programs: type-checking of application is now performed differently to revocer...
programs: type-checking of application is now performed differently to revocer application of logical symbols and A-normal form
parent aa097f1d
...@@ -518,6 +518,9 @@ test: bin/why.byte $(TOOLS) ...@@ -518,6 +518,9 @@ test: bin/why.byte $(TOOLS)
testl: bin/whyml.byte testl: bin/whyml.byte
ocamlrun -bt bin/whyml.byte -L theories/ tests/test-pgm-jcf.mlw ocamlrun -bt bin/whyml.byte -L theories/ tests/test-pgm-jcf.mlw
testl-type: bin/whyml.byte
ocamlrun -bt bin/whyml.byte --type-only -L theories/ tests/test-pgm-jcf.mlw
# installation # installation
...@@ -143,11 +143,11 @@ type expr = { ...@@ -143,11 +143,11 @@ type expr = {
and expr_desc = and expr_desc =
| Econstant of constant | Elogic of Term.term
| Elocal of Term.vsymbol | Elocal of Term.vsymbol
| Eglobal of Term.lsymbol | Eglobal of Term.lsymbol
| Elogic of Term.lsymbol | Eapply of expr * Term.vsymbol
| Eapply of expr * expr | Eapply_ref of expr * reference
| Efun of binder list * triple | Efun of binder list * triple
| Elet of Term.vsymbol * expr * expr | Elet of Term.vsymbol * expr * expr
| Eletrec of recfun list * expr | Eletrec of recfun list * expr
...@@ -145,7 +145,7 @@ let rec dpurify env = function ...@@ -145,7 +145,7 @@ let rec dpurify env = function
(dpurify env c.dc_result_type) (dpurify env c.dc_result_type)
let check_reference_type uc loc ty = let check_reference_type uc loc ty =
let ty_ref =Tyapp (ts_ref uc, [create_type_var loc]) in let ty_ref = Tyapp (ts_ref uc, [create_type_var loc]) in
if not (Denv.unify ty ty_ref) then if not (Denv.unify ty ty_ref) then
errorm ~loc "this expression has type %a, but is expected to be a reference" errorm ~loc "this expression has type %a, but is expected to be a reference"
print_dty ty print_dty ty
...@@ -296,7 +296,7 @@ and dexpr_desc env loc = function ...@@ -296,7 +296,7 @@ and dexpr_desc env loc = function
assert (Denv.unify e1.dexpr_type (Tyapp (ts_arrow env.uc, [ty2; ty]))); assert (Denv.unify e1.dexpr_type (Tyapp (ts_arrow env.uc, [ty2; ty])));
create (DEapply (e1, e2)) ty create (DEapply (e1, e2)) ty
in in
let e = create (DEglobal s) (dcurrying env.uc tyl ty) in let e = create (DElogic s) (dcurrying env.uc tyl ty) in
let e = List.fold_left2 apply e el tyl in let e = List.fold_left2 apply e el tyl in
e.dexpr_desc, ty e.dexpr_desc, ty
...@@ -504,22 +504,82 @@ and binder uc env (x, tyv) = ...@@ -504,22 +504,82 @@ and binder uc env (x, tyv) =
let env = Mstr.add x v env in let env = Mstr.add x v env in
env, (v, tyv) env, (v, tyv)
let mk_expr loc ty d = { expr_desc = d; expr_loc = loc; expr_type = ty }
(* apply ls to a list of expressions, introducing let's if necessary
ls [e1; e2; ...; en]
let x1 = e1 in
let x2 = e2 in
let xn = en in
ls(x1,x2,...,xn)
let make_logic_app loc ty ls el =
let rec make args = function
Elogic (t_app ls (List.rev args) ty)
| ({ expr_desc = Elogic t }, _) :: r ->
make (t :: args) r
| (e, _) :: r ->
let v = create_vsymbol (id_fresh "x") e.expr_type in
let d = mk_expr loc ty (make (t_var v :: args) r) in
Elet (v, e, d)
in
make [] el
(* same thing, but for an abritrary expression f (not an application)
f [e1; e2; ...; en]
-> let x1 = e1 in ... let xn = en in (...((f x1) x2)... xn)
(* TODO?: check for references -> Eapply_ref instead of Eapply *)
let make_app loc ty f el =
let rec make k = function
k f
| ({ expr_desc = Elocal v }, tye) :: r ->
make (fun f -> k (mk_expr loc tye (Eapply (f, v)))) r
| (e, tye) :: r ->
let d = make (fun f -> k (mk_expr loc tye (Eapply (f, v)))) r in
mk_expr loc ty (Elet (v, e, d))
in
make (fun f -> f) el
let rec expr uc env e = let rec expr uc env e =
let d = expr_desc uc env e.dexpr_denv e.dexpr_desc in
let ty = Denv.ty_of_dty e.dexpr_type in let ty = Denv.ty_of_dty e.dexpr_type in
let d = expr_desc uc env e.dexpr_denv e.dexpr_loc ty e.dexpr_desc in
{ expr_desc = d; expr_type = ty; expr_loc = e.dexpr_loc } { expr_desc = d; expr_type = ty; expr_loc = e.dexpr_loc }
and expr_desc uc env denv = function and expr_desc uc env denv loc ty = function
| DEconstant c -> | DEconstant c ->
Econstant c Elogic (t_const c ty)
| DElocal x -> | DElocal x ->
Elocal (Mstr.find x env) Elocal (Mstr.find x env)
| DEglobal ls -> | DEglobal ls ->
Eglobal ls Eglobal ls
| DElogic ls -> | DElogic ls ->
Elogic ls begin match ls.ls_args with
Elogic (t_app ls [] ty)
| al ->
errorm ~loc "function symbol %s is expecting %d arguments"
ls.ls_name.id_string (List.length al)
| DEapply (e1, e2) -> | DEapply (e1, e2) ->
Eapply (expr uc env e1, expr uc env e2) let f, args = decompose_app uc env e1 [expr uc env e2, ty] in
begin match f.dexpr_desc with
| DElogic ls ->
let n = List.length ls.ls_args in
if List.length args <> n then
ls.ls_name.id_string n;
make_logic_app loc ty ls args
| _ ->
let f = expr uc env f in
(make_app loc ty f args).expr_desc
| DEfun (bl, e1) -> | DEfun (bl, e1) ->
let env, bl = map_fold_left (binder uc) env bl in let env, bl = map_fold_left (binder uc) env bl in
Efun (bl, triple uc env e1) Efun (bl, triple uc env e1)
...@@ -587,6 +647,13 @@ and expr_desc uc env denv = function ...@@ -587,6 +647,13 @@ and expr_desc uc env denv = function
let c = type_c uc env c in let c = type_c uc env c in
Eany c Eany c
and decompose_app uc env e args = match e.dexpr_desc with
| DEapply (e1, e2) ->
decompose_app uc env e1 ((expr uc env e2, ty) :: args)
| _ ->
e, args
and letrec uc env dl = and letrec uc env dl =
(* add all functions into env, and compute local env *) (* add all functions into env, and compute local env *)
let step1 env ((x, dty), bl, var, t) = let step1 env ((x, dty), bl, var, t) =
...@@ -36,21 +36,13 @@ let rec expr e = ...@@ -36,21 +36,13 @@ let rec expr e =
let d, ef = expr_desc loc ty e.Pgm_ttree.expr_desc in let d, ef = expr_desc loc ty e.Pgm_ttree.expr_desc in
{ expr_desc = d; expr_type = ty; expr_effect = ef; expr_loc = loc } { expr_desc = d; expr_type = ty; expr_effect = ef; expr_loc = loc }
and expr_desc loc ty = function and expr_desc _loc _ty = function
| Pgm_ttree.Econstant c -> | Pgm_ttree.Elogic _t ->
Elogic (t_const c ty), E.empty
| Pgm_ttree.Elogic ls ->
Elogic (t_app ls [] ty), E.empty
| al ->
| Pgm_ttree.Eapply _ as e ->
assert false (*TODO*) assert false (*TODO*)
| Pgm_ttree.Efun (_bl, (p, e, q)) -> | Pgm_ttree.Eapply _ as _e ->
let e = expr e in assert false (*TODO*)
| Pgm_ttree.Efun (_bl, (_p, e, _q)) ->
let _e = expr e in
| _ -> | _ ->
...@@ -5,7 +5,7 @@ logic f(int, int) : int ...@@ -5,7 +5,7 @@ logic f(int, int) : int
logic c : int logic c : int
let ff () = { } f 1 2 { result = result } let ff () = { } f 2 3 { true }
