Commit bfe46a90 authored by MARCHE Claude's avatar MARCHE Claude
proof of WP function complete, function abstract_effects remains to do
parent 4b5cd36b
...@@ -411,11 +411,16 @@ predicate stmt_writes (i:stmt) (w:Set.set ident) = ...@@ -411,11 +411,16 @@ predicate stmt_writes (i:stmt) (w:Set.set ident) =
val abstract_effects (i:stmt) (f:fmla) : val abstract_effects (i:stmt) (f:fmla) :
fmla fmla
{ forall sigma pi. eval_fmla sigma pi result -> { forall sigma pi:env. eval_fmla sigma pi result ->
eval_fmla sigma pi f /\ eval_fmla sigma pi f /\
forall sigma':env, w:Set.set ident. forall sigma':env, w:Set.set ident.
stmt_writes i w /\ assigns sigma w sigma' -> stmt_writes i w /\ assigns sigma w sigma' ->
eval_fmla sigma' pi result eval_fmla sigma' pi result
forall sigma' pi':env, n:int.
many_steps sigma pi i sigma' pi' Sskip n ->
eval_fmla sigma' pi' result
use HoareLogic use HoareLogic
This diff is collapsed.
...@@ -424,10 +424,11 @@ Theorem WP_parameter_wp : forall (i:stmt), forall (q:fmla), ...@@ -424,10 +424,11 @@ Theorem WP_parameter_wp : forall (i:stmt), forall (q:fmla),
| (Sassert f) => True | (Sassert f) => True
| (Swhile e inv i1) => forall (result:fmla), (valid_triple result i1 | (Swhile e inv i1) => forall (result:fmla), (valid_triple result i1
inv) -> forall (result1:fmla), (forall (sigma:(map Z value)) (pi:(map Z inv) -> forall (result1:fmla), (forall (sigma:(map Z value)) (pi:(map Z
value)) (sigmaqt:(map Z value)) (piqt:(map Z value)) (w:(set1 Z)), value)), (eval_fmla sigma pi result1) -> ((eval_fmla sigma pi
((eval_fmla sigma pi (Fand (Fimplies (Fand (Fterm e) inv) result) (Fand (Fimplies (Fand (Fterm e) inv) result)
(Fimplies (Fand (Fnot (Fterm e)) inv) q))) /\ ((stmt_writes i1 w) /\ (Fimplies (Fand (Fnot (Fterm e)) inv) q))) /\ forall (sigmaqt:(map Z
(assigns sigma w sigmaqt))) -> (eval_fmla sigmaqt piqt result1)) -> value)) (piqt:(map Z value)) (n:Z), (many_steps sigma pi i1 sigmaqt
piqt Sskip n) -> (eval_fmla sigmaqt piqt result1))) ->
(valid_triple (Fand inv result1) i q) (valid_triple (Fand inv result1) i q)
end. end.
destruct i; trivial. destruct i; trivial.
...@@ -447,14 +448,32 @@ apply Z_lt_induction with (P := ...@@ -447,14 +448,32 @@ apply Z_lt_induction with (P :=
many_steps s1 p1 (Swhile cond inv body) s2 p2 Sskip n -> many_steps s1 p1 (Swhile cond inv body) s2 p2 Sskip n ->
eval_fmla s2 p2 Post); auto. eval_fmla s2 p2 Post); auto.
intros. intros.
elim H0; clear H0; intros H_inv_in_s2 H_abstr_in_s2.
inversion H1; subst; clear H1. inversion H1; subst; clear H1.
inversion H2; subst; clear H2. inversion H0; subst; clear H0.
generalize (many_steps_seq _ _ _ _ _ _ _ H3); clear H3. (* case cond = true *)
generalize (many_steps_seq _ _ _ _ _ _ _ H2); clear H2.
intros (s3 & p3 & n1 & n2 & First_iter & Next_iter & Hn1n2). intros (s3 & p3 & n1 & n2 & First_iter & Next_iter & Hn1n2).
generalize (steps_non_neg _ _ _ _ _ _ _ First_iter); intro Hn1_pos. apply H with (3:=Next_iter).
generalize (steps_non_neg _ _ _ _ _ _ _ Next_iter); intro Hn2_pos. generalize (steps_non_neg _ _ _ _ _ _ _ First_iter); intro Hn1_pos.
apply H with (3:=Next_iter); auto with zarith. generalize (steps_non_neg _ _ _ _ _ _ _ Next_iter); intro Hn2_pos.
omega.
generalize (H_abstracted sigma2 pi2 H_abstr_in_s2); clear H_abstracted.
simpl.
intros ((Htrue,_) & Hnext).
generalize (Hnext s3 p3 n1 First_iter); clear Hnext.
intro H_abstr_in_s3.
split; auto.
red in H_WP_body.
apply H_WP_body with (2:=First_iter).
apply Htrue; auto.
(* case cond = false *)
inversion H2; [subst; clear H2 | inversion H0].
generalize (H_abstracted s2 p2 H_abstr_in_s2); clear H_abstracted.
simpl.
intros ((_,Hfalse) & Hnext).
apply Hfalse; split; auto.
rewrite H11; discriminate.
Qed. Qed.
