GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
bb165cfe
bb165cfe
Andrei Paskevich
Parser: rename [_.._] to [..] for consistency with other bracket ops
2b61be07
10
Expand all
10 changed files
1466 additions
1474 deletions
+1466
-1474
doc/qualid.bnf
doc/qualid.bnf
+1
-1
doc/term1.bnf
doc/term1.bnf
+1
-1
src/core/pretty.ml
src/core/pretty.ml
+4
-4
src/driver/driver_lexer.mll
+2
src/driver/driver_parser.mly
+4
-1
src/mlw/expr.ml
src/mlw/expr.ml
+5
-5
src/mlw/pmodule.ml
src/mlw/pmodule.ml
+1
-1
src/parser/handcrafted.messages
+1443
-1456
src/parser/parser.mly
+4
-4
stdlib/seq.mlw
stdlib/seq.mlw
+1
-1
doc/qualid.bnf
bb165cfe
@@ -12,7 +12,7 @@
| "[]" ; collection access
| "[<-]" ; collection update
| "[]<-" ; in-place collection update
_.._]"
; collection slice
; collection slice
| "[_..]" ; right-open slice
| "[.._]" ; left-open slice %
\end{syntax}
doc/term1.bnf
bb165cfe
@@ -44,7 +44,7 @@
| "[]<-" ; in-place update
_.._]"
; collection slice
; collection slice
\end{syntax}
src/core/pretty.ml
bb165cfe
@@ -158,9 +158,9 @@ let print_ts fmt ts =
let
print_ls
fmt
ls_name
id_string
nm
as
ls
if
nm
"mixfix []"
then
pp_print_string
fmt
else
if
nm
"mixfix [<-]"
then
pp_print_string
fmt
else
if
nm
"mixfix [..]"
then
pp_print_string
fmt
else
if
nm
"mixfix [_..]"
then
pp_print_string
fmt
"([_..])"
else
if
nm
"mixfix [.._]"
then
pp_print_string
fmt
"([.._])"
else
if
nm
"mixfix [_.._]"
then
pp_print_string
fmt
"([_.._])"
else
let
s
id_unique
iprinter
ls
ls_name
in
match
extract_op
s
Some
s
fprintf
fmt
"(%s)"
escape_op
s
@@ -291,15 +291,15 @@ and print_app pri ls fmt tl =
_
t1
t2
t3
when
ls
ls_name
id_string
"mixfix [<-]"
fprintf
fmt
protect_on
pri
7
"@[%a@,[%a <-@ %a]@]"
print_lterm
7
t1
print_lterm
6
t2
print_lterm
6
t3
_
t1
t2
t3
when
ls
ls_name
id_string
"mixfix [..]"
fprintf
fmt
protect_on
pri
7
"%a[%a..%a]"
print_lterm
7
t1
print_lterm
6
t2
print_lterm
6
t3
_
t1
t2
when
ls
ls_name
id_string
"mixfix [_..]"
fprintf
fmt
protect_on
pri
7
"%a[%a..]"
print_lterm
7
t1
print_term
t2
_
t1
t2
when
ls
ls_name
id_string
"mixfix [.._]"
fprintf
fmt
protect_on
pri
7
"%a[..%a]"
print_lterm
7
t1
print_term
t2
_
t1
t2
t3
when
ls
ls_name
id_string
"mixfix [_.._]"
fprintf
fmt
protect_on
pri
7
"%a[%a..%a]"
print_lterm
7
t1
print_lterm
6
t2
print_lterm
6
t3
_
tl
fprintf
fmt
protect_on
pri
6
"@[%a@ %a@]"
print_ls
ls
print_list
space
print_lterm
7
tl
bb165cfe
@@ -89,6 +89,8 @@ rule token = parse
RIGHTPAR
DOT
DOTDOT
COMMA
bb165cfe
@@ -22,7 +22,7 @@
token
THEORY
END
SYNTAX
REMOVE
META
PRELUDE
PRINTER
MODEL_PARSER
OVERRIDING
token
VALID
INVALID
UNKNOWN
FAIL
token
TIMEOUT
OUTOFMEMORY
STEPLIMITEXCEEDED
TIME
STEPS
token
UNDERSCORE
LEFTPAR
RIGHTPAR
DOT
QUOTE
EOF
token
UNDERSCORE
LEFTPAR
RIGHTPAR
DOT
DOTDOT
QUOTE
EOF
token
BLACKLIST
token
MODULE
EXCEPTION
VAL
CONVERTER
LITERAL
token
FUNCTION
PREDICATE
TYPE
PROP
ALL
FILENAME
TRANSFORM
PLUGIN
@@ -141,6 +141,9 @@ operator:
LEFTSQ
RIGHTSQ
Ident
mixfix
LEFTSQ
LARROW
RIGHTSQ
Ident
mixfix
LEFTSQ
RIGHTSQ
LARROW
Ident
mixfix
LEFTSQ
DOTDOT
RIGHTSQ
Ident
mixfix
LEFTSQ
UNDERSCORE
DOTDOT
RIGHTSQ
Ident
mixfix
"[_..]"
LEFTSQ
DOTDOT
UNDERSCORE
RIGHTSQ
Ident
mixfix
"[.._]"
(* Types *)
src/mlw/expr.ml
bb165cfe
@@ -1184,9 +1184,9 @@ let print_rs fmt ({rs_name = {id_string = nm}} as s) =
if
nm
Ident
mixfix
then
pp_print_string
fmt
else
if
nm
Ident
mixfix
then
pp_print_string
fmt
else
if
nm
Ident
mixfix
then
pp_print_string
fmt
else
if
nm
Ident
mixfix
then
pp_print_string
fmt
else
if
nm
Ident
mixfix
"[_..]"
then
pp_print_string
fmt
"([_..])"
else
if
nm
Ident
mixfix
"[.._]"
then
pp_print_string
fmt
"([.._])"
else
if
nm
Ident
mixfix
"[_.._]"
then
pp_print_string
fmt
"([_.._])"
else
match
extract_op
s
rs_name
s
rs_logic
Some
x
_
fprintf
fmt
"(%s%s%s)"
@@ -1265,13 +1265,13 @@ let print_capp pri ({rs_name = id} as s) fmt vl =
_
t1
t2
t3
when
id
id_string
"mixfix []<-"
fprintf
fmt
protect_on
pri
"%a[%a] <- %a"
print_pv
t1
print_pv
t2
print_pv
t3
_
t1
t2
t3
when
id
id_string
"mixfix [..]"
fprintf
fmt
protect_on
pri
6
"%a[%a..%a]"
print_pv
t1
print_pv
t2
print_pv
t3
_
t1
t2
when
id
id_string
"mixfix [_..]"
fprintf
fmt
protect_on
pri
6
"%a[%a..]"
print_pv
t1
print_pv
t2
_
t1
t2
when
id
id_string
"mixfix [.._]"
fprintf
fmt
protect_on
pri
6
"%a[..%a]"
print_pv
t1
print_pv
t2
_
t1
t2
t3
when
id
id_string
"mixfix [_.._]"
fprintf
fmt
protect_on
pri
6
"%a[%a..%a]"
print_pv
t1
print_pv
t2
print_pv
t3
_
tl
fprintf
fmt
protect_on
pri
5
"@[<hov 1>%a@ %a@]"
print_rs
s
Pp
print_list
Pp
space
print_pv
tl
@@ -1284,9 +1284,9 @@ let print_cpur pri ({ls_name = id} as s) fmt vl =
_
_
_
when
id
id_string
"mixfix []"
Some
_
_
_
_
when
id
id_string
"mixfix [<-]"
Some
_
_
_
_
when
id
id_string
"mixfix []<-"
Some
_
_
_
_
when
id
id_string
"mixfix [..]"
Some
_
_
_
when
id
id_string
"mixfix [_..]"
Some
"[_..]"
_
_
_
when
id
id_string
"mixfix [.._]"
Some
"[.._]"
_
_
_
_
when
id
id_string
"mixfix [_.._]"
Some
"[_.._]"
_
None
in
match
op
vl
None
src/mlw/pmodule.ml
bb165cfe
@@ -1215,9 +1215,9 @@ let get_rs_name nm =
if
nm
"mixfix []"
then
else
if
nm
"mixfix []<-"
then
else
if
nm
"mixfix [<-]"
then
else
if
nm
"mixfix [..]"
then
else
if
nm
"mixfix [_..]"
then
"([_..])"
else
if
nm
"mixfix [.._]"
then
"([.._])"
else
if
nm
"mixfix [_.._]"
then
"([_.._])"
else
try
Strings
remove_prefix
"infix "
nm
Not_found
try
Strings
remove_prefix
"prefix "
nm
"_)"
Not_found
nm
bb165cfe
This diff is collapsed.
bb165cfe
@@ -56,7 +56,7 @@
let
get_op
s
e
Qident
mk_id
Ident
mixfix
s
e
let
set_op
s
e
Qident
mk_id
Ident
mixfix
s
e
let
sub_op
s
e
Qident
mk_id
Ident
mixfix
_.._
s
e
let
sub_op
s
e
Qident
mk_id
Ident
mixfix
s
e
let
above_op
s
e
Qident
mk_id
Ident
mixfix
"[_..]"
s
e
let
below_op
s
e
Qident
mk_id
Ident
mixfix
"[.._]"
s
e
@@ -1183,9 +1183,9 @@ lident_op:
LEFTSQ
RIGHTSQ
Ident
mixfix
LEFTSQ
LARROW
RIGHTSQ
Ident
mixfix
LEFTSQ
RIGHTSQ
LARROW
Ident
mixfix
LEFTSQ
UNDERSCORE
DOTDOT
UNDERSCORE
RIGHTSQ
Ident
mixfix
"[_.._
LEFTSQ
DOTDOT
UNDERSCORE
RIGHTSQ
Ident
mixfix
"[.._
LEFTSQ
UNDERSCORE
DOTDOT
RIGHTSQ
Ident
mixfix
"[_..
LEFTSQ
DOTDOT
RIGHTSQ
Ident
mixfix
LEFTSQ
UNDERSCORE
DOTDOT
RIGHTSQ
Ident
mixfix
"[_..
LEFTSQ
DOTDOT
UNDERSCORE
RIGHTSQ
Ident
mixfix
"[.._
op_symbol
OP1
stdlib/seq.mlw
bb165cfe
@@ -91,7 +91,7 @@ module Seq
(** [s[i..j]] is the sub-sequence of [s] from element [i] included
to element [j] excluded *)
let function ([
_.._
]) (s:seq 'a) (i:int) (j:int) : seq 'a
let function ([
requires { 0 <= i <= j <= length s }
ensures { length result = j - i }
ensures { forall k. 0 <= k < j - i -> result[k] = s[i + k] }
