Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit c0c54f6b authored by Andrei Paskevich's avatar Andrei Paskevich
slightly generalized Tower of Hanoi (two Coq lemmas not proved yet)
parent 3b6e790c
......@@ -57,6 +57,79 @@ module Hanoi
module Tower_of_Hanoi
use import int.Int
use import list.List
use import list.Length
clone list.Sorted as S with type t = int, predicate le = (<)
clone list.Sorted as R with type t = int, predicate le = (>)
type tower = {
mutable rod : list int;
} invariant {
S.sorted self.rod
let move (a b: tower) (ghost x: int) (ghost s: list int)
requires { a.rod = Cons x s }
requires { match b.rod with Nil -> true | Cons y _ -> x < y end }
ensures { a.rod = s }
ensures { b.rod = Cons x (old b.rod) }
= match a.rod with
| Cons x r ->
a.rod <- r;
b.rod <- Cons x b.rod
| Nil -> absurd
predicate compat (s t: list int) =
match s, t with
| Cons x _, Cons y _ -> x < y
| _, _ -> true
function rev_append (s t: list int) : list int =
match s with
| Cons x r -> rev_append r (Cons x t)
| Nil -> t
let rec hanoi_rec (a b c: tower) (n: int) (ghost p s: list int)
requires { length p = n /\ R.sorted p }
requires { a.rod = rev_append p s }
requires { compat p b.rod }
requires { compat p c.rod }
variant { n }
ensures { b.rod = rev_append p (old b.rod) }
ensures { c.rod = old c.rod }
= if n > 0 then begin
let ghost t = c.rod in
let ghost x = match p with Cons x _ -> x | Nil -> absurd end in
let ghost r = match p with Cons _ r -> r | Nil -> absurd end in
hanoi_rec a c b (n-1) r (Cons x s);
move a b x s;
hanoi_rec c b a (n-1) r t
use import list.Reverse
lemma rev_sorted:
forall s: list int. S.sorted s -> R.sorted (reverse s)
lemma rev_append_rev:
forall s: list int. s = rev_append (reverse s) Nil
let tower_of_hanoi (a b c: tower)
requires { b.rod = c.rod = Nil }
ensures { b.rod = old a.rod }
ensures { a.rod = c.rod = Nil }
= hanoi_rec a b c (length a.rod) (ghost reverse a.rod) Nil
(* a stack of disks is modeled as a sorted list of integers *)
module Disks
