Commit bf39fc59 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
registered parsers: error reporting
parent a0659b62
...@@ -68,14 +68,17 @@ let env_tag env = env.env_tag ...@@ -68,14 +68,17 @@ let env_tag env = env.env_tag
type parse_only = env -> string -> in_channel -> unit type parse_only = env -> string -> in_channel -> unit
type read_channel = env -> string -> in_channel -> theory Mnm.t type read_channel = env -> string -> in_channel -> theory Mnm.t
type error_report = Format.formatter -> exn -> unit
let parse_only_table = Hashtbl.create 17 (* parser name -> parse_only *) let parse_only_table = Hashtbl.create 17 (* parser name -> parse_only *)
let read_channel_table = Hashtbl.create 17 (* parser name -> read_channel *) let read_channel_table = Hashtbl.create 17 (* parser name -> read_channel *)
let error_report_table = Hashtbl.create 17 (* parser name -> error_report *)
let suffixes_table = Hashtbl.create 17 (* suffix -> parser name *) let suffixes_table = Hashtbl.create 17 (* suffix -> parser name *)
let register_parser name suffixes po rc = let register_parser name suffixes po rc er =
Hashtbl.add parse_only_table name po; Hashtbl.add parse_only_table name po;
Hashtbl.add read_channel_table name rc; Hashtbl.add read_channel_table name rc;
Hashtbl.add error_report_table name er;
List.iter (fun s -> Hashtbl.add suffixes_table ("." ^ s) name) suffixes List.iter (fun s -> Hashtbl.add suffixes_table ("." ^ s) name) suffixes
exception UnknownParser of string (* parser name *) exception UnknownParser of string (* parser name *)
...@@ -109,3 +112,17 @@ let read_channel ?name env file ic = ...@@ -109,3 +112,17 @@ let read_channel ?name env file ic =
let rc = find_parser read_channel_table n in let rc = find_parser read_channel_table n in
rc env file ic rc env file ic
let report ?name file fmt e =
let n = parser_for_file ?name file in
let er = find_parser error_report_table n in
er fmt e
let list_formats () =
let h = Hashtbl.create 17 in
let add s p =
let l = try Hashtbl.find h p with Not_found -> [] in
Hashtbl.replace h p (s :: l)
in
Hashtbl.iter add suffixes_table;
Hashtbl.fold (fun p l acc -> (p, l) :: acc) h []
...@@ -39,9 +39,10 @@ exception TheoryNotFound of string list * string ...@@ -39,9 +39,10 @@ exception TheoryNotFound of string list * string
val register_parser : val register_parser :
string -> string list -> parse_only -> read_channel -> unit string -> string list -> parse_only -> read_channel -> error_report -> unit
(** [register_parser name extensions f1 f2] registers a new parser (** [register_parser name extensions f1 f2] registers a new parser
under name [name], for files with extensions in list [extensions]; under name [name], for files with extensions in list [extensions];
[f1] is the function to perform parsing only; [f1] is the function to perform parsing only;
...@@ -51,5 +52,9 @@ val parse_only : ?name:string -> parse_only ...@@ -51,5 +52,9 @@ val parse_only : ?name:string -> parse_only
val read_channel : ?name:string -> read_channel val read_channel : ?name:string -> read_channel
val report : ?name:string -> string -> error_report
val list_formats : unit -> (string * string list) list
...@@ -76,6 +76,7 @@ let add_opt_goal x = match !opt_theory with ...@@ -76,6 +76,7 @@ let add_opt_goal x = match !opt_theory with
let add_opt_trans x = opt_trans := x::!opt_trans let add_opt_trans x = opt_trans := x::!opt_trans
let opt_config = ref None let opt_config = ref None
let opt_parser = ref None
let opt_prover = ref None let opt_prover = ref None
let opt_loadpath = ref [] let opt_loadpath = ref []
let opt_driver = ref None let opt_driver = ref None
...@@ -89,6 +90,7 @@ let opt_print_namespace = ref false ...@@ -89,6 +90,7 @@ let opt_print_namespace = ref false
let opt_list_transforms = ref false let opt_list_transforms = ref false
let opt_list_printers = ref false let opt_list_printers = ref false
let opt_list_provers = ref false let opt_list_provers = ref false
let opt_list_formats = ref false
let opt_parse_only = ref false let opt_parse_only = ref false
let opt_type_only = ref false let opt_type_only = ref false
...@@ -119,6 +121,10 @@ let option_list = Arg.align [ ...@@ -119,6 +121,10 @@ let option_list = Arg.align [
"<prover> Prove or print (with -o) the selected goals"; "<prover> Prove or print (with -o) the selected goals";
"--prover", Arg.String (fun s -> opt_prover := Some s), "--prover", Arg.String (fun s -> opt_prover := Some s),
" same as -P"; " same as -P";
"-F", Arg.String (fun s -> opt_parser := Some s),
"<format> Input format (default: \"why\")";
"--format", Arg.String (fun s -> opt_parser := Some s),
" same as -F";
"-T", Arg.Int (fun i -> opt_timelimit := Some i), "-T", Arg.Int (fun i -> opt_timelimit := Some i),
"<sec> Set the prover's time limit (default=10, no limit=0)"; "<sec> Set the prover's time limit (default=10, no limit=0)";
"--timelimit", Arg.Int (fun i -> opt_timelimit := Some i), "--timelimit", Arg.Int (fun i -> opt_timelimit := Some i),
...@@ -145,6 +151,8 @@ let option_list = Arg.align [ ...@@ -145,6 +151,8 @@ let option_list = Arg.align [
" List the registered printers"; " List the registered printers";
"--list-provers", Arg.Set opt_list_provers, "--list-provers", Arg.Set opt_list_provers,
" List the known provers"; " List the known provers";
"--list-formats", Arg.Set opt_list_formats,
" List the known input formats";
"--parse-only", Arg.Set opt_parse_only, "--parse-only", Arg.Set opt_parse_only,
" Stop after parsing"; " Stop after parsing";
"--type-only", Arg.Set opt_type_only, "--type-only", Arg.Set opt_type_only,
...@@ -167,10 +175,20 @@ let () = ...@@ -167,10 +175,20 @@ let () =
(Pp.print_list Pp.newline Pp.string) (Pp.print_list Pp.newline Pp.string)
(List.sort String.compare (Register.list_transforms_l ())); (List.sort String.compare (Register.list_transforms_l ()));
end; end;
if !opt_list_printers then if !opt_list_printers then begin
printf "@[<hov 2>Registered printers:@\n%a@]@\n@." printf "@[<hov 2>Registered printers:@\n%a@]@\n@."
(List.sort String.compare (Register.list_printers ())); (List.sort String.compare (Register.list_printers ()))
end;
if !opt_list_formats then begin
let print1 fmt s = fprintf fmt "%S" s in
let print fmt (p, l) =
fprintf fmt "%s [%a]" p (Pp.print_list Pp.comma print1) l
in
printf "@[<hov 2>Known input formats:@\n%a@]@."
(Pp.print_list Pp.newline print)
(List.sort Pervasives.compare (Env.list_formats ()))
end;
if !opt_list_provers then begin if !opt_list_provers then begin
let config = read_config !opt_config in let config = read_config !opt_config in
let print fmt s prover = fprintf fmt "%s (%s)@\n" s prover.name in let print fmt s prover = fprintf fmt "%s (%s)@\n" s prover.name in
...@@ -178,7 +196,8 @@ let () = ...@@ -178,7 +196,8 @@ let () =
printf "@[<hov 2>Known provers:@\n%a@]@." print config.provers printf "@[<hov 2>Known provers:@\n%a@]@." print config.provers
end; end;
if !opt_list_transforms || !opt_list_printers || !opt_list_provers if !opt_list_transforms || !opt_list_printers || !opt_list_provers ||
!opt_list_formats
then exit 0; then exit 0;
if Queue.is_empty opt_queue then begin if Queue.is_empty opt_queue then begin
...@@ -247,10 +266,10 @@ let memlimit = match !opt_memlimit with ...@@ -247,10 +266,10 @@ let memlimit = match !opt_memlimit with
let debug = !opt_debug let debug = !opt_debug
let rec report fmt = function let rec report fmt = function
| Lexer.Error e ->
fprintf fmt "lexical error: %a" Lexer.report e;
| Loc.Located (loc, e) -> | Loc.Located (loc, e) ->
fprintf fmt "%a%a" Loc.report_position loc report e fprintf fmt "%a%a" Loc.report_position loc report e
| Lexer.Error e ->
| Parsing.Parse_error -> | Parsing.Parse_error ->
fprintf fmt "syntax error" fprintf fmt "syntax error"
| Denv.Error e -> | Denv.Error e ->
...@@ -272,7 +291,10 @@ let rec report fmt = function ...@@ -272,7 +291,10 @@ let rec report fmt = function
Prover.report fmt e Prover.report fmt e
| Register.Error e -> | Register.Error e ->
Register.report fmt e Register.report fmt e
| e -> fprintf fmt "anomaly: %s" (Printexc.to_string e) | Env.UnknownParser p ->
fprintf fmt "unknown format '%s'" p
| e ->
let print_th_namespace fmt th = let print_th_namespace fmt th =
Pretty.print_namespace fmt th.th_name.Ident.id_string th.th_export Pretty.print_namespace fmt th.th_name.Ident.id_string th.th_export
...@@ -384,11 +406,13 @@ let do_input env drv = function ...@@ -384,11 +406,13 @@ let do_input env drv = function
| "-" -> "stdin", stdin | "-" -> "stdin", stdin
| f -> f, open_in f | f -> f, open_in f
in in
let report = Env.report ?name:!opt_parser fname in
try
if !opt_parse_only then begin if !opt_parse_only then begin
Env.parse_only env fname cin; Env.parse_only ?name:!opt_parser env fname cin;
close_in cin close_in cin
end else begin end else begin
let m = Env.read_channel env fname cin in let m = Env.read_channel ?name:!opt_parser env fname cin in
close_in cin; close_in cin;
if !opt_type_only then () if !opt_type_only then ()
else if Queue.is_empty tlist then else if Queue.is_empty tlist then
...@@ -399,6 +423,11 @@ let do_input env drv = function ...@@ -399,6 +423,11 @@ let do_input env drv = function
else else
Queue.iter (do_local_theory drv fname m) tlist Queue.iter (do_local_theory drv fname m) tlist
end end
eprintf "%a%a" Loc.report_position loc report e; exit 1
| e ->
report err_formatter e; exit 1
let () = let () =
try try
...@@ -1064,7 +1064,19 @@ let parse_only _env fname cin = ...@@ -1064,7 +1064,19 @@ let parse_only _env fname cin =
ignore (Lexer.parse_logic_file lb); ignore (Lexer.parse_logic_file lb);
let () = Env.register_parser "why" ["why"] parse_only read_channel let error_report fmt = function
| Lexer.Error e ->
| Denv.Error e ->
Denv.report fmt e
| Error e ->
report fmt e
| e ->
raise e
let () = Env.register_parser "why" ["why"] parse_only read_channel error_report
Local Variables: Local Variables:
