@ -98,6 +98,7 @@ type ide_request =
Prove_req
of
node_ID
prover
Call_provers
resource_limit
Prove_req
of
node_ID
prover
Call_provers
resource_limit
Transform_req
of
node_ID
transformation
string
list
Transform_req
of
node_ID
transformation
string
list
Strategy_req
of
node_ID
strategy
Strategy_req
of
node_ID
strategy
Edit_req
of
node_ID
prover
c0d087be
@@ -247,6 +247,7 @@ let print_request fmt r =
Prove_req
_nid
prover
_rl
fprintf
fmt
"prove with %s"
prover
Prove_req
_nid
prover
_rl
fprintf
fmt
"prove with %s"
prover
Transform_req
_nid
tr
_args
fprintf
fmt
"transformation :%s"
tr
Transform_req
_nid
tr
_args
fprintf
fmt
tr
Strategy_req
_nid
st
fprintf
fmt
"strategy %s"
st
Strategy_req
_nid
st
fprintf
fmt
"strategy %s"
st
Edit_req
_nid
prover
fprintf
fmt
"edit with %s"
prover
| Open_session_req f -> fprintf fmt "open session file %s" f
@@ -913,6 +914,34 @@ let get_locations t =
limit
callback
notification
notify_change_proved
d
cont
limit
callback
notification
d
cont
unproven_goals
unproven_goals
let
callback_edition
cont
panid
pa_status
let
ses
cont
controller_session
in
begin
match
pa_status
Running
begin
try
ignore
node_ID_from_pan
panid
Not_found
let
parent_id
get_proof_attempt_parent
ses
panid
in
let
node_ID_from_pn
parent_id
in
ignore
new_node
APa
panid
_
let
limit
cont
controller_session
panid
limit
in
let
new_status
Proof_status_change
pa_status
false
limit
in
P
notify
Node_change
node_ID_from_pan
panid
new_status
let
schedule_edition
nid
node_ID
p
Whyconf
config_prover
let
d
get_server_data
in
let
prover
p
Whyconf
prover
in
let
callback
callback_edition
d
cont
in
match
any_from_node_ID
nid
APn
id
C
schedule_edition
d
cont
id
prover
file
None
callback
notification
d
cont
_
(* ----------------- Schedule transformation -------------------- *)
(* Callback of a transformation *)
@@ -1075,6 +1104,15 @@ let get_locations t =
Strategy_req
nid
st
Strategy_req
nid
st
let
counterexmp
Whyconf
cntexample
Whyconf
get_main
config
in
let
counterexmp
Whyconf
cntexample
Whyconf
get_main
config
in
run_strategy_on_task
counterexmp
nid
st
counterexmp
nid
st
Edit_req
nid
p
let
p
try
Some
get_prover
p
Bad_prover_name
p
P
notify
Message
Proof_error
nid
"Bad prover name"
p
None
in
begin
match
p
None
Some
p
schedule_edition
nid
p
Clean_req
clean_session
Clean_req
clean_session
Save_req
save_session
Save_req
save_session
Reload_req
reload_session
Reload_req
reload_session
@@ -1129,6 +1167,8 @@ let get_locations t =
Strategies
st
Strategies
st
let
counterexmp
Whyconf
cntexample
Whyconf
get_main
config
in
let
counterexmp
Whyconf
cntexample
Whyconf
get_main
config
in
counterexmp
nid
st
counterexmp
nid
st
Edit
p
schedule_edition
nid
p
Help_message
s
P
notify
Message
s
Help_message
s
P
notify
Message
s
QError
s
P
notify
Message
Query_Error
nid
s
QError
s
P
notify
Message
Query_Error
nid
s
Other
s
_args
Other
s
_args
@@ -1150,10 +1190,11 @@ let get_locations t =
Set_max_tasks_req
i
C
set_max_tasks
i
Set_max_tasks_req
i
C
set_max_tasks
i
Exit_req
exit
Exit_req
exit
e
P
notify
Message
Error
Pp
string_of
e
when
not
Debug
test_flag
Debug
stack_trace
fun
fmt
r
e
Format
fprintf
fmt
P
notify
Message
Error
Pp
string_of
"There was an unrecoverable error during treatment of request:
\n
%a
\n
with exception: %a"
fun
fmt
r
e
Format
fprintf
fmt
print_request
r
Exn_printer
exn_printer
e
r
e
\n
%a
\n
with exception: %a"
print_request
r
Exn_printer
exn_printer
e
r
e
let
treat_requests
bool
let
treat_requests
bool
iter
treat_request
P
get_requests
iter
treat_request
P
get_requests
c0d087be
@@ -121,6 +121,7 @@ let convert_request_constructor (r: ide_request) =
Prove_req
_
String
"Prove_req"
Prove_req
_
String
"Prove_req"
Transform_req
_
String
"Transform_req"
Transform_req
_
String
"Transform_req"
Strategy_req
_
String
"Strategy_req"
Strategy_req
_
String
"Strategy_req"
Edit_req
_
String
"Edit_req"
| Open_session_req _ -> String "Open_session_req"
@@ -164,6 +165,10 @@ let print_request_to_json (r: ide_request): Json_base.json =
convert_record
"ide_request"
cc
r
convert_record
"ide_request"
cc
r
"node_ID"
Int
nid
"node_ID"
Int
nid
"strategy"
String
str
"strategy"
String
str
Edit_req
nid
prover
convert_record
"ide_request"
cc
r
"node_ID"
Int
nid
"prover"
String
prover
convert_record ["ide_request", cc r;
@@ -438,6 +443,10 @@ let parse_request (constr: string) j =
let
str
get_string
get_field
j
"strategy"
in
let
str
get_string
get_field
j
"strategy"
in
Strategy_req
nid
str
Strategy_req
nid
str
"Edit_req"
let
nid
get_int
get_field
j
"node_ID"
in
let
p
get_string
get_field
j
"prover"
in
Edit_req
nid
p
| "Open_session_req" ->
let f = get_string (get_field j "file") in
c0d087be
@@ -283,6 +283,7 @@ type command =
Transform
of
string
Trans
gentrans
string
list
Transform
of
string
Trans
gentrans
string
list
Prove
of
Whyconf
config_prover
Call_provers
resource_limit
Prove
of
Whyconf
config_prover
Call_provers
resource_limit
Strategies
of
string
Strategies
of
string
Edit
of
Whyconf
config_prover
Help_message
of
string
Help_message
of
string
Query
of
string
Query
of
string
QError
of
string
QError
of
string
@@ -291,7 +292,10 @@ type command =
let
interp_others
commands_table
config
cmd
args
let
interp_others
commands_table
config
cmd
args
match
parse_prover_name
config
cmd
args
match
parse_prover_name
config
cmd
args
Some
prover_config
limit
Some
prover_config
limit
Prove
prover_config
limit
if
prover_config
Whyconf
interactive
then
Edit
prover_config
else
Prove
prover_config
limit
None
None
match
cmd
match
cmd
"auto"
"auto"
c0d087be
@@ -50,6 +50,7 @@ type command =
Transform
of
string
Trans
gentrans
string
list
Transform
of
string
Trans
gentrans
string
list
Prove
of
Whyconf
config_prover
Call_provers
resource_limit
Prove
of
Whyconf
config_prover
Call_provers
resource_limit
Strategies
of
string
Strategies
of
string
Edit
of
Whyconf
config_prover
Help_message
of
string
Help_message
of
string
Query
of
string
Query
of
string
QError
of
string
QError
of
string
c0d087be
@@ -263,6 +263,31 @@ let is_detached (s: session) (a: any) =
let
pn
get_proofNode
s
pn_id
in
let
pn
get_proofNode
s
pn_id
in
pn
proofn_task
None
pn
proofn_task
None
let
rec
s
any
match
any
AFile
_f
assert
false
ATh
th
th
ATn
tn
let
pn_id
get_trans_parent
s
tn
in
s
APn
pn_id
APn
pn
match
get_proof_parent
s
pn
Theory
th
th
Trans
tn
s
ATn
tn
APa
pa
let
pn
s
pa
in
s
APn
pn
let
s
any
match
any
AFile
f
f
ATh
th
theory_parent
s
th
_
let
th
s
any
in
theory_parent
s
th
(* Remove elements of the session tree *)
let
remove_transformation
s
session
id
transID
let
s
session
id
transID
@@ -528,17 +553,20 @@ let add_proof_attempt session prover limit state obsolete edit parentID =
Hint
replace
session
proofAttempt_table
id
pa
Hint
replace
session
proofAttempt_table
id
pa
id
id
let
graft_proof_attempt
s
session
id
proofNodeID
pr
Whyconf
prover
let
graft_proof_attempt
file
s
session
id
proofNodeID
pr
Whyconf
prover
limit
limit
let
pn
get_proofNode
s
id
in
let
pn
get_proofNode
s
id
in
try
try
let
id
Hprover
find
pn
proofn_attempts
pr
in
let
id
Hprover
find
pn
proofn_attempts
pr
in
let
pa
Hint
find
s
proofAttempt_table
id
in
let
pa
Hint
find
s
proofAttempt_table
id
in
let
pa
pa
limit
limit
proof_state
None
proof_obsolete
false
in
let
pa
pa
limit
limit
proof_state
None
proof_obsolete
false
proof_script
file
in
Hint
replace
s
proofAttempt_table
id
pa
Hint
replace
s
proofAttempt_table
id
pa
id
id
Not_found
Not_found
add_proof_attempt
s
pr
limit
None
false
Non
e
id
add_proof_attempt
s
pr
limit
None
false
fil
e
id
(* [mk_proof_node s n t p id] register in the session [s] a proof node
@@ -1480,6 +1508,11 @@ let save_prover fmt id (p,mostfrequent_timelimit,mostfrequent_steplimit,mostfreq
opt
pp_print_int
"steplimit"
steplimit
opt
pp_print_int
"steplimit"
steplimit
mostfrequent_memlimit
let
save_option_def
name
fmt
opt
match
opt
None
Some
s
fprintf
fmt
"@ %s=
%s
name
s
let
save_bool_def
name
def
fmt
b
let
save_bool_def
name
def
fmt
b
if
b
def
then
fprintf
fmt
"@ %s=
%b
name
b
if
b
def
then
fprintf
fmt
"@ %s=
%b
name
b
@@ -1512,12 +1545,13 @@ let save_status fmt s =
let
save_proof_attempt
fmt
id
tl
sl
ml
a
let
save_proof_attempt
fmt
id
tl
sl
ml
a
fprintf
fmt
fprintf
fmt
\n
@[<h><proof@ prover=
%i
%a%a%a%a>"
\n
%i
%a%a%a%a
%a
id
id
save_int_def
"timelimit"
tl
a
limit
Call_provers
limit_time
save_int_def
"timelimit"
tl
a
limit
Call_provers
limit_time
save_int_def
"steplimit"
sl
a
limit
Call_provers
limit_steps
save_int_def
"steplimit"
sl
a
limit
Call_provers
limit_steps
save_int_def
"memlimit"
ml
a
limit
Call_provers
limit_mem
save_int_def
"memlimit"
ml
a
limit
Call_provers
limit_mem
save_bool_def
"obsolete"
false
a
proof_obsolete
save_bool_def
"obsolete"
false
a
proof_obsolete
save_option_def
"proof_script"
a
proof_script
save_status
fmt
a
proof_state
save_status
fmt
a
proof_state
fprintf
fmt
"</proof>@]"
fprintf
fmt
"</proof>@]"
c0d087be
@@ -97,6 +97,11 @@ val get_any_parent: session -> any -> any option
(* Answers true if a node is in a detached subtree *)
val
is_detached
session
any
bool
val
is_detached
session
any
bool
(* get the parent theory/file of a proof node *)
val
session
any
theory
val
session
any
file
exception
BadCopyDetached
of
string
exception
BadCopyDetached
of
string
(** [copy s pn] copy pn and add the copy as detached subgoal of its parent *)
@@ -127,13 +132,16 @@ val merge_file_section :
proof_attempts and transformations to the goals of the new
theory *)
theory *)
val
graft_proof_attempt
session
proofNodeID
Whyconf
prover
val
graft_proof_attempt
file
string
session
proofNodeID
limit
Call_provers
resource_limit
proofAttemptID
Whyconf
prover
limit
Call_provers
resource_limit
proofAttemptID
(** [graft_proof_attempt s id pr l] adds a proof attempt with prover
file
[pr] and limits [l] in the session [s] as a child of the task
[id]. If there already a proof attempt with the same prover, it
updates it with the limits. It returns the id of the
generated proof attempt. *)
For manual proofs, it has the same behaviour except that it adds a
proof_script field equal to [file].
val
update_proof_attempt
session
proofNodeID
Whyconf
prover
val
session
proofNodeID
Whyconf
prover
Call_provers
prover_result
unit
Call_provers
prover_result
unit
