Commit bfe9a22e authored by Guillaume Melquiond's avatar Guillaume Melquiond
Prevent IDE from overwriting the main config with extra config files.
parent 4126efe7
...@@ -55,6 +55,7 @@ type t = ...@@ -55,6 +55,7 @@ type t =
(** colors *) (** colors *)
mutable env : Env.env; mutable env : Env.env;
mutable config : Whyconf.config; mutable config : Whyconf.config;
original_config : Whyconf.config;
mutable altern_provers : altern_provers; mutable altern_provers : altern_provers;
mutable replace_prover : conf_replace_prover; mutable replace_prover : conf_replace_prover;
...@@ -169,7 +170,7 @@ let load_altern alterns (_,section) = ...@@ -169,7 +170,7 @@ let load_altern alterns (_,section) =
} in } in
Mprover.add unknown known alterns Mprover.add unknown known alterns
let load_config config = let load_config config original_config =
let main = get_main config in let main = get_main config in
let ide = match get_section config "ide" with let ide = match get_section config "ide" with
| None -> default_ide | None -> default_ide
...@@ -199,6 +200,7 @@ let load_config config = ...@@ -199,6 +200,7 @@ let load_config config =
max_running_processes = Whyconf.running_provers_max main; max_running_processes = Whyconf.running_provers_max main;
default_editor = ide.ide_default_editor; default_editor = ide.ide_default_editor;
config = config; config = config;
original_config = original_config;
env = env; env = env;
altern_provers = alterns; altern_provers = alterns;
replace_prover = ide.ide_replace_prover; replace_prover = ide.ide_replace_prover;
...@@ -219,7 +221,7 @@ let save_altern unknown known (id,family) = ...@@ -219,7 +221,7 @@ let save_altern unknown known (id,family) =
(id+1,(sprintf "alt%i" id,alt)::family) (id+1,(sprintf "alt%i" id,alt)::family)
let save_config t = let save_config t =
let config = t.config in let config = t.original_config in
let config = set_main config let config = set_main config
(set_limits (get_main config) (set_limits (get_main config)
t.time_limit t.mem_limit t.max_running_processes) t.time_limit t.mem_limit t.max_running_processes)
...@@ -255,8 +257,8 @@ let save_config t = ...@@ -255,8 +257,8 @@ let save_config t =
let read_config conf_file extra_files = let read_config conf_file extra_files =
try try
let config = Whyconf.read_config conf_file in let config = Whyconf.read_config conf_file in
let config = List.fold_left Whyconf.merge_config config extra_files in let merged_config = List.fold_left Whyconf.merge_config config extra_files in
load_config config load_config merged_config config
with e when not (Debug.test_flag Debug.stack_trace) -> with e when not (Debug.test_flag Debug.stack_trace) ->
eprintf "@.%a@." Exn_printer.exn_printer e; eprintf "@.%a@." Exn_printer.exn_printer e;
exit 1 exit 1
...@@ -45,6 +45,7 @@ type t = ...@@ -45,6 +45,7 @@ type t =
mutable error_color : string; mutable error_color : string;
mutable env : Why3.Env.env; mutable env : Why3.Env.env;
mutable altern_provers : prover option Mprover.t; mutable altern_provers : prover option Mprover.t;
Supports Markdown
